Weld Free Electric Longboard
44,389
556
49
About: I am a 20 years old student from Germany who love to make things. Later I want to become an Electrical Engineer :-)
This time, I want to show you how to make a weld free electric longboard.
My mission was to build a very professionell electric longboard at a price of 350-400€. It is very confortable to ride, because it has 97mm wheels. So small rocks don't affect you. Also you have less vibrations when you drive faster compared to smaller wheels.
Specs:
  • Top Speed: 35km/h
  • Battery: 2x 6s 22.2V 5000mAh Lipo
  • Range: 20km
If you like my Instructable, please vote for me in the Make it Move Contest :-)
Update 01.05.2016:
Added Video
### Falls Jemand aus dem Raum Dortmund / Unna / Kamen kommt und auch ein elektrisches Longboard besitzt, wäre es bestimmt nett sich mal zu treffen. Mit mehreren zu fahren macht einfach mehr Spaß :-). Hinterlasst mir hier einfach eine Nachricht ###
Step 1: BOM - Excel-File
I made it simple for you :-).
Here is the complete BOM-Excel file for the weld free electric longboard incl. price list.
You just need to download the attached file and open it with Excel. (German)
Step 2: Fusion 360 Motor Bracket File
If you can't see the interactive 3D model above, its probably because you're not using a WebGL-enabled browser, or you're using the Instructables Mobile app)
I also upload a .f3d file for Fusion360 and a .step file for other CAD programs
Step 3: Prepare the Wood Plates
At first you have to buy two 120x60cm in lenght 4mm thick plywood. Then you cut it in four 120x30cm pieces
Step 4: Stick the Wood Plates Together
Now you stick the four 40x120cm woodplates together. At first you have to make sure that you have enough PVA / wood glue. You need 400ml glue for all plates. Once you have checked that you have enough , you spread a glue layer on the first plate. Make sure that you use enough glue!
After you have spreaded all plates with glue, you have to press the plates together.
Attention when pressing:
You need to build a press form, which forms a concave longboard deck, because only the concave in the deck makes your longboard rigid and flexible at the same time! See at the pictures, how my press form looks like :-)
The deck have to stay at least one (better two or three) day in the form, until the glue is strong enough that it can hold the plates together.
Step 5: Remove the Plates From the Form
Here you can see, how a well glued longboard deck looks like, when it comes out of the form.
It is perfect, when you see some glue at the edges.
Step 6: Cut Out the Typical Longboard Design
For the perfect longboard form, I used some transparent baking paper. For the right size, please look at the pictures. Once you have marked your size on the deck, you can cut it out. For this step I used a jigsaw.
Step 7: Grind the Edges
To remove the sharp edges, I used an electric router. Now I have some very smooth edges. Additionally it is very recommed to sand the complete deck. Later it will give you better results at the painting. I used a 180 corning sand paper.
Step 8: Paint It!
At first, don't forget to sand your deck. This is highly recommend, because it will remove the tiny hair from the wood plates. Once sanded, you paint the deck black. Let it dry for at least one day. After that, you have to apply a thin layer of laquer. Let it also dry for one day. Then sand it again and apply a new layer of laquer. Repeat this step four times that you have 4 layers of laquer on both sides of your longboard deck
Step 9: Attach the Grip Tape
After the laquer is dry enough, you can start to attach the griptape to the longboard deck.
You do that like this:
  1. Glue the griptape to the deck. Make sure that you have no air bubbles under the griptape.
  2. After that, prepare the edges of the deck. I used a file shaft for this step (See pictures)
  3. Then you can cut the unused griptape with a sharp knife.
  4. At last, you open the holes for the axis/battery box
Step 10: Attach the Axis to the Deck
You simply have to screw the axis to the deck, by using the M5x30mm screws
Step 11: Make the Motor Bracket
For this step is it highly recommend to download the attached PDF for the motor bracket. Or even better the CAD file at the top of my instruction :-)
I used a 15mm thick aluminium block for the axis bracket and a 5mm for the motormount.
Required tools:
  • Jigsaw with asawblade for alumnium
  • A drilling machine
  • some files in different sizes
For the work flow, please look at the pictures, drawings and the Fusion360 file.
Step 12: Connect the Motor Mount to the Axis
At first you have to grind the shaft from the axis that you are able to push the axis holder on the axis. Once completed, you have to screw the motorholder to the axis holder. For that step, I used three screws and three self-locking nuts.
Step 13: Connect the Gear to the Wheel
At first a big thanks to buZztiaan from Thingiverse for sharing his awesome 48 tooth longboard gear for flywheels!
For this step you need:
  • 1x Flywheel
  • 1x The 48 tooth gear for HTD5M belt from Thingiverse + retrainer
  • 6x M5 Hex nuts
  • 6x M5 washers
  • 6x M5x70mm screws
See pictures, how to assemble the gear with the wheel :-)
Step 14: Detailed Pictures From the Motor Mount
Step 15: Build the Electronic Box
To protect your electronic against dirt, you should build a box, which you attach under the longboard
Required Parts:
  • 2x 250x70x18mm plywood
  • 1x 145x70x6mm plywood
  • 1x 95x170x1,5mm perforated metal
  • 290x290x2mm aluminium plates
  • Some small wood screws
What you make:
  • At first you cut the 18mm plywood in a 70° angel
  • Then you bend the perforated metal, that it has the same high as the 18mm plywood
  • After that you drill some holes inside the aluminium plate
  • Then you screw the parts together (see pictures)
Step 16: Splint Pin
To guarantee that the box is to 100% closed when you drive, you need to make a splint pin. I bend them by myself out of some stainless steel. The safety Pin is also diy from an old wire.
Step 17: Detailed Pictures From the Box
Step 18: How to Protect Your LIPOs Against Water, Dirt and Vibrations
I attached some foam inside and under the electronic box to protect the Lipos and the ESC against dirt and vibrations. I get my foam from some old packing material.
Step 19: 3D-Printed Wire Channel
This 3D-Printed wire channel is highly recommend for a professionel look.
I print it at a layer hight of 0.2mm out of black PLA
Step 20: Connect the Electronic
Once you completed the box, you have to attach the electronic. For that I used the 9mm plywood inside the box. I drilled some holes, that I could connect the ESC and Receiver with Zipties.
You simply have to connect the ESC and Receiver like in every normal RC-Car.
Make it Move Contest 2016
Second Prize in the
  • Trash to Treasure
    Trash to Treasure
  • Gardening Contest
    Gardening Contest
  • Tape Contest
    Tape Contest
49 Discussions
KoenS1
2 years ago
nice build tutorial! I just started to make my own with very similar components https://youtu.be/yWeLAkTYFoY (build log)
I will try to make the best quality board under 400 $
NathanM189
2 years ago
Any chance you could upload a english version of the supply list? I wouldn't want to get mixed up in the translations and buy the wrong parts.
Longboard1999
2 years ago
Does the esc have a breaking feature or do you have to use your foot to stop
VulcamanLongboard1999
Reply 2 years ago
Yes, the esc has a breaking feature, but the brake is to strong. So I disabled the break and use my foot.
markyoeVulcaman
Reply 2 years ago
Did you have to get an ESC programming card to do that?
Vulcamanmarkyoe
Reply 2 years ago
You don't need a programming card in general. You can programm the esc with your RC transmitter. Only for some advanced features an programming card is necessary. Take a look at ESC specifications :-)
MightyCoCo
2 years ago
Nice project. About your ESC (never had one in my hands) - how did you connect the two Lipo packs to the ESC? Serial, parallel or does the ESC has connectors for two?
VulcamanMightyCoCo
Reply 2 years ago
You connect the two Lipos in parallel, because you want to increase the capacity not the voltage. I simply use two XT60 Connectors and solder them in parallel. (See picture)
spotsizzle
2 years ago
i have a question that i feel quite urgently needs to be answered, cause if its not i wont be able to build this. But is it possible to skip the 'longboard construction' steps andjust apply the other steps to an already owned board?
owatsonspotsizzle
Reply 2 years ago
transmitter and receiver for an RC car
NoamB2
2 years ago
how do i get the 48 tooth longboard gear flywheels? and motoe gear and belt?
can i find it on ebay?
EsaE
2 years ago
Really gorgeous and professional-looking! The box just seems 2x too tall for my taste :( I know it has plenty clearance...but :(
Would be nice if you used Google Docs for the parts list :)
Keep on rollin'!
harold_loop
2 years ago
Looks very professional!
I was just wondering if the motor bracket doesn't come loose from the truck since it only relies on friction?
Logan302
2 years ago
Does the box ever scrape on the ground. Thanks for sharing.
VulcamanLogan302
Reply 2 years ago
The Box didn't scrape the ground, you have 7cm space between ground and deck.
DEDELIE
2 years ago
Bravo Vulcaman !
Bel instructables très bien documenté. C'est un exemple pour tout le monde.
Merci
