Voice Activated Arduino (Bluetooth + Android)
308,359
1,200
286
About: Hi I'm Angelo! I am a college student taking my engineering majors in BS-EE/ BS-ECE at the DLSU. I use my course as an inspiration for making my current projects! I've been posting projects here ever since I...
Control your Arduino with voice commands using an Android smartphone! Before we make a voice activated home automation system, we must first learn the basic principles of the experiment. This guide will let you command the Arduino using your Android smartphone and a HC-05 Bluetooth module.
The designer of the app did not include a sample code. I looked for alternatives in Google's PlayStore but none was as good as the app that I've found. Luckily, I was able to figure it out although it took me a while to program it. Sorry IOS users, this app isn't available in Apple's app store :/
How Does It Work?
Have you ever encountered Android's speech recognition? Yes android has one and you can use it to control your Arduino, via Bluetooth. The App works by pressing the mic button, then the it will wait for you to say a command. The app will then display the word's that you've stated and will send data strings for the Arduino to process.
Home Automation System (on July 4, 2014):
A month from now/ I'll be releasing a highly sophisticated home automation + security system. It's my biggest project ever! Our current agenda is to program a better smartphone app that work's like Siri (talks back) and sends strings (data types) to the Arduino via bluetooth. If you want to take a sneak peek of the project and it's concept, kindly skip to the last step. The prototype that I'm working on now is composed of a network of wireless switch boxes that connects to a main control panel via WiFi/ Bluetooth.
Here's A Quick Video Demo:
Step 1: Parts & Materials
If your having trouble in finding them, I'm sure RadioShack has all of them. If you want to buy online try searching on Amazon or DealExtreme.
Thing that you'll need:
- 5 LED Indicators (the color of your choice)
- Arduino UNO (a clone works fine)
- HC-05 Serial Bluetooth Module
- Solderless Breadboard
- Jumper Cables
Step 2: Assemble the Mini Bluetooth Shield
My JY-MCU (DX Bluetooth Module) is still installed on my robots, what I have right now is the bare HC-05 module.
As we all know, the HC-05 doesn't come with a PCB. Soldering wires, directly to the metal conductors, isn't a good idea since the conductors could chip off anytime. As a solution, you can cut a fraction of perf-board then mount the HC-05 on it. I mistakenly connected my LED indicator on a blank (N/A) pin so mine doesn't work.
___________________________________________
Too lazy to assemble a Bluetooth shield? DX.com has a ready made version (click here). I've used the DX Bluetooth module on my robots, it's tested and it's 100% ok! You can visit Bluetooth related projects (Bluetooth Sumobot and Bluetooth FPV Rover) as reference.
Step 3: Connect the Bluetooth Module
Grab some jumper cables and power the Bluetooth module with 3.3 volts. Remember, the bare HC-05 run on 3.3v and not on 5v. On the other hand, the JY-MCU has a built in regulator, it can run on a 5v line.
Now connect the RX (pin #0) of the Arduino to the TX pin of the Bluetooth module and the TX (pin #1) of the Arduino to the RX pin of the Bluetooth module. (refer to the image above)
Step 4: Connect the LEDs
Connect the positive leads of each LED on pins # 2,3,4,5,6 of the Arduino. The negative leads of each LED goes to the negative rail of the breadboard. The negative rail of the breadboard goes to the Arduino's ground.
Step 5: Programming the Arduino
Understanding The App:
Before you program the arduino, you must first learn how the app works. The app work by recognizing your voice command, it will then display the words that you've spoken then sending data/ strings to the arduino via bluetooth. What's a string? A string is like a word, you can make conditional statements out of it [ex: if (voice == "*computer on") {// turn Pin #2 on} ]. The "voice" is your string, "==" is your condition (means equal to), "*computer on" is your command and the code inside the curly-braces "{ }" are the codes to be executed once your string matches the command condition.
What's the format of the string? How does it know when the next command kicks in? How does it differentiate a set of words from a new command? The app sends strings in this format *command#, the asterisk (*) indicates the start of a new command and the hash-tag (#) indicates the end of a command. I was able to remove the hash-tag (#) after each word in the conditional statement was not able to remove the asterisk (*). You'll need to start your command condition with an asterisk otherwise the sketch will not work.
How Can I Change The Commands?
You can see that the "*TV on" is highlighted from the image above. If you want to change the command to ,humm let's say "open garage door", you can replace the "*TV on" with "*open garage door". Always remember to start the command with an asterisk.
//Coded By: Angelo Casimiro (4/27/14)
//Voice Activated Arduino (Bluetooth + Android)
//Feel free to modify it but remember to give credit
String voice;
int
led1 = 2, //Connect LED 1 To Pin #2
led2 = 3, //Connect LED 2 To Pin #3
led3 = 4, //Connect LED 3 To Pin #4
led4 = 5, //Connect LED 4 To Pin #5
led5 = 6; //Connect LED 5 To Pin #6
//--------------------------Call A Function-------------------------------//
void allon(){
     digitalWrite(led1, HIGH);
     digitalWrite(led2, HIGH);
     digitalWrite(led3, HIGH);
     digitalWrite(led4, HIGH);
     digitalWrite(led5, HIGH);
void alloff(){
     digitalWrite(led1, LOW);
     digitalWrite(led2, LOW);
     digitalWrite(led3, LOW);
     digitalWrite(led4, LOW);
     digitalWrite(led5, LOW);
void setup() {
  Serial.begin(9600);
  pinMode(led1, OUTPUT);
  pinMode(led2, OUTPUT);
  pinMode(led3, OUTPUT);
  pinMode(led4, OUTPUT);
  pinMode(led5, OUTPUT);
void loop() {
  while (Serial.available()){  //Check if there is an available byte to read
  delay(10); //Delay added to make thing stable
  char c = Serial.read(); //Conduct a serial read
  if (c == '#') {break;} //Exit the loop when the # is detected after the word
  voice += c; //Shorthand for voice = voice + c
  if (voice.length() > 0) {
    Serial.println(voice);
  //----------Control Multiple Pins/ LEDs----------//
       if(voice == "*all on") {allon();}  //Turn Off All Pins (Call Function)
  else if(voice == "*all off"){alloff();} //Turn On  All Pins (Call Function)
  //----------Turn On One-By-One----------//
  else if(voice == "*TV on") {digitalWrite(led1, HIGH);}
  else if(voice == "*fan on") {digitalWrite(led2, HIGH);}
  else if(voice == "*computer on") {digitalWrite(led3, HIGH);}
  else if(voice == "*bedroom lights on") {digitalWrite(led4, HIGH);}
  else if(voice == "*bathroom lights on") {digitalWrite(led5, HIGH);}
  //----------Turn Off One-By-One----------//
  else if(voice == "*TV off") {digitalWrite(led1, LOW);}
  else if(voice == "*fan off") {digitalWrite(led2, LOW);}
  else if(voice == "*computer off") {digitalWrite(led3, LOW);}
  else if(voice == "*bedroom lights off") {digitalWrite(led4, LOW);}
  else if(voice == "*bathroom lights off") {digitalWrite(led5, LOW);}
voice="";}} //Reset the variable after initiating
Step 6: Learn to Use the App
Download The Free App Here: Android Meets Robots : Voice
5 Simple Steps:
1st.)  Download the app from Google PlayStore
2nd.) Tap on options menu then select "Connect Robot"
3rd.)  Click on your BT-Module (in my case it's the HC-05)
4th.)  Wait until it says Connected to BT-Module (HC-05)
5th.) Tap on the mic icon and state your command!
Here's A Quick Demo Video:
Step 7: Next Project: Highly-Sophisticated Home Automation (Network)
Here's a drawing of what to expect on my next Arduino project!
Sorry for the terrible doodle :)
17 People Made This Project!
  • Trash to Treasure
    Trash to Treasure
  • Tape Contest
    Tape Contest
  • Arduino Contest 2019
286 Discussions
bio-ranjit
1 year ago
I am unable to get the voice app on Google play. Can you make help.
pejjaireddy_14
Question 1 year ago
Hey, can I use WI-FI module instead of HC-05 ?
pejjaireddy_14
Question 1 year ago
hey can i use an wifi module instead of HC-0 .if yes is their any changes i have to make?
please answer ...
Maya07phi_rocks
Question 1 year ago on Step 6
Which app to use as the app mentioned above is no longer available on play store and I am not able to find a good app.
MihaelaN2
1 year ago
Hi. It`s not working. The Serial.available() value is always 0. Can you help me?
professors3
1 year ago
would like to start out saying having lots of fun playing with this setup have added up to 8 chanells but would like to ad more and maybe a sensor or two still learning how to program so could use some help please.
#1 I cant seem to get the relay to work if I move say pin 4 to pin 52 even after writing the new placement fot it.?
#2 how would I add a PIR sensor to turn on a light on my relay setup with a over ride if I walk in room then tell it romm lights stey on or something?
Iam sure other sensor might come latter but this is one thing I would like to do as Iam using a mega and want to move all the relay pins to say 52,50,48,46,,44,42,40,,38 and then add some singles down the road to get around 20 or so setup to run my house and then add sensors ?
some day hope you add a LCD
professors3professors3
Reply 1 year ago
sorry it was just me puttimg the pins in the right spot helps ...help to double and treaple check everything.
would like to ask about the sensors like a PIR or others as as I wrote.
maybe add a touchscreen or LCD
Mayannk hemaraj
Reply 1 year ago
you have to put semicolons after defining led pins instead of comma
nazril26
1 year ago
how to check the programe is work if i dont put the adruino
anand shaurya
1 year ago
i'reprogram the arduino but this is not work why
plz.... help me
anand shaurya
1 year ago
that's works thanks.
instructable
oguzt
2 years ago
We built a circuit in our project. As a result, we showed the LCD on the screen. How can I send this text to the android mobile phone? And how can I read this text that I sent out by voice? I used genuino 101.
Asmita01
2 years ago
Why do we need the PCB design on HC-05 module? And how can I do this? Please guide me. And I can not connect my module with my galaxy grand 2 set. How can I connect?
