Wireless Car Parking Alarm
29,154
377
30
About: I am Saiyam, currently studying in 12th standard and soon going to complete high school. I like to make random DIY projects whenever free. I like learning stuff more than studying and cramming up things! You...
Are you or your wife/kids have just learned driving a car and are afraid of getting an ugly dent on it while parking it? Don't worry, this project is just for you!! The topic already tells much about the project but still telling, it is a wireless car parking alarm that consists of two arduinos connected wirelessly through rf modulation. The transmitter is present at the back of your car that detects the distance between your car and an obstacle. The distance is transmitted and received by the receiver present inside your car that gives you a beep signal. The rate of beeping determines the distance. Faster beeping means that your car is nearer to an obstacle and it can just bang on it if you don't stop your car.
As already told, the project consists of arduinos both in the transmitter and receiver linked through RF (radio frequency) transmitter and receiver modules. The distance is calculated using an ultrasonic distance sensor that can sense for upto 500cm. Both of them are powered using a 9v battery which makes them portable however the transmitter can be made smaller, hidden and can be powered using your car's 12v power supply if you want to make it permanent. The project is not very difficult to make and can be easily completed within 3-4 hours. I didn't add photos of it mounted on my car as it is not present most of the time.
The following are the beep rates of the receiver depending on the distance (in cm):
  1. >200 ---- No beeping
  2. <=200 and >150 ---- Beeping every 3 seconds
  3. <=150 and >100 ---- Beeping every 2 seconds
  4. <=100 and >50 ---- Beeping every 1 second
  5. <=50 and >20 ---- Beeping every 0.5 second
  6. <=20 ---- Buzzer remains on
If you have any doubt related to this instructable or found an error, please post it in the comment section below.
Please vote for me in the contests by clicking the orange icon on the top right corner of the page if you like this instructable.
Supplies:
Step 1: Parts and Tools
The following parts and tools are required to make this project. The total cost of the project was around $20 or 1200 INR.
PARTS:
Transmitter:
Receiver:
Common:
TOOLS:
  • Soldering iron
  • Soldering wire
  • Hot glue gun w/glue sticks
  • Wire cutter/stripper
  • Pliers
Step 2: Prep Your Enclosures
The first step is to prepare your enclosure and to make holes for all the parts. For the type of enclosure, you can use any small wooden or metal box but the best option can be to use a plastic one. Before selecting the size, make sure that all the components fit in easily.
For the transmitter enclosure, make holes each for ultrasonic sensor, LED and switch.
For the receiver, make holes for buzzer, dual LED, power indicator LED and switch.
Step 3: Making the Receiver: Make a Shield for Arduino
This is the first step to make the receiver. To work with your pro mini and to connect your components easily, it is necessary to make a shield for your arduino. This is a much better option than soldering your pro mini to the project which makes ir difficult to remove it later or do any modifications.
Make a shield by soldering some female headers and then some male ones corresponding to each to of the female ones. Then connect all the male headers to their corresponding female ones. Check if your arduino fits in easily.
Step 4: Making the Transmitter: Make a Power Supply for Arduino
Since your pro mini requires regulated 5v to operate (some require 3.3v as well), you need to make a power supply that would convert the 9v supplied from the battery to safer 5v to operate the arduino.
Refer to the schematic above and solder everything according to it. The circuit uses a 7805 low cost voltage regulator with a couple of filter capacitors.
Step 5: Making the Transmitter: Connect the RF Receiver Module
RF receiver module is has a very important role here, that is to receive signals from the other arduino connected to the ultrasonic sensor and transmitter. In other words, it provides a wireless interface between two arduinos along with the transmitter module. Connect it according to the following:
  1. Pins 2,3,8 when seen from the front ---- Arduino gnd
  2. Pins 4,5 ---- Arduino 5v or Vcc
  3. Pin 7 ---- Arduino digital pin 10
Step 6: Making the Transmitter: Connect the Buzzer and LED
Connect the buzzer and LED by following the text below. The role of buzzer here is to beep whenever your car gets near to an obstacle. The rate of beeping increases as it gets nearer. The LED flashes along with the buzzer in red or green color.
Buzzer:
  1. Posisitve terminal ---- Arduino digital pin 13
  2. Negative terminal ---- Arduino gnd
LED:
  1. Negative terminal ---- Arduino gnd
  2. Green ---- Arduino digital pin 12
  3. Red ---- Arduino digital pin 11
Step 7: Making the Transmitter: Connect the Battery, Switch and Power Indicator LED
This part will supply power to the arduino. A switch is added to eliminate the need to remove the battery again and again for switching your arduino on and off. The role of LED is to tell you that the transmitter is on so you don't leave in on overnight. Connect them following the text given below or the schematic.
Battery:
  1. Positive terminal ---- Terminal 1 of switch
  2. Negative terminal ---- Arduino gnd connected to pin 2 of 7805
Switch:
  1. Terminal 1 ---- Positive terminal of battery
  2. Terminal 2 ---- Pin 1 of 7805
  3. Terminal 3 ---- Not connected
Power Indicator:
  1. Positive terminal ---- Arduino Vcc
Connect Pin 3 of power supply to arduino vcc
Step 8: Upload the Code to the Receiver
After doing the electronics stuff, you need to upload the code to your arduino that will tell it what to do when. Since your pro mini does not have an internal programmer, we should have an external one to upload the code. We will be using the nano's programmer (or uno) however there are many options including an FTDI board and RS232. First you need to upload the ISP sketch that will tell your nano to act as a programmer. Do it according to the following steps:
  1. Connect your nano to your pc with a USB cable.
  2. In the ide, make sure that boards and serial ports are all correct (Board should be nano at this point)
  3. In examples, open ISP sketch and upload it to your nano.
Then you should connect your pro mini to nano/uno in the following way:
  1. 5v of nano/uno ---- Vcc of pro mini
  2. Gnd of nano ---- Gnd of pro mini
  3. Digital pin 13 of nano ---- D13 of pro mini
  4. Digital pin 12 of nano ---- D12 of pro mini
  5. Digital pin 11 of nano ---- D11 of pro mini
  6. Digital pin 10 of nano ---- Reset of pro mini
Then refer to the following steps to upload the code to your pro mini:
  1. Change your board in tools>boards to pro mini (or nano also works for me)
  2. Change the programmer in tools>programmer to Arduino as ISP.
  3. Upload the code given below by going to file>'upload using programmer' (NOT upload)
Step 9: Making the Transmitter: Make a Shield for Arduino
So now here we start by making the transmitter that will transmit the distance calculated by it to the receiver. The first step to make it is to make a shield for arduino like it was done earlier for pro mini.
Follow the same steps as was done earlier but use 15 headers on one side in this case.
Step 10: Making the Transmitter: Connect the Ultrasonic Tester
The ultrasonic sensor acts as the most important component here which calculates the distance between you car and obstacle then sends it to arduino for processing. Connect it following the text below.
  1. Vcc ---- Arduino 5v
  2. Gnd ---- Arduino gnd
  3. Trigger ---- Arduino digital pin 11
  4. Echo ---- Arduino digital pin 12
Step 11: Making the Transmitter: Connect the RF Transmitter Module
Connect the RF transmitter module that will send the signals to the receiver wirelessly by following the text given below.
  3. Data ---- Arduino digital pin 10
Step 12: Making the Transmitter: Connect the Battery, Switch and Power Indicator LED
Like the receiver, I have also added a switch and a power indicator here. Follow the text below to connect them. Since there is an inbuilt voltage regulator on your nano, there is no need to make a power supply and it can be directly powered with a 9v battery.
Battery:
Switch:
  2. Terminal 2 ---- Arduino Vcc
  3. Terminal 3 ---- Unconnected
Power Indicator:
  1. Positive terminal with a 1K resistor ---- Arduino 5v
Step 13: Upload the Code to the Transmitter
Upload the code given below in the ino file to your nano. Since it already has a programmer so you don't need any external components.
Step 14: Add an Antenna to Both of Them (Optional)
The range of your transmitter and receiver is around 100m. Adding an antenna can increase the range by around 100m which will make it 200m however this is not necessary.
For connecting your antenna, locate a pin named ANT on your transmitter and receiver module then solder a jumper wire with length 10-15cm to the ANT pin. You can roll the antenna like a coil to make it look small.
Step 15: You're Done!
So you're finally done making your own car parking alarm system! Mount the transmitter at the back of your can and receiver on your dashboard or you can just keep it with you. Now will lose the fear of adding an ugly dent on your car while parking it.
The project can be extended even more to make a car theft alarm and parking alarm with 3 sensors which will make it more effective. Or you can even add bluetooth or WiFi to get the distance on your phone.
This brings this instructable to an end. Hope you liked it. Do post the pictures of your project if you've made one yourself or did any modifications. Feel free to comment or ask a question.
Please vote for me in the contests if you like this instructable.
Thanks for watching :)
Car and Motorcycle Contest
First Prize in the
Safety Challenge
Runner Up in the
Safety Challenge
    • Classroom Science Contest
    • Arduino Contest 2019
    30 Discussions
    SorosN
    1 year ago
    I try this but not work.
    Question i see in Sketch TX file transmit_pin=12 but in circuit is pin 10,
    Pin 12 in circuit is Echo pin.
    Thanks
    SaiyamSorosN
    Reply 1 year ago
    Okay there must have been some mistake. change the transmit pin to 10 in the code.
    Thanks for pointing it out!
    anthonysaide
    2 years ago
    please can someone help me with the code?
    diy_bloke
    3 years ago on Step 15
    Looks great but what is the added value of making this wireless at expense of a second arduino? If you let the Arduino with the US distance meter trigger a buzzer sure that would be heard in the entire car (unless it is a stretch limo).
    Getting the distance on yr phone seems nice, but In parking the car better watch the cars around you than watch your phone.
    I do apologize as I do not want to sound critical. I am known for building many over the top projects myself :-) but in this case I'd say: just let the first Arduino do the beeping.
    Of course if you make it part of a security system, there is use for a receiver, but you don't want to get a warning every time someone parks behind you: a vibration sensor would be more suitable. Make the signalling such that the transmitting arduino reads the distance sensor as long as the engine is running and the vibration sensor as long as the engine is off.
    Mind you though that even a small current over a few days can empty your car battery.
    Perhaps give it its own rechargeable battery and (and now I am going over the top again :-) ) a solar cell to charge it while the engine is off.
    regardless... well done
    Saiyamdiy_bloke
    Reply 3 years ago
    Thank you for such an informative comment
    Actually the point was that you should be easily able to hear the beeping sitting inside your car so that it won't crash. You don't need to look at the receiver but just hear the sound. Adding a beeper outside can be a problem when you won't be able to hear the sound of beeping But still I would say that you have said correctly.
    Your idea of adding a solar panel and switching it on along with the engine is great! Thank you for such a useful modification :)
    anthonysaideSaiyam
    Reply 2 years ago
    UlyssesL
    3 years ago on Introduction
    might help to put glue to secure connectors or to directly solder connections since the vibration of the vehicle might cause unreliable connection.
    SaiyamUlyssesL
    Reply 3 years ago
    Good point, I will surely do that.
    Xabier_556
    3 years ago
    I made a similar project to this. I put the ultrasonic sensor in the back of my garage for when I'm pulling in. Instead of the radio and beeping sounds I wired an RGB led in a spot in the garage where I could easily see it from my car. When I get close the RGB light turns yellow then red when I'm at the perfect calibrated distance.
    Now my car is parked in the perfect spot every time.
    PinakiG
    Only problem I found that the sensor can't be used in a rainy environment. If you have any idea to make this stuff water resistant please discuss it. Thanks.
    SaiyamPinakiG
    Reply 3 years ago
    The box can be easily made water resistant but if you cover the ultrasonic sensor with some thing, it would interfere with the transmission of ultrasonic waves thus the sensor would not work.
    So overall it can be a difficult job.
    baudeagle
    Great idea, can the transmitter be adapted to the RF to a frequency that the car radio could pick up?
    Bobmonkey07baudeagle
    Reply 3 years ago on Introduction
    Probably not directly, but if you can get it to regular 3.5mm, you could use an FM transmitter.
    SaiyamBobmonkey07
    Reply 3 years ago
    Yup, that can be done but one should not forget that use of such transmitters is illegal in some places as @Athul Krishna said.
