Waffle Iron Adapted Into MIni Kiln...or...The Bavarian Bead Buster!
40,528
168
45
As a lampworker/glassworker, I needed an annealing kiln that was more portable than my huge Paragon kiln, for travel & show work.
Here's my quick, easy & economical alternative.
This is my first instructable - so please bear with!
PLEASE NOTE: SOME OF THE STEPS INVOLVED CAN BE DANGEROUS!!!
READ THROUGH ENTIRE PROCESS FIRST AND FOLLOW DIRECTIONS CAREFULLY!
POTENTIAL ELECTROCUTION HAZARD!
PLEASE BE SAFE, VENTILATE WELL, POTENTIAL FOR HAZARDOUS FUMES!
POTENTIAL FIRE HAZARD - KEEP A FIRE EXTINGUISHER RATED
FOR ELECTRIC FIRES HANDY!
YOU'LL NEED:
-An older style steel electric waffle maker with removeable waffle plates.
Pretty doesn't matter, functionality does - see image.
I see them for sale regularly at yard sales & 2nd hand shops for a couple of bucks.
(I've seen newer styles that seem to be a light aluminum, no experience with these)
-Probe thermometer.
(Our particular thermometer is a 'flue' thermometer, meant for use inside
a chimney. They're available in a range of temperatures - for our use, we need one that
can read up to 1500F. Available at wood stove resellers, or possibly ordered from an appliance supplier - Cost? Approx: $30.00)
-Insulated container of some sort to house the waffle iron.
(old metal refridgerator drawer, small propane barbeques, less the inner parts,
work great too.)
-Agregate, or other insulating material.
-Insulated/Fireproof fibre matting.
(may be purchased at some welding shops & most hot glass facilities/shops)
Optional/fire brick - kiln liner brick.
(Kiln liner brick is exactly the same as stove liner brick, however, stove brick is
a fraction of the cost and can be easily purchased anywhere wood stoves & said
accessories are sold)
Tin foil. The heavier guage, the better.
Can of spray brake cleaner.
Supplies:
Step 1: Cleaning & Prepping the Waffle Kiln
Remove any plastic or bakelite type handles, feet, or other 'accessories'.
(keep in mind, my mini kiln has successfully ramped up to 2000F - these handy
plastic handles & feet will melt like candy if not removed - I'm pretty sure they'll smell bad too!)
Remove waffle plates.
You are now faced with an shell of a waffle iron, complete with elements, wiring,
ceramic posts that hold the elements, and some whatnot gagetry.
It's probably really greasy & dirty in there - any grease or carbon fumes/smoke emitted
during your anneal process could leave smudges & imprints on your glass projects.
(not to mention a heck of a smell, probably...I'm not big into nasty smells...)
Take the iron outside & shake any loose gunk out.
Wipe any excess you can reach with paper towels.
Key words here...SAFETY & VENTILATION!!!
Take the iron outdoors & place it on the ground or on some other heat proof surface.
Place it somewhere away from highly flammable objects.
Spray the insides liberally with brake cleaner. (don't inhale the fumes - brake cleaner is nasty!)
Spray the inner wiring & coils, anywhere grease may have collected.
Try to avoid letting the brake cleaner run out onto any outer wiring - if so, wipe it off.
Let it sit for five minutes & then plug it in & fire it up.
Be ready...this will be messy, smoky & potentially scary!
FIRE HAZARD!!!
Keep your fire extinguisher handy, just in case.
(be aware of local fire bylaws, perhaps your neighbours don't have THAT great a sense of humor...)
As the iron heats up, it will begin to smoke. Alot. Even more. Still more!
It may even catch fire - although this should last only a minute or two at most.
(here's where the fire extinguisher comes in handy, just in case...)
Keep an eye on the outer case of the iron - it probably won't get too hot, but you'll need to
I didn't find it was necessary - but can't hurt to think ahead!
I simply pulled the cord directly away from the iron before I plugged it in, so it wasn't
lying right next to it & covered it with the foil to sheild it from any direct flame.
Once the whole mess has stopped smoking, unplug it & let it cool down.
A power bar is handy for this step, as, if a problem occurs, the power bar
should cut power, or, you can quickly hit the switch before unplugging the power
bar & not have to worry about having to touch potentially hot electric cords...
Step 2: Cleaned & Ready!
The kiln shown pictured was already built, and I didn't feel the need to disassemble it - so I've just zoomed in on any important parts.
There's a similar kiln kit available commercially that is made out of a small toolbox.
(red style, steel toolbox with hinged lid & one inner tray) This kiln is pretty much the
same design, less the fancy digital controller.
Your waffle iron may differ someone, and some small adaptations may be in order.
This particular "kiln" has been in and out of annealing service for about 8 years now.
Now that it's all cleaned up & cooled off, look inside...
As shown in the pic, the insulated wirings & elements should be
nice & clean, white even, if the wiring is coated with a fireproof outer shell.
(please excuse the dusty mess in the bottom, this is the galvanized wire coating,
I just hadn't swept it out yet)
This iron had many, (many, many) years of use as a waffle maker before
being relegated to glasswork, yet the brake cleaner job cleaned the inner workings as though
they were new.
Once again, I mention, this kiln has been ramped up to 2000F - yet still the insulated wiring & exposed elements continue to function...who knew?
Step 3: The Build!
DANGER - ELECTROCUTION HAZARD
Now that the elements are now exposed, they pose a potential burn/electrocution hazard,
and must be sheilded for protection.
I purchased regular galvanized grid wire (as shown in image)- 1cm x 1cm, cut it to size,and fit thepiece into both the top and bottom of the iron, wiring them into place so they don't fall in or out.
Be sure to trim your gridwire so it doesn't come into contact with ANY wiring or elements.
(results could be shocking!!!) Tuck any loose ends in and nip them off.
The gridwire most commonly available is galvanized - after a couple of firings, the galvanized
coating on the gridwire will flake off. (as seen in step 2 image)
Sweep or vacuum it out now and then, and if your gridwire becomes weak, replace & repeat.
If you can find it ungalvanized, even better.
In some cases, the ceramic posts already inside support the grid wire too.
Make a snake out of tin foil long enough to go around the outside edge of the bottom of the iron.
(most irons are on a hinge, the foil fills the gap that the original waffle presses filled,
and stops heat from escaping.)
Press the foil down onto the bottom, close the top & press it down too, making an imprint...
Kind of like a gasket...
Repeat with the top.
I wired my foil down, as after a few uses, it would sometimes separate when
I lifted the lid.
You'll need to experiment to see what works best for you.
This particular iron had some holes already punched out for another handle which I removed.
These holes were perfect for inserting the temperature probe. Yours may not have such holes,
and so,you may have to punch/drill a hole in a more applicable spot, or,
you can insert the probe thermometer somewhere between the top & bottom, wedged between the foil.
(try to keep it away from the elements as much as possible,or you'll get a higher reading than normal.)
The probe also should not be touching any wiring or elements or electric shock may occur!
Place the probe in a location where you'll be able to read it easily.
(remember, it'll be hot, so put it somewhere you can see it & possibly reach to shift it,
if necessary)
Step 4: Insulating!
As for the main kiln build, that's about it...however...
Because this setup has little or no insulation, it loses heat at a rapid rate.
(uneconomical & a pain in the behind!)
As a result, I chose to insulate it.
I used a metal refridgerator drawer to house my kiln - dropping the iron into the bottom, then
filling any gaps up to the bottom lip with aggregate.
The back cord (as seen in image) is wrapped in insulation & foil, sunk down into the insulating aggregate, & clipped to the edge to keep it from falling back in next to the metal & melting.
Check the cord frequently to be certain it's not damaged or melted, or frayed in any way.
If you happen to be handy electrically, or know an electrician, it may be necessary to replace
this cord with one that can withstand a higher temperate.
I used a small section of sheet metal for a lid, and covered it with stove liner fire bricks, also
called kiln liner bricks, (at a much higher price...)
There's no pic of the lid - I couldn't find it at this time...:/
Fireproof insulated fibre matting works well as a lid too, however, it falls apart after a short
amount of time, so, I found the bricks far more economical.
I can also easily lift the lid to take a peek at the temperature probe this way.
I was quite surprised to find that these odd probe thermometers are actually quite accurate.
(stuck one in my paragon kiln one day, just because I wanted to know for sure...!)
Step 5: Feel the Burn!!!
Why anneal glass?
A quote from Bandhu Scott Dunham - a famous Hot Glass Master...
"The basic principle of annealing is to hold the hot glass at a temperature where it is fluid enough for internal stresses to relax, and then to cool the glass so slowly that both the inside and the outside, the thick sections and the thin sections, have a chance to shrink evenly. This way, no stresses are developed or 'frozen' into the finished piece."
Soft glass - most commonly known as moretti - has a fluid temperature of approximately 1770F. (again, I repeat - this kiln ramped up to 2000 degrees in a test run - 2000F will seriouly melt any soft glass you may be using & cause it to drip onto your elements, hence, ruining your kiln. Realistically, very little should ever touch your elements. If something drips, turn everything off, unplug, cool slowly, then clean it off!)
If you're into slumping glass, this is wonderful, however, if you're annealing beads, this isn't a good thing!
Hard glass, commonly known as borosilicate, or, pyrex, is a much harder glass, not recommended or tried in this small kiln.
To anneal beads, make a couple of supports with extra grid wire to support bead mandrels.
(see image)
This keeps the beads from touching any grid wire & possibly getting marked up.
It also supports the bead mandrels & prevents them from falling into the kiln &
coming into contact with the exposed elements and any exposed wiring - should
one of your mandrels or any tool fall into the kiln & contact the wiring, unplug it
before removing, or you could be in for a nasty shock.
I simply folded a section of grid wire in half, sort of in a tent like shape & placed it
inside the kiln.
Two pieces folded this way easily support a number of bead mandrels.
To slump, use a small piece of kiln washed kiln brick to place your glass on.
(don't forget, the glass will stick to the brick without some kind of coating - kiln wash is
cheap and can be purchased at any hot glass or ceramic supplier, or kiln manufacturer)
The tricky part of these 'do it yourself' kilns is the annealing process...
I'll use annealing soft glass beads as an example.
Soft glass, (moretti) with a COE of 104 needs an annealing schedule of:
Approximately 1 hour at 960F.
Temperature down, 100 degrees per hour to 800F for another hour.
Temperature down, 100 degrees per hour to room temperature.
With a modern kiln, the process of slowly cooling down or ramping up is
usually done with a computer controller.
Our wee waffle iron, however, has no controller.
Heat regulation is done by powering on and off, and, once you've settled into
a routine, a timer is helpful.
You'll have to monitor your first few firings closely to be certain your temperature
isn't getting too high, and your probe is fairly accurate.
(if your beads begin to droop & melt off the mandrel, it's too hot!)
Also, I found with the insulation packed in well, simply turning the kiln off
after the 800F hour, refaining from 'peeking' & keeping the heat it, the kiln lost heat at less than the required rate of 100 degrees per hour...
Once again, I stress SAFETY in all aspects - don't forget to VENTILATE!!!
(should you be indoors, which, I reiterate, is not a good idea...garage, maybe ok...with a fan)
Keep a fire extinguisher handy.
I personally use a power bar, at all times, during an anneal with this kiln.
If there's a problem, I can disconnect while being fairly far away from the danger zone.
Lead glass in itself produces fumes of an unwanted nature, I can't even begin to imagine how bad a lungful of galvanization would be!!!
I strongly suggest this "DIY" kiln only be operated out of doors.
Always open to new adaptations of my waffle kiln!
Thanks for looking!
    • Woodworking Contest
      Woodworking Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    45 Discussions
    spark master
    4 years ago on Introduction
    Kiln liner bricks have a much better insulation factor, if available and affordable they will serve you better!
    nice instructable
    pbarnett
    9 years ago on Step 5
    I am looking to build a kiln to use for enameling metals. Wonder if an old and small toaster over would work. Basically following the same steps, laid on its back inside a suitable container so the elements are on the sides instead of top and bottom. If it had the Pyrex glass window I would be able to monitor the project. Since the firing time is pretty short and no annealing is required I should be able to do it. Any ideas?
    glassguy23pbarnett
    Reply 9 years ago on Step 5
    I like that toaster idea if you build it (or already have) you should post it up here.
    1 suggestion: I don't know the temperatures that you use for enameling metals but I would suggest that if you want to add a window to a kiln use fused quartz glass instead of borosilicate (pyrex) glass. Quartz glass has a much higher melting point and is the standard for high temp viewing windows. Good luck.
    bonecholampworksglassguy23
    Actually, I'd like to see that too, if it gets done! (that was the problem with the waffle iron - it works great, as long as you don't need to see inside it!) Yes, that's a great idea too, (I just didn't know it was called quartz glass!) I'm assuming you could buy this glass at a place that deals in wood stoves - as I'm also assuming that would be the type of glass in the front of my woodstove. (and, for certain, is has gotten hot enough in there to melt boro) Thanks for the tip! Janice
    XTLbonecholampworks
    Old fashioned wood stoves used to use a mica sheet as a window. its thin and available from the same places.
    bonecholampworksXTL
    Hi,
    Yep, we used to be able to get it, but I'm not certain anymore.
    We heat with wood stoves, and the "Safetly Standards" stuff sure has changed over the last few years.  I'm not sure you're even allowed to use Mica anymore, too bad too, we have a georgeous antique corner stove, and I'd like to have an insert put in it to make it airtight, but I believe I'd still have to remove the mica, I'll have to check for sure.
    Thanks for bringing that up!
    A thought, if instead of the mica sheets (and I realize this may be an expense unless you can scrounge one from an old discarded oven) the Pyrex type glass in sheets would serve as an acceptable window, I would think......albeit, it will complicate the construction a bit.
    Hi Goodhart,
    Pyrex might do, but you'd have to be sooo careful!
    (and attentive too - something I'm so not good at!!!)
    Pyrex - or Borosilicate - has a different COE, and melts at approx.
    1570 F.
    (old corningware makes some awesome bracelets!)
    I've easily ramped this baby up to 2000 F.
    I'd have been so dissapointed if I'd have melted it!
    (I already have lots of melted 'experiments')
    A great idea for a PMC kiln though I would think.
    Ok,  then maybe savaging the "window" from one of those electric ovens that have a Self Cleaning feature (where temps reach up so high it pretty much burns away everything inside the stove, yet the window survives)?  I am uncertain what that temperature might be, that the oven reaches, however.
    That is, only if one wished to observe what is going on inside.
    Ok.....  I have to know more about using broken CorningWare for jewelry.  Can you post a picture and some basic instructions?  By the way I finally broke down and bought a used small kiln.  I ran into so many safety issues that I gave up on the homemade.  I would get one problem figured out and then another would pop up.  I was spending more time trying to build a kiln when I could have been enameling and melting stuff.  Even the mistakes are fun.
    kristell1119
    5 years ago on Introduction
    in your opinion.. Do you think this would work for small clay objects?
    Psyckosama
    7 years ago on Introduction
    About the Mica brought up above: http://antiquestoves.com/st/products.php?cat=1
    There you go.
    Do you think this method could be used to build a small Kiln for burning out wax in lost wax casting?
    I'm thinking about gutting a used table top grill for the heating elements.
    Hey, Thanks for the link!
    I don't see why not -If you can't find a suitable "waffle iron" there's no reason you couldn't build your own - a metal box - lid, insulate the inner with stove bricks, scavenge some elements, insulators & other necessities, and build to suit!
    (it's one of those projects on my ever growing "todo" list - I'd be interested in how it goes for you if you do try... )
    Good luck!
    Hey, just happy to help. My google-fu is very strong. :)
    I live near a good will. I intend to simply pick up one of those George Foreman type grills, they normally have a dozen of them, and strip it. I need something that can fit a crucible though as I'll be using it for investment casting uses.
    Very good instructable but the safety warnings are a bit weak. How about using bold text for ELECTROCUTION warning.
    You also mention keeping a fire extinguisher handy - some are water based and should not be used on live wires!
    On top of the fire and electrocution hazards, and the vapors, remember that the "white fireproof outer shell" on the wires and whatever is insulating the heating element are almost certainly asbestos if the waffle iron was made before 1980.
    Very cool, but way too risky for my blood!
    Thanks Tina!
    (do you drive? Don't check the 'risk ratio' involved in auto accidents then...)
    Yes, that would be something to check on...and I guess I should have mentioned that! (I've done alot of kiln building/repairing, and that's what's so awesome about Instructables, if you've forgotten or omitted something, there are always peeps out there willing to help!)
    When in doubt, do check! (I did mention ventilation...and I've done uber amounts of research on this over the years, although, my research certainly isn't going to stop someone else's foolish behavior, as Patrick pointed out...LOL)
    Investigation & research turns up alot of useful info on this sort of thing.
    www.asbestos.net is a valuable resource.
    The insulators are made of ceramic, very much the same as those used in a more modern kiln setup, if a different shape.
    If the wire covers in any particular item are white, and unbound, it's very highly doubtful that they would, or could, be asbestos. Unbound asbestos wire cover becomes 'friable' (disintigrates) in a very short amount of time.
    (for that matter, why anyone would use any electrical appliance that had frayed wire or insulation is beyond me...)
    Keep in mind that asbestos is most hazardous when it's in a friable state, meaning the dust particles can become airborne.
    (very much the same as fumes from glassblowing/lampworking & dust from bead release & kiln wash can be hazardous)
    This is far more of a hazard in home and industrial applications, around furnaces, insulation, in walls, ceilings, floor tiles and roofing materials where it may fray or dust may become airborne during renovation or construction projects, and for those who frequently repair old appliances such as crock pots and popcorn makers.
    (I worry more about whats in my old home...I happen to KNOW the old wiring was asbestos, and I'll tell you, that wasn't fun! Makes one wonder what else may be lurking in the walls)
    Most often, this type of wiring is a sleeve made of fiberglass, safe unless it too becomes brittle and the particles may become airborne.
    Of course, if one is uncertain, it's simple enough to replace those wires, after all, the iron is already half disassembled.
    As for the electrocution hazard...I have two modern (circa 2000ish) "pro" glass kilns, and one very large (circa 1970) ceramic kiln. Their elements aren't covered either.
    Vapors, yes, nasty, dangerous, but a risk easily taken care of with proper ventilation & masks. Been done for many years.
    (If you're into lampworking, or anything involving fumes, (I'm guessing not, but you never know!) I have a mega huge list of safety resources & such that I've compiled over the years, if you want a copy, just let me know!)
    Anyway, so, everyone...listen up!
    NO ASBESTOS!!!
    DON'T POKE ANY EXPOSED WIRES OR ELEMENTS!!!
    WEAR A DAMN MASK & AN APRON!!! (rubber boots and a stick add to the costume immensely!)
    STAY OUT OF VEHICLES!!! (just joking Tina!)
    :) Thanks Patrick... I did put this in the "not liable" category... (and, I had warnings everywhere, but culled them out due to repitition) I worried more about ventilation, as in my experience, people are aware of electrical hazards, so aware in fact as to ignore others. I'm assuming (and hoping!) one who would undertake such a task would have some minimal knowledge, or, at least do some research on the subject before starting...or else they'd probably have already thinned themselves from the herd... And, yes, I agree on the fire extinguisher, but...isn't that a common sense issue taught in Grade school? (I know it was for me) So, (Thanks Patrick) please heed what Patrick has to say, as he is correct - most fire extinguishers have a rating on the outer hull which indicates what they are. Some would be bad news on electric fires. (I believe mine are Pyrene based...) Janice
    I liked the idea of plugging the unit into a power strip. I was taught in multiple fire safety trainings, once you cut the power, a so called "electrical fire" becomes a plain old "material fire."
    Still doesn't help with the original electrocution aspect, but I guess you could also always plug into a GFI. And wear a rubber suit, carry a rabbit's foot and a rosary . . .
    This is a wonderful 'able. I've been fusing glass at 1500* in a small high fire kiln (overkill) and plan to experiment with the wedding present waffle iron c. 1977.
