DIY Wire & Seed-Bead Bracelet
13,464
198
17
About: Hey, I'm Muhaimina! A crazy craft addict! Obsessed with swirls and polka dots... Love green craft and rustic home decors... and Instructables is pretty much my second home!
There's nothing much to say... I was in class, doodling and randomly came up with the idea of making this bracelet. I made the bracelet in my head (like I always do!) and made 1 as soon as I came home. It was so easy to make, turned out pretty nice so I had to share the tutorial.
Anyways, grab the materials and go make one, it won't take much time and you'll love it :)
Step 1: Materials Needed
To make this bracelet you'll need:
  1. Craft wire - 18 gauge,
  2. Jewelry pliers,
  3. Seed bead (color of your choice),
  4. Ruler or anything to measure ,
  5. Round object that fits your bracelet size.
Step 2: Making Wire Coils
Hold the wire from an end without cutting it from the bundle,
Use the looping plier to make wire coils, make sure to make neat wire coils.
The wire coils I made were 3 cm long.
You will need 6 wire coils for each bracelet.
After making the wire coils bend them slightly to give them a round shape so that they can fit into the bracelet.
Step 3: Making the Bracelet
Measure your bracelet size (lengthwise) and add half an inch extra. Mine was 6 inches so I had to cut 6.5 inches long wire.
Use the looping plier to make a small loop at any end of the wire,
Carefully wrap the wire around a round object that fits your bracelet size. I used my hair spray bottle.
Keep the other end open for now.
Step 4: Beading the Bracelet
First insert a wire coil into the wire bracelet, through the open end,
Now insert seed beads and stop beading once the beads reach near the center,
Insert another wire coil and then repeat the previous steps,
Keep 1.5 cm intact at the end, you will need to make another loop for closing.
Make 1 more bracelet similarly.
Step 5: Attaching Bracelets
Make 2 jump rings,
Place the 2 bracelets one over another, matching their loops on both ends,
Attach the jump rings with the loops on both ends to join the 2 bracelets together.
Step 6: Closure
Cut a small piece of wire (8 cm),
Bend the wire into half and use flat nose plier to tighten the bend,
Use looping plier to bend the wire again to create a hook-like pattern,
Again, use the looping plier to create a loop on the other end,
Simply attach the hook with the bracelet through the jump ring on any one side.
You can add extra jump rings or chains for adjusting the size of the bracelet.
Done! I hope you enjoyed the tutorial and please share pictures if you make one :)
    • Paper Contest
      Paper Contest
    • Pie Contest
      Pie Contest
    • Weaving Challenge
      Weaving Challenge
    17 Discussions
    audrey5775
    3 years ago
    Love it, it is so cute. My friends and I love to bead.
    This has been one of the best projects to follow with the instructions so clear and straight forward thank you for sharing i have made all different colours as it was a great way to use up left over wire from other projects. my family have been given them for easter gifts. Thank you for the insperation.
    doniseg
    4 years ago on Introduction
    this is a darling craft and idea thank you so very much for sharing your kindness and love god bless you so much love donise grace amen feb 22,2015
    Gilly
    This is really attractive and inspirational - can't wait to have a go. What gauge wire did you use for the bracelet part?
    Muhaiminah FaizGilly
    Reply 4 years ago on Introduction
    Thank you so much! Share a picture if you make one :) I used 18 gauge wire but you can also use 20 gauge.
    GillyMuhaiminah Faiz
    Thank you - I will try to get the wire and if my bracelet works out well, I will definitely post a picture. It may take me several goes to get it right!
    Gilly
    Oh and thanks for sharing your idea by the way.
    pan367
    4 years ago on Step 6
    great job !! I think I have all the supplies I think I'll try it
    shazni
    Lovely! One suggestion though. Rather than bend the coils. First fill up the straight wire which you use for the bracelet ( after you make the first coil) with the beads and coil. Then wrap it around a round object to get the rounded shape. That's how I do it and I find it easier and then the coils would have the perfect bend :-)
    Muhaiminah Faizshazni
    Thanks you sooo much Shazni! I'll surely keep that in mind next time :D Thanks again for the suggestion!
