How to #2 - Use LTC3780
10,936
34
16
About: Hi, I'm Nemeen, Electronics Enthusiast! I have seen a huge decline in electronics hobbyist in past few years. I started this channel in order to inspire you to create. Hopefully, you will find something tha...
This is a Buck Boost converter, which is a kind of high efficient power supply module with Constant voltage, constant current, under-voltage protection.
What is Buck Converter ?
It can step down the voltage
What is boost converter ?
It can step up the voltage
And This LTC3780 is Buck boost converter !
If you want to watch the video Click Here
And do check out my channel Click Here
Supplies:
Step 1: What Are These Pots ?
Far right one is for Under voltage protection (VV) and it is mostly used for Solar Charging
What does it mean ?
The device can monitor a DC-DC output voltage and quickly disconnect the power source from the DC-DC input load when an overvoltage condition occurs. A power-OK output signals when the DC-DC input voltage falls below an adjustable threshold.
Center one is for Constant Current ( CC)
What does it mean ?
A constant current is that does not change its intensity with time.
Left one is for Constant Voltage ( CV )
What does it mean ?
Same as CC does not change over time
Step 2: How Much Power Can It Handle ? and Efficiency ?
It depends on the board the one which I have used can handle Up to 130W
But after 80W it needs to increase the Heat Dissipation
And
The sweet spot for the efficiency is 98% at 12V
Step 3: Lets Power It Up !
I had a bunch of LED's soldered in parallel
After powering it up I have to say it worked like charm and I was able to control the voltage and current to change the intensity of the LED's
Step 4: Ending Notes
From where I got mine ?
Gearbest - Click Here
LTC3780 - Click Here
Volt Amp Display - Click Here
Shipping Time ?
It took 2 weeks for me to reach India
Packaging ?
Excellent Static proof bags with bubble wrap in it
Note - In the Next Instructables And video I am going the built a power Supply out of it !
So For updates you can check my Youtube Channel, Facebook And Instagram
Hope you like this Instructables
Happy Making !
    • IoT Challenge
      IoT Challenge
    • Party Challenge
      Party Challenge
    16 Discussions
    JamieC142
    2 years ago
    can i change the current pot whit a 220k ohm pot impart from the 200k pot?
    Nematic!JamieC142
    Reply 2 years ago
    Yes it won't make any difference because it is making voltage difference if doesn't works let me know
    PedroR207Nematic!
    Reply 3 months ago
    hi, i use a 220k potenciometer on the amp and dont work i try a 100k and nothing, the position of lines to potenciometer are correct and potenciometer are good what do you say.
    Pokornz
    Question 9 months ago
    Thank you for the instructable! However, I would like to ask you to remove the part about efficiency since it is a misleading statement. If you take a closer look at the "Efficiency and Power Loss" figure, it says in the subtitle "Vout = 12V". It is true that the plotted curve implies that the greatest efficiency will be achieved when the Vin = 12V, but considering the fact that the input voltage is the same as the output voltage, the circuit is essentially not providing any conversion. That is the reason for the 98% efficiency - the unit is only passing through the same voltage level.
    To conclude, your statement "The sweet spot for the efficiency is 98% at 12V" is true only if the output voltage and input voltage are both 12V, which then defeats the purpose of using the LTC3780 unit.
    Feel free to reply and let me know your thoughts.
    throbscottle
    11 months ago
    Nice useful instructable
    Omar_Kassem90
    1 year ago
    Can i power it up using 24v 5A and if i do wil the output voltage and current be higher?
    JohnathanW15
    1 year ago
    what resistor value on the CC terminals would set it wide open (no current limit) Im trying to save space and the pots are slightly higher than the caps so Im taking them off for a thinner case. I need 24-26v (currently resistors replacing CV are giving 26) and no limit on amperage. The device attached draws 2amps max but im not quite sure how to tell if its limited by the 3780/psu or not as i cant force device to max power and dont have power resistors I wouldnt turn red hot
    Duret-RobertL
    2 years ago
    Hello ! I tried to used one of those for a variable psu however when I tried powering up the board, it wouldn't output anything and the FAULT led was lit.. I powered it up with a 12V playstation3 power supply and tries measuring the output voltage using a voltmeter. Did I do something wrong or was it just a doa board ? Could anyone help me please :)
    danielglenn1234Nematic!
    Reply 1 year ago
    That didn't work for me as I am having the same problem but turning the 3rd pot did nothing
    I eventually figured out the solution which was indeed turning the 3rd pot. However it is a multiturn pot with no locking so you have to try turning it many times in each directions. The FAULT led also turns on if your outputs are directly connected or if the input voltage is too high
    I didn't realise how many times you could turn the pot! I kept turning until the fault led turned off. I wish it would have been mentioned in the video that this was necessary instead of saying we didn't need to touch it but I got it working. Thanks so much for your help!
    kamhagh
    2 years ago
    I have one which outputs stuff correctly. but the OP amp gets TOASTY! I used a tiny heatsink on the op amp (lm358).
    can anyone tell me if their's do that too? because litteraly the second Ibought it I accidentally smashed the circuit with my screw driver while adjusting those annoying pots :D
    sadly the second one I bought had the same thing happen to it. only this time it made a giant spark on constant and now it gives me a constant 2.3v and the ltc3780 heats up very quickly
    AaravM
    2 years ago
    Hi can i power it using a 12 volt2 amp adapter (the tata sky ones)
    Nematic!AaravM
    Reply 2 years ago
    Yes but you won't be able to exceed 24W power I would recommended getting one 12v 5A or 10A smps
    pmondal2Nematic!
    Reply 2 years ago
    Sir can i power it with a atx power supply and can i power it more than 10amp power supply please help me.
