Wearable LED Flower Brooch
3,288
87
About: YuKonstruct is a non-profit society which provides an enthusiastic community of makers and entrepreneurs affordable access to space, equipment and knowledge. This community serves to embrace the individual a...
This project was created for YuKonstruct's first Build Night.
YuKonstruct is the first makerspace in Canada's north. Our mission is to provide access to shared space, quality tools, available expertise, and a collaborative environment to help makers build anything!
This pretty flower pin is easy to make and fun to wear.
The parts are also easily assembled into kits if you'd like to make a bunch of them at your next craft party.
Step 1: Gather Your Materials
You'll need:
  • LED
  • Battery
  • Tulle
  • Felt
  • Needle & thread (or a glue gun and glue)
  • Pin back
  • Scissors
  • Pliers
Step 2: Make the Backing
Cut a leaf shape out of felt.
Make sure the felt leaves are large enough to cover your battery.
Step 3: Add the LED
Poke the metal ends (leads) of the LED through the felt leaves.
Using small pliers, carefully bend the leads of the LED. One lead should be curled up tight against the felt leaves and the other should stick out in a L shape in order to touch the other side of the battery.
Test the fit with the battery. If both leads are touching one side each of the battery but it doesn't work, try flipping over the battery.
Step 4: Create a Pocket for the Battery
Cut out a square of felt slightly larger than the battery.
Sew 3 edges of the felt square to the felt leaves to create a pocket for the battery (alternatively, use a glue gun).
Step 5: Make the Tulle Flower
Twist and wrap the tulle around the LED to create your flower.
Secure the tulle in place with a few stitches (alternatively, use a glue gun).
Step 6: Add the Pin
Sew the pin back onto the back of the battery pocket.
Step 7: Wear With Pride!
Pop in the battery and wear your glowing flower with pride!
When not in use, simply slide the battery out of the pocket.
You can also embellish your flower with glitter, embroidery or paint.
These glowing flowers would make funky prom corsages, wedding boutonnieres or hair accessories.
    • Jewelry Challenge
      Jewelry Challenge
    • Pie Contest
      Pie Contest
    • Fat Challenge
      Fat Challenge
