Wemos ESP8266 Getting Started Guide With Arduino IDE
65,878
66
10
About: As a young lad Tom spent most of his days at the heels of his father, working in their shop, also known as the basement. His dad was an extraordinary cabinet maker and while working on their 1850’s hom...
This instructable will take you through the basic set up of the WEMOS ESP8266 Board and the Arduino IDE.
Step 1: About the Wemos & What You Need
About:
  1. Wemos D1 Mini:
    • Microcontroller: ESP-8266EX
      • Operating Voltage: 3.3V (chip) 5v (board)
      • Digital I/O Pins: 11
      • Analog Input Pins: 1(Max input: 3.2V)
  2. Mirco USB for power and programming
  3. CH340G Serial to USB chip
  4. The Wemos is better than a normal esp board because you can directly program it.
  5. It can be programmed using little effort, and the Arduino IDE.
  6. There is lots of support for the ESP and the Arduino.
  7. The ESP8266 low-cost Wi-Fi chip with full TCP/IP stack
Links:
  • https://www.wemos.cc/product/d1-mini.html
  • https://www.arduino.cc/
  • https://github.com/esp8266/Arduino.git
What you need:
Step 2: Soldering the Headers
  • The WEMOS board comes with 3 different types of headers.
    1. Female
    2. Male
    3. Female/Male (long female)
  • I use a breadboard to solder these on. It helps keep everything aligned. I find it better that using the helping hands. You do want to be careful because you may melt the plastic of the breadboard if you heat up the pins to much.
  • For the purpose of my project and future projects I am going to use the Female headers. These will allow me to install shields. The WEMOS board has a number of shields and I will be using the Temp and Relay shield in a future build.
  • When Soldering you want to make sure you don't use too much solder, it will result in a ball of solder on your pin. If you use to little solder or not enough heat you can risk no connecting them fully. Take a look at my last picture to see what good solder joint looks like.
Step 3: Download the Arduino IDE
This part is pretty self explanatory and I wont go into how to install a program.
Navigate to the https://www.arduino.cc/ and download the correct IDE for your operating system.
Step 4: Download and Installing the CH340G Drivers (Windows)
The CH340G is a cheap serial to USB programming chip and does not come with native windows or mac drivers. However it has been made very easy to install.
Download and install the drivers through the wemos website: https://www.wemos.cc/product/d1-mini.html
Step 5: Installing the Board on Arduino 1.6X
Version 1.6.4 of the Arduino IDE introduced official support for adding third party boards to the new Board Manager. This addition is great news, because it allows users to quickly add new boards with the click of a button. Previously the addition of new boards required a cumbersome manual installation process, or in certain cases, the download of a completely separate version of the IDE with the new boards added.
  1. Go to the wemos website: https://www.wemos.cc/product/d1-mini.html
  2. OR go direct to github: https://github.com/esp8266/Arduino.git
  3. There you will find these instructions:
    1. Enter http://arduino.esp8266.com/stable/package_esp8266... into Additional Board Manager URLs field. You can add multiple URLs, separating them with commas.
    2. Open Boards Manager from Tools > Board menu and install esp8266 platform (and don't forget to select your ESP8266 board from Tools > Board menu after installation).
  4. Profit.
Step 6: Installing the Libraries
  1. Go to Sketch
  2. Then Included Libraries
  3. Then Library Manager
  4. Search: ESP8266 Microgear
  5. Install the top one (see image)
Step 7: Getting Ready to Upload
  1. To to Tools
  2. Board >
  3. Select Wemos D1...
  4. Make sure you have the correct COM port selected.
Step 8: Uploading the Sketch
To get us started I just uploaded the Blink Sketch.
This sketch is designed to blink the LED onboard the ESP8266. It is the prefect sketch to figure out if you have installed and configured everything properly.
The Sketch will open the new window, click the compile button and watch in the debug windows at the bottom.
Once the compile is down you will see that progress bar of the upload, this will be orange. "loading.......50%" something like that. During this you will also notice that the LED on the WEMOS board will start to blink rapidly, almost to fast to even notice.
Once done the loader will show 100%. The board will restart and start blink once every 2 seconds.
Your Done, Subscribe to my Youtube and Instructables Accounts for part 2,3 and 4
https://www.youtube.com/channel/UC5-KZ_TpZ8_0Ko0xcepuskQ
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    10 Discussions
    matelot2
    Question 9 days ago
    will this work with the wemos D1 R1?
    thanks
    mukeshgupta12
    Question 4 months ago on Step 8
    hello sir
    i have one question in my mind
    i have a code for temperature sensor with esp 8266 12 e. i set this code to take reading every 30 min
    but when i insert this code to esp it take reading every 27-28 min. i cannot understand that where is the error in code or hardware plz tell me. i can share my code also ...thanks
    please reply me
    gctseng
    5 months ago
    Just found this and it worked great. I had spent many hours trying to get a basic grasp of what I could do to even set it up, and I'm so happy to have found this. Hope you use the Wemos on more projects soon.
    mbedgeek
    10 months ago
    Really helpful. Thank you.
    gluckc
    1 year ago
    Looked forward to trying this... went through all the steps. Then realized that I accidentally bought a WEMO D1 mini LITE. I'll go ahead and get the D1 mini, but do you know if the LITE version can be used in the same way? I'm guessing it uses different drivers at least, since it wasn't recognized by the arduino IDE. I'm bummed. Now I have to wait to try again.
    StanislavP9
    1 year ago
    Hello! :) Could you help me with my issue? I've followed your tutorial and encountered this issue:
    In file included from c:\programdata\matlab\supportpackages\r2017b\3p.instrset\arduinoide.instrset\idepkgs\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\algorithm:60:0,
    from C:\ProgramData\MATLAB\SupportPackages\R2017b\3P.instrset\arduinoide.instrset\idepkgs\packages\esp8266\hardware\esp8266\2.4.1\cores\esp8266/Arduino.h:254,
    from sketch\sketch_mar25a.ino.cpp:1:
    c:\programdata\matlab\supportpackages\r2017b\3p.instrset\arduinoide.instrset\idepkgs\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\utility:68:28: fatal error: bits/c++config.h: No such file or directory
    #include <bits/c++config.h>
    compilation terminated.
    Thanks in advance for your reply!
    RaviM72
    1 year ago
    Got me started with Wemos. Thanks :-)
    Lacybad
    1 year ago
    It was a really good help for me :)
