DIY Bead Stud Earrings
58,293
214
18
About: Hey, I'm Muhaimina! A crazy craft addict! Obsessed with swirls and polka dots... Love green craft and rustic home decors... and Instructables is pretty much my second home!
I love to collect beads, all kinds and colors ^_^ I always wanted to make bead studs, I don't know why this idea of making bead stud earrings didn't pop in my head before!
Have cute, colorful beads and craft wire? great! you can make these stud earrings in only 5 minutes :)
Lets start!
Supplies:
Step 1: Materials Needed
To make these stud earrings you'll need:
  1. Craft wire,
  2. Craft pliers - flat nose and cutting pliers,
  3. Pearl beads or any kind of beads (you'll need a pair of beads as we're going to make earrings).
Step 2: Wrapping the Bead
First of all measure the size of the bead, and keep that in mind.
Hold the wire from an end, do not cut it from the bundle,
Use the flat nose plier to bend the wire into 90 degrees, according to the bead size. I used 8 mm pearl bead so I had to bend 8 mm wire to 90 degrees.
Now carefully wrap the bead 2-3 times with the wire,
I wrapped the wire 3 times around the bead and kept the wire flat while wrapping but you can wrap over and over again if you want a thicker border around the bead.
Step 3: Making the Stem
Done wrapping the bead? now to make the stem of the earring.
Bend the wire downwards from where the wrap ends, see the first and second picture of this step,
Now use the flat nose plier to make another 90 degree (or more) bend on the wire on the center of the bead,
Keep 2 cm of the bent wire straight for the stem and cut the wire from the bundle.
Stud earring complete!
Step 4: Making Ear-stud Backs
I used an eraser or rubber to make the earring backs.
Use x-acto knife to cut the eraser into small square pieces.
Carefully push and screw the stem of the ear stud on the small eraser pieces to create a hole on it. There, you have backs for the earrings.
I made 9 pairs of bead stud earrings in 30 minutes! Since mothers day is coming, these stud earrings can be great as gift ^_^ my mom loves to wear pearl bead stud earrings and I'm super excited to give these studs to her as mothers day gift :)
Enjoy!
    • IoT Challenge
      IoT Challenge
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    18 Discussions
    kgomathi4
    3 years ago
    Awesome & neat finish.. Can u pls tell me the exact size of the craft wire?? Thanks in adv..
    AWSM
    5 years ago
    Dea
    AWSM
    5 years ago
    Sbshstzffhxgdy
    14 12:32 PM.jpg
    Very Cute :). The way you shoot your main picture always gets me to say without seeing who posted it "Oh it's Muhaiminah's ible"
    Abigail02
    5 years ago
    Oh these are so cute! You did a great job!
    土豆
    5 years ago
    做的不错,
