Walnut Hallway Table Topper
5,340
222
5
Topper for a metal hallway table topper I found.
Supplies:
Step 1:
Found a piece of walnut with an interesting graining pattern and cut it into 3/4" strips and mixed them up.
Step 2: Glue Up
Glued them together and clamp them up while keeping them flat.
Step 3: Finish
I used vinyl sealer and precatalyzed lacquer.
Step 4: Here It Is
I just put small adhesive clear rubber feet on the bottom of it and set it in place. Thanks for looking y'all.
    • Party Challenge
      Party Challenge
    • Woodworking Contest
      Woodworking Contest
    5 Discussions
    TimBToddalisterdark
    Reply 4 years ago on Introduction
    I did not attach it at all. I put some small clear rubber pads down so it wouldn't slide, and just placed the wooden top on top of the table.
    I considered screwing through the metal top, underneath, unto the wood, but wanted to avoid doing that in case I ever decided to remove the top or something.
    I's been over a year and it hasn't moved.
    deletemetoo2
    4 years ago
    Table looks great! The metal frame looks to be a 55 gallon aquarium stand. Those are readily available.
    TimBToddseamster
    Thanks! I didn't make it but I refurbished it. I found it in a field of kudzu. You can see some photos here if you're interested: http://imgur.com/a/8y8ZA
