Wood Bending Steam Box
5,211
119
6
For a commissioned sculpture I needed to bend some lengths of pine in a 90 degree arc. To do that I researched both kerf bending and steam bending and ultimately settled on steam bending. Now I had to figure out how to make a box that could stand up to a few weeks of solid use. After a few tutorials I settled on the following design.
**Full disclosure -- I had fully made and used the steam box when a friend told me about the awesomeness that is Instructables.com so I had to unassemble and photograph the process. This is why certain parts of the wood is already stained and why I can't go back further in the progress as I wood glued parts together.**
Step 1: Ingredients
4 - 14" x 60" pieces of plywood. (I used 1/4" but whatever you have on hand will do.)
2 - 14" x 14" pieces of plywood.
4 - 1" x 2" x 60" pieces of wood.
1 - pack of R13 insulation.
8 - 2" x 4" x 3.75" pieces of wood
1 - 6" x 60" piece of stove pipe
1 - cheap coffee can
1 - steam source (I used a Wagner Power Steamer 705, but whatever you have on hand will work)
2 - saw horses (optional)
Assorted screws
Drill & Jigsaw (Table saw if plywood isn't yet cut.)
Step 2: Assemble the Skeleton
Using three of the large pieces of plywood and all 4 pieces of 1x2, create a three sided box with all 4 pieces of 1x2 in the 4 corners.
Attach 2 pieces of 2x4 per side to act as a guide for the stove pipe down the center.
Step 3: Prepare the Endcap
Take your coffee can and cut a whole in the bottom to fit whatever delivery method you choose. In my case I cut up a threaded piece of plastic that came with the power steamer and epoxied it onto the coffee can. Insert the coffee can onto the end of the stovepipe. This can be hard to change once completed so be sure it's what/where you want it.
Step 4: Put the Meat on the Bones
Put the first two layers of insulation in the bottom of the box, lining up the holes cut in the insulation.
Place the stovepipe in the center in line with the three guides.
Cut the insulation into four 60 inch pieces and make holes for 2x4 guides.
Your measurements for the sides will be different than mine, but you'll again cut four 60" pieces, and then cut them in half. Once that's done cut them to fit in between your guides and press them in between the pipe and the plywood.
Step 5: Finish the Box
Put the final two layers of insulation on the top and screw down the top piece of plywood. Take your two 14" x 14" pieces of plywood and cut a 6.25" circle right in the middle. Screw one onto the front and one onto the back.
Step 6: Steam and Bend Wood
Hook up your steam source and insert the wood you wish to bend. I also recommend placing something under the tail end of the box so the condensation can drip out of the front rather than pooling inside. Place a towel over the front opening but leave a small gap to allow steam to escape so it doesn't build up pressure. Be sure to steam it 15 minutes per 1/4" and you should be able to bend it to whatever you need. In this case I've made 90 degree bend over a 5 foot section.
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    6 Discussions
    spark master
    Question 10 months ago
    1)WHAT/where were the tutorials you used, 2)any vids using it 3) how many seconds do you have from pot to jig 4) how long does it cool to set? 5)overbending by how much?
    Great tutorial, very basic, very nice work.
    spark master
    10 months ago
    I must make one soon, I do not think the insulation matters, but it might, and is cheap. The ancients and certainly the not quite so ancients dod not have it and they steam bend big things, like beams on a ship made from barely shaped tree "stems".
    I want to make walking sticks and canes, this will fit the bill. Get a jig ready and make some steamed wood a la king! Throw in a nice berenaise sauce...
    vincent7520
    2 years ago
    Very nice job.
    But I must say that I don't see the purpose of insulation.
    Insulation is useful to contain heat (or cold) for a longer period, not for steaming small pieces of wood such as yours (or even bigger boards such as in the boating industry).
    In the three wooden boat yards where I worked we always had a steel tube slanted 25° from the ground and heated by a propane burner : the end of the boards would more or less sit in the water but that was no trouble. Wood ones not rot from sitting for 30 / 45 minutes in water !…
    For bigger board there was a very long big box made of solid wood (not plywood) and held together by strong fittings. Steam was provided from a boiler through a pipe. Basically it had the same shape of what you did. But again insulation was not needed.
    To be honest insulation seems to have very little beneficial effect to me : wood would get steamed in about the same duration, and the loss of heat wouldn't be so great. With the almost kindle you had to steam a single steel / iron tube would have been good enough… and simpler.
    At any rate steaming wood does not require100% steam : as long as you get 80°C / 90°C you're on the right side of the marking buoy (as we say in nautical slang !…).
    As for handling an iron tube that is still hot a good pair of gloves does the job; the more so that it loses its heat quite rapidly, being so thin. At any rate a bucket of cold water would help if you're still wary of getting scolded.
    Thanks for sharing anyway.
    JosephR25vincent7520
    Reply 2 years ago
    I had the same question. I'd assume that so long as the steam was hot going in it would maintain temp on its own. I'm assuming we're not bending boards in a freezer. That said, it would prevent your shop from overheating if that's a concern.
    seamster
    2 years ago
    This is so good. I love the way you built and insulated the box. A steam box has been on my to-make list for years, but I had never considered making it with insulation like this.
    This looks like the way to go for sure. Nice work :)
    naaberleseamster
    Reply 2 years ago
    Hey thanks! I like the insulation because I can handle it immediately afterwards and hopefully the exterior wood will last a lot longer without the steam coming directly into contact with it.
