WiFi Kit 32 NTP Clock
About: Retired and still learning.
WiFi Kit 32 NTP Clock is another of my learning forays into the numerous features of the ESP32.
During startup, the clock obtains the current date and time from an ntp server, adjusts for time zones (see the Software step), writes the result to the ESP32 rtc (real time clock), then uses the ESP32 rtc to update the built in OLED display with the date and time.
The source code is included in the Software step and should be documented well enough to explain how it works. If you have any questions, please feel free to comment and I will do my best to answer them.
In the interest of full disclosure, I receive no samples or compensation for the use of this board.
Step 1: Software.
The software requires the include files "time.h", "WiFi.h", "WiFiUdp.h" and "U8g2lib.h", and as such these libraries must be included in the Arduino environment.
The software connects to an ntp time server via wifi and a udp port, obtains the ntp time from the server, adjusts then writes the time to the ESP32 rtc (real time clock), then displays the date and time on the built in OLED display.
Upon startup, the code initializes the serial port, wifi, graphics and udp port. The serial port is used during initialization to display when the wifi is connected and when the ntp time has been received from the ntp server. Wifi is used to communicate with the ntp server. The graphics is used to display the initialization and operational displays on the built in OLED. Finally, the udp port receives the ntp time from the ntp server.
The main loop performs two major functions; obtains the time from the ntp server and to update the oled. The time is obtained from the ntp server only once, and upon receipt, is adjusted for time zone then written into the ESP32 rtc (real time clock), after which wifi is turned off. The OLED is updated once per pass, and there is a 200ms delay in the main loop so the OLED is updated 5 times a second.
Before compiling and downloading the code, adjust the following settings:
1) TIME_ZONE - currently set to -6 for Oklahoma (my home state), adjust to your timezone.
2) chPassword - currently set to "YourWifiPassword", adjust to your wifi password.
3) chSSID - currently set to "YourWifiSsid", adjust to your wifi ssid.
Next, connect the board to a USB port on your computer via a USB to micro USB cable, then compile and download the software. While awaiting the download, start the serial monitor. When the download is complete, the software will send status messages to the serial monitor as shown in the video and, if successful, the OLED will display the date and time.
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest
      Paper Contest
    10 Discussions
    Trev_A
    7 weeks ago on Introduction
    Worked perfectly straight off. Just had to install the olikraus u8g2 lib.
    I found changing the line "strftime(chBuffer, sizeof(chBuffer), "%I:%M:%S", tmPointer);" to "strftime(chBuffer, sizeof(chBuffer), "%H:%M:%S", tmPointer);" gave me 24 hour display format instead of 12 hour.
    Really great for trying my first EP32 program. Thank you
    gzumwaltTrev_A
    Reply 7 weeks ago
    Congratulations! Great work on converting the time to 24 hours!
    Greg
    JensH29
    6 months ago
    sorry, I have to correct the nonsense I wrote regarding a locate() function, which doesn't exist. In fact, none of any locale.h which I found for Arduino offered a working 'setlocale (LC_TIME, "de_DE", ...)' function
    JensH29
    6 months ago on Step 1
    Hi Greg,
    with your code, I did my very first step into arduino programming and finally succeeded in adopting it to display with German wording for the days and months. It was a bit complicated, because the locate() function doesn't work for Arduino.
    Python's and Java's handling of string variables is much easier...
    If you're interested, just write a note to j811195 at hotmail dot com.
    rruggiero
    10 months ago
    This is a great instructable but, can you tell me which library the required include files are supplied with?
    gzumwaltrruggiero
    Reply 10 months ago
    The libraries have the same names as the ".h" files, thus you will need to add "time.lib", "WiFi.hlib, "WiFiUdp.lib" and "U8g2lib.lib" to your sketch. On a Mac, these libraries are located in "Documents/Arduino/libraries".
    Hope this helps!
    Greg
    SESupply
    10 months ago
    Works perfectly - seems like a very useful little device!
    gzumwaltSESupply
    Reply 10 months ago
    I’ve had a lot of fun using this board, good price also.
    enaidoo
    11 months ago
    Great. worked perfectly first time. Thanks a lot.
    gzumwaltenaidoo
    Reply 11 months ago
    Congratulations, great work!
    Greg
