Winter Fire Cider
15,184
336
19
It's hard to turn down something immune boosting, circulation encouraging, antibacterial and viral, that also clears your sinuses, even if it's got a taste that takes some getting used to. Fire Cider is just that--a hot, bitter, sweet and easy DIY home remedy to fight off the pesky cold and flu season and promote wellness year-round. Fire Cider is apple cider vinegar that has been infused with a variety of spices, herbs, and fruits so naturally it lends itself to variation and experimentation. In this Instructable, I'll walk you through a basic Fire Cider recipe but feel free to explore, substitute, or add to your ingredients for flavor or wellness benefits.
So raise a teaspoon and here's to wellness this cold and flu season!
NOTE: This Instructable is not a treatment or cure-all and should not be taken instead of the advice of any medical or health professional. This is simply at at home recipe to boost wellness, not cure ailments.
Step 1: Ingredients
There are many varieties of fire cider. The list of ingredients below is for a blend that I've come to enjoy in a fire cider. You are more than welcome to play with quantities or ingredients yourself--let me know how they turn out!
Things you'll need:
  • Apple Cider Vinegar
  • 1 Whole Lemon
  • 2 Oranges
  • Fresh Ginger (1/4 cup chopped)
  • Fresh Turmeric (1/4 cup chopped)
  • Fresh Horseradish (1/4 cup chopped)
  • 4 Garlic Cloves Chopped
  • 1 Jalapeno
  • 1 Full Onion
  • 1 Head of Parsley
  • 3 Sprigs of Thyme
  • 2 Sprigs of Oregano
  • 2 Sprigs of Rosemary
  • 2 Teaspoons of Cinnamon
  • Honey to Taste
Equipment:
  • Glass Jar
  • Wax Paper
  • Cheesecloth
Other Optional Ingredients:
  • Cayenne Pepper
  • Chili Powder
  • Mustard Seed
  • Elderflower
  • Basil
  • Dill
  • Peppercorns
  • Habanero
Step 2: Onions & Garlic
Coarsely chop your onions and garlic cloves. You want to chop your onion and garlic fine enough that the vinegar can seep into them but coarse enough so that when you strain the fire cider in the final step you aren't left with any chunks.
Once chopped, add your garlic and onions to a clean dry jar.
Onions can act as a cough reliever and anti-inflammatory agent.
Garlic is full of antioxidants which can help to ward off free radicals that can contribute to heart disease, cancer and Alzheimers. It is also thought that garlic helps to prevent the common cold.
Step 3: At the Root of Things
Time for you roots. Peel the skins off of your turmeric, horseradish, and ginger. Coarsely chop your roots until you have equal amounts of all three of them. Place your freshly chopped roots into your glass jar on top of your onions and garlic.
Turmeric has been used for thousands of years as both an antioxidant and natural remedy for inflammation, bad digestion, diseases of the skin, liver problems and wounds.
Horseradish is believed to be advantageous to digestion, respiratory conditions, lowering blood pressure, and strengthen bones. It is also believed to be an anticancer root because of it's high levels of glucosinolates.
Ginger is useful in fighting flu or cold symptoms. It has also been used to treat menstrual cramps, headaches, and nausea.
Step 4: Greens
Coarsely chop your parsley and add it to your jar. Next, strip the leaves from your oregano and thyme. Combine your stripped leaves with your rosemary and chop all of the herbs together. Add your chopped herbs on top of your parsley.
Parsley is high in vitamin C and antioxidants. It is also believed to be anti-inflammatory.
Thyme has antibacterial properties as well as the ability to suppress coughs and clear mucus.
Rosemary has been shown to relieve muscle pain and spasm as well as promote healthy circulatory and nervous systems.
Step 5: Good Old Vitamin C
Quarter one and a half of your oranges and the entire lemon. Once quartered slice each citrus until you have a selection of uniform wedges, each about a quart of an inch thick. Drop your wedges into your jar, pushing them down with your finger if necessary.
Juice the remaining half of an orange into your fire cider jar. This will add a bit of sweetness to your otherwise acidy and bitter cider.
Step 6: Spice It Up
Chop your jalapeno into slices and place it in the jar. Add your cinnamon. You're almost done!
Cinnamon has been used in home and natural health remedies for generations. It is thought to help reduce inflammation, aid in digestion, curb appetite, and help with painful menstruation.
Step 7: Top It Off
Shake your Apple Cider Vinegar. Pour the vinegar into your jar until all of your health boosting ingredients are covered. Give your jar a good gentle shake to release any air bubbles.
Step 8: Seal and Store
Cover your jar with a square of wax paper. The wax paper prevents the vinegar from corroding the metal lid. You can also substitute a silicone or plastic lid if you have one. Otherwise wax paper works great!
Screw your lid on tightly and store your fire cider in a cool temperature controlled place like your refrigerator for 3-4 weeks. Try to shake it daily, or as often as you can remember to.
Step 9: Straining
Place two squares of cheesecloth over the mouth of your jar. Pull tight and secure your cheesecloth with a rubber band. The cheesecloth will act as a barrier, allowing your to collect your fire cider without any of the chunks.
Pour your infused vinegar into a separate clean jar to store for use later. Seal tightly.
Step 10: Done!
You're done. Feel free to add honey to taste. I generally like to leave the honey out and simply add it to whatever I am consuming with the fire cider if I need it a little sweeter.
Step 11: Use Fire Cider
Fire Cider is a wonderful addition to many things, especially since it can boost your health and ward off cold and flu season. I generally add it to tea with a teaspoon of local honey, but try any of these variations or share your own:
  • Mix with Orange Juice
  • Use in Salad Dressings
  • Add to Soup or Chili
  • Add to Tea with Honey
  • Spritz over veggies
  • Add to a Meat Marinade
  • Shoot it straight!
    • Arduino Contest 2019
    • Classroom Science Contest
    • Gardening Contest
      Gardening Contest
    19 Discussions
    Mjtrinihobby
    2 years ago
    Very well done. I love the documentation.
    kelleymariearnoldmelton
    Reply 3 years ago
    Hi arnoldmelton! It can last up to a year refrigerated. I've also heard that it can be stable outside of the refrigerator, but having not tried it I am hesitant to say so!
    Marcos_El_Malokelleymarie
    Reply 3 years ago
    As I mentioned in another comment, vinnegar has a long shelf life by itself. It's the other components that will affect this. I suspect that the honey (which also has a long shelf life on its own) might ferment at some point, if other bacterial processes don't take hold first.
    MipyMarcos_El_Malo
    Reply 2 years ago
    honey never goes off, honey has been found in ancient Egyptian tombs that is still edible. The honey and vinegar don't go off quickly but the other stuff does.
    artenlorMipy
    Reply 2 years ago
    Yes but when mixed with other things honey can go bad, I would not mix them together unless I was going to use it immediatly.
    puggirl415
    3 years ago
    I just made this a couple weeks ago. We used horseradish and didn't use the citrus or the greens. I like your additions. I'm also making it without honey and then adding honey to some of the decanted mixture and some will stay plain. I think it would make a good addition to salad dressing. The other ritual is to bury the jars on a full moon and then dig it up on the next full moon. We buried the night before Thanksgiving and will dig up on Christmas night this year. Delicious.
    JohnBradley79
    3 years ago
    This is very nice!
    I`ll definitely make my own version of this.
    discourius
    3 years ago
    A coworker made a version of this and left it at the office unrefrigerated. He consumed it regularly throughout the winter, but then forgot about it. I believe around April it began to look unsanitary and encouraged him to pitch it.
    Marcos_El_Malodiscourius
    Reply 3 years ago
    Vinnegar has a good shelf life without refrigeration, but I would suppose that it becomes compromised when you add ingredients, especially sugar.
    2012Viking
    3 years ago
    I wonder if you would get the same benefits if you put everything through a good juicer (or something like a vitamixer) then add the vinegar? If you did that it might be ready immediately.
    densad
    3 years ago
    I want to try this, but I wonder how it will be if you substitute vinegar for vodka or calvados brandy.
    kelleymariedensad
    Reply 3 years ago
    More of an infused liquor then? What about just adding the Fire Cider to a cocktail?
    densadkelleymarie
    Reply 3 years ago
    My step-dad is a big fan of infused liquors, that's why I ask, but a cocktail sounds nice.
