Wireless Charger for Any Mobile || Easy || Simple || BD135
4,470
38
13
About: i believe to help people and share my knowledge i always want to build creative thing some of them for learning and some of them is very useful.
. Please SUBSCRIBE to my YouTube channel... ? ? ? ? ?
This project is about to build wireless charger that based on mutual induction.
Supplies:
Step 1: Requirements
  • 1nf capacitor
  • 470pf cap.
  • 224nf cap.
  • 4.7nf cap.
  • 100pf cap.
  • 10k resistor
  • Bd135 transistor
  • Breadboard
  • 10mm led
  • Mobile charging pin
  • Some wires
  • 4 diode 1N4007
Step 2: Build Transmitter Coil
  • Put a tape on hard surface, make sure the sticky surface of tape is on top.
  • Take a wire and make loops on the tape.
  • Open the wire terminal after 8 loop that is tapping of coil.
  • You can see the A, B and C terminal on coil.
  • A and C is outer terminal of coil and B is tapping.
Step 3: Build Receiving Coil
  • Take a thin wire.
  • Make 24 loop of the wire.
  • Make bridge rectifier form diode.
  • Connect ends of coil at input of rectifier.
  • Connect a Led at output of rectifier.
Step 4: Circuit Diagram
Here is circuit diagram of Transmitter and receiving coil.
Let's make it on Breadboard.
Step 5: Breadboard Connections
  • Put BD135 in Breadboard as in picture.
  • Connect 10k resistor in between base and free terminal on Breadboard.
  • Connect 1nf capacitor parallel to resistor.
  • Connect 4.7nf capacitor in between collector and free terminal.
  • Connect 470pf capacitor in between emitter and base.
  • Connect 100pf capacitor in between emitter and another free terminal.
  • Connect A terminal of Transmitter coil to resistor.
  • Connect B terminal of Transmitter coil to 100pf capacitor
  • Connect C terminal of Transmitter coil to collector.
  • Take power source and connect positive terminal to B terminal of coil and negative to emitter.
Step 6: Test the Circuit
Connect circuit via power source
Put receiving coil on Transmitter coil then LED will glow.
Once LED glow now we have to connect charging pin.
Step 7: Connect Charging Pin
Once led glows then remove it...
Remove extra wire on bridge rectifier.
Connect a 220pf capacitor to the output terminal of rectifier.
Connect a charging pin to the output terminal of rectifier.
Step 8: Packaging
Cover receiving coil via white paper. It looks better
Put Transmitter coil on a round box and cover it via white paper.
Cool all done..
Step 9: All Done
The voltage is sufficient at receiving coil but the current is not sufficient do your mobile it indicates it charging but actually it is not charging....
This is better for school and college projects to understand the concept of wireless charging as well as concept of mutual induction.
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    • IoT Challenge
      IoT Challenge
    13 Discussions
    vishalsoniindiaTekno deha
    Answer 20 days ago
    the power is 5V you can supply from any source ,in my case i have used 5 volt adapter
    Tekno deha
    Tip 3 months ago
    please answer my question
    alby21europa
    1 year ago
    You can build a silicone cover and put in side all composant......
    vishalsoniindiaalby21europa
    Reply 1 year ago
    Ya you are right it is perfect for those Mobile that haven't inbuilt wireless charger.
    Niranjan_Niru
    1 year ago
    what is the current drawn from the receiver circuit, if am not wrong it wont draw much current , the circuit is good enough to power a led , with the same circuit it takes a day to charge your mobile fully
    Ya, you are right... I have already said in video and instructions that current is not sufficient...
    mac11380.
    1 year ago
    No offense, but it is not wireless if you have to plug it in.
    Cool project though
    vishalsoniindiamac11380.
    Reply 1 year ago
    Ya, but if you insert the receiving coil into the mobile then it would be wireless.
    I don't want to damage my mobile so I haven't discussed this.
