Wire Tree
8,468
213
5
About: I Love Making Awesome Stuff
Decorate home tablets with this wire tree.
Materials
  1. Copper Wire 60 Metre (20 Gauge)
  2. Wire Cutter
  3. Nose Pliers
  4. Wood Piece
  5. Drill Power Tool
  6. Measuring Tape
  7. Marker
Supplies:
Step 1: Setup
  1. Measure 18 inches of wire and cut it.
  2. By doing the same cut all the wire.
  3. Now you have a bunch of 18 inches wires.
Step 2: Making the Base
  1. Take a piece of wood, mark 8 points on it like shown in picture.
  2. Now the calculation part comes.
    1. Divide the total number of wires on 8. In my case 114/8 = 14.
    2. Now make a 8 clusters of wires each containing 14 wires.
    3. Analyse the thickness of cluster and select the drill bit according to the thickness of cluster.
  3. Make hole on that points with drill machine.
  4. And pass each cluster through these hole (1 inch).
  5. Bend these wires so they can't pull back out.
Step 3: Making the Trunk and Branches
  1. Grab the wood with left hand and wire with right hand and twist it. Use Pliers if needed.
  2. Split the wires to make the main branches and twist them too.
  3. Again split for some small branches.
  4. By doing the same make more branches as much you like. But remember one thing leave minimum 3 inches from the top of every branch to make leaves.
Step 4: Making the Leaves
  1. Open the wires if it bends from top of branches.
  2. Grab one wire with nose pliers at the top (Leaving the half cm) then twist your wrist to right, again hold this wire a little below and twist your wrist to left. Do it till the end of wire.
  3. Now the wire have some zic zac shape.(See in picture)
  4. Make all wire shape like this in the same branch.
  5. Now roll them or press them to compress.
  6. Do it for all the other all branches.
Step 5: See How This Tree Was Made (Video)
6 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • IoT Challenge
    IoT Challenge
  • Fandom Contest
    Fandom Contest
5 Discussions
Frostsmaker
1 year ago
I know that something like this exist. But, I've gotta to say that you are really good. I mean someone really did it. Good Job. Nice Idea. Now, I just need electricity in it.
Awesome CraftsFrostsmaker
Reply 1 year ago
Compliment like this motivate me to make some more good stuff. Thanks a lot!
FrostsmakerFrostsmaker
Reply 1 year ago
I mean have got to. (gotta is wrong part on there. I'm sorry).
mrsmerwin
1 year ago
It looks incredible.
How did you work the root structure? Did you remove the wood block or add additional wire? How did you embed the tree in the base so it looks like a beautiful little bonsai tree?
Awesome Craftsmrsmerwin
Reply 1 year ago
Thanks a lot mrsmerwin. Oops I forget to mention. I have just make the wires straight which were bend under the wood and pull them to seprate it from the wood. Further, please see from the 4th step of given below instructables.
https://www.instructables.com/id/Wire-Bonsai-Tree/
