Watch Strap Buckle
3,583
7
About: I truly enjoy making things...
I was once looking at my wrist and thinking how hard would it be to make a DIY watch strap buckle. As it turns out, it is a surprisingly simple task. It probably took me less than an hour to make and I have something original and durable.
Step 1: ​Supplies and Tools
  • Aluminum flat bar – the width dependence on the width of your strap. I am using a 20 mm wide and 2 mm thick piece. e. g. https://www.amazon.com/Pieces-ALUMINUM-FLAT
  • Steel wire or nail – 1,2 mm in diameter
  • Regular spring bar
Tools
  • Hacksaw
  • Fret Saw
  • File
  • Sandpaper
  • Vice
  • Drill press or cordless drill
  • Drill bits – 1 mm, 1.5 mm, 3 mm
Step 2: Draw the Shape
I used old an old buckle as a reference, therefore I just traced its shape on a piece of flat aluminum bar. You, however, can draw any shape, just make sure that you have enough clearance on the inside. You can see the exact measurements of mine on the picture.
Step 3: Cut Out the Inside
  • Now you can remove the material from inside of the buckle. I used a fret saw because its blade can fit in the corner, therefore I can cut the back side as well. To make it easier you can drill a 3 mm hole in the corner. You could also use a hacksaw and drill out the back side.
  • After most of the material is removed you can work to the line precisely with a flat file. Lastly, clean everything with a 240 grit sandpaper.
Step 4: Dril Holes for the Spring Bar
  • Support the lugs of the buckle with a scrap piece of wood. Drill a 1 mm hole in each lug to accept the spring bar.
  • A drill press is the best tool for the job but you theoretically could do it with a cordless drill as well. 1 mm drill bit is quite fragile so be careful and take your time.
Step 5: Cut the Part and Clean It
  • You just cut off the piece you need for the buckle with a hacksaw.
  • Hold the piece in a vice, clean it with a file and chamfer the sharp corners.
  • Lastly finish the whole piece nicely with a 240 grit sandpaper. You can go to higher grits if you want, but I was going for a brushed look so 240 was enough.
Step 6: Grove for the Buckle Tongue
Mark the middle of the buckle with calipers and make a groove with a small rounded file. This will accept the tongue and make the connection nicely secure.
Step 7: Make the Tongue
  • You take a substantially longer piece of 1.2 mm wire than you will need at the end (20 mm should be enough). Using pliers you will bend over the last 3 mm of the wire. Next, you will flatten the area a little bit with a hammer.
  • Then using a drill press and a 1.5 mm drill bit you will expand the hole which is created when you fold the material. This hole will then accept the spring bar.
  • Now you can assemble the buckle mark how long you need the tongue to be, cut off the excess, and clean it with a file.
Step 8: Assembly
Now you can simply put everything together. Regular watch spring bar is going to connect the buckle, tongue, and strap together nicely. It is a good idea to use a spring bar tool, it makes the process easier.
    • Warm and Fuzzy Contest
    • Epilog X Contest
      Epilog X Contest
    • Comfort Food Challenge
    2 Discussions
    Troubah
    3 months ago
    Very nice !
    Is aluminum durable enough for something you wear everyday ? Aren't you worried it bends over time ?
    JindraSykoraTroubah
    Reply 3 months ago
    Thank you. I have been using it on an almost daily basis for quite some time now and I did not have any issues with it yet... The tongue is probably the most loaded part and that is made out of steel.
    Important to state though, I try not to abuse this watch. However, I am definitely planning to make a new version out of steel some day. :D
