Wood Lichtenberg Figures
105,742
375
43
Warning! This project uses high voltages. Build at your own risk.
This is also my first project on Instructables so it might not be formatted too well. Sorry.
This is a really fun and simple project that almost anyone can make. You can make it for yourself or as a gift.
Materials:
-Transformer (I used a 6KV Neon Sign Transformer. The higher the voltage, the thicker the stream and the more branches produced)
-Extension Cord
-Wood (I used an 8 inch by 3.5 inch piece of Poplar)
-Water
-Spoon
-Baking Soda
-Cup/Glass
-Sponge
-Alligator Clips (optional)
-Scissors or Wire Stripping Tool
-Paper towels
Step 1: Preparing the Transformer
First, strip the output and input wires from the transformer.
Then strip the extension cord so the three wires are exposed. Once stripped, connect the input wires from the transformer to the wires from the extension cord. It does matter which wires are hooked up to which.
The one in the middle (should have green insulation once stripped) is the ground and is hooked up to the ground (green) wire from the transformer. The wire which comes from the left prong (the one that goes in the larger wall input) should be neutral, this hooks up to the white wire. on the transformer. The wire which comes from the right prong (the one that goes into the smaller wall input) should be live/hot, this hooks up to the red wire from the transformer.
Once the wires are hooked up, do not plug it in. You will plug it into the wall in a later step.
Step 2: Preparing the Wood
Take your glass or cup and put two tablespoons of baking soda into it. Then pour water into it until it is about 3/4 full.
Stir the mixture until it is cloudy.
Grab your sponge and soak it up in the mixture while it is still cloudy, do no let the baking soda settle to the bottom.
Softly rub the sponge onto the side of the wood which you want to have the Lichtenberg Figures.
Get your paper towels and dry the sides of the wood. Some of the mixture might have gotten on the sides.
Step 3: Burning the Wood
I placed alligator clips on the output of the transformer because the wire would not reach far enough.
I also placed a wood beam under the piece of wood which I would be burning for extra insulation.
Set the wire on each end of the wood.
Step back and plug the extension cord which was attached to the transformer into the wall.
Do not touch any part of the wood, transformer, or exposed wires while it is plugged in.
Almost instantly the wood should start burning. Once both sides are connected to each other, the figures will stop being burned into the wood. Once this has happened, unplug the transformer.
Just let the wood sit for about a minute and that is it. You should have your own wood with Lichtenberg Figures on it.
Make sure the transformer is unplugged before taking the piece of wood.
This was originally from TheBackyardScientist on YouTube. I will link his video.
Click here for TheBackyardScientist's video
  • Pie Contest
    Pie Contest
  • Fat Challenge
    Fat Challenge
  • Jewelry Challenge
    Jewelry Challenge
43 Discussions
LeeH153
Question 1 year ago on Introduction
How do you attach PVC with wire to fractal
Burn?
Natsufire
2 years ago
What's the amps/ current needed for this project in looking at a 12KV neon sign transformer but they have either 25mA or 50mA what would u recommend have the greater effect. I don't wanna buy a transformer and have it melt on me cause of he wrong current ???
ChadB18Natsufire
Reply 1 year ago
Higher current at that same voltage will produce a greater effect than a lower current will produce. Higher current = greater danger, though. So be careful! Those currents are easily high enough to be lethal at that voltage so it is a good practice to keep your left hand in your pocket when playing with that kind of power, just so you don't reflexively grab a conductive surface should something unexpected and startling occur.
JamesG398ChadB18
Reply 1 year ago
Chad, thanks for sharing that word of advice. That's what I learned in electrical training, left hand in your pocket, preventing current flow through your body/heart from hand-to-hand contact.
ClarkC5
3 years ago on Introduction
So ive been wanting to use the transformer from an old microwave, the scariest part is the setting up the dang transformer. Any tips other than what you have provided. I.E. what types of insulated tools you would suggest
ChadB18ClarkC5
Reply 1 year ago
My advice: Add a momentary switch on the 120 side which feeds the transformer (on the hot side; switching a neutral is bad practice) and run that switch out to an electrical pvc conduit cut to fit your grip, fit it with some end caps and install the momentary switch into one of the end caps on the conduit. Then you will have some isolation from the HV side, you can stand back before energizing it, and it won't stay energized if you drop your homemade handheld switch. Much more safe!
alissam1ClarkC5
Reply 3 years ago
Note that I'm in no way, shape, or form a trained electrician, but I have worked on small appliances and computers around my home.
So long as you're 100% sure the microwave or whatever device you're harvesting the transformer from is unplugged from the wall, the only shock you're at all likely to get is from static.
That said, be sure to finish off the project with wire nuts and/or electrical tape to make the finished product a heck of a lot safer. Just remember to trim the bare wires (the part sticking out from the insulated 'sheathe') down so there's no bare wire coming out of the end caps.
Using wire nuts:
http://www.ehow.com/how_5984152_connect-end-caps-e...
Using electrical tape:
http://www.doityourself.com/stry/6-tips-for-using-...
bmaneyalissam1
Reply 2 years ago
That's very wrong. There's a big capacitor that can zap you in there. Know what you're doing if you open a microwave.
NelsonStudiosbmaney
Reply 2 years ago
I haven't seen a microwave cap with out some sort of drawdown well ever. I suppose some of the older ones might have. Don't just fear bate, share how to test the cap is down with a chunky screwdriver. Teach what you know... or don't share it.
bmaneyNelsonStudios
Reply 2 years ago
I didn't mean to fear bait. I'm actually worried about this. When there's a small chance that someone can get killed, I feel it's worth saying something. Most guides on the web about microwave repair will have cautions concerning discharging the cap, so I didn't feel it necessary to repeat that here. I should have said so. Here's an example: http://www.doityourself.com/stry/repairmicrowave
DennisA67ClarkC5
Reply 2 years ago
Using a microwave transformer is way too dangerous. You can find a transformer that has high voltage and less amps. It's not the volts that kill you it's the amps. Do your homework....search for safe practices....it may save your life
damienm30
2 years ago
is the transformer one time use?
DennisA67DreamingOrchid
Reply 2 years ago
Wont work with a welder. You need a transformer that will take 120 volts up to 10k to 15k volts. I use a oil burner ignition transformer I bought from walmart's online for 48 plus tax.
MavthePatriotDennisA67
Reply 2 years ago
What kind of Oil burner ignition Transformer do you use? Do you mind commenting with pictures of the work? I was thinking about getting this one.
https://www.amazon.com/Allanson-312-28-LB-431-Transformer/dp/B00EZHCKUM
H&JK
2 years ago
Just about what I was looking for - thx :-)
Anyone know if it's
possible to control the path of the figure more discreetly? maybe doing something like
only putting conductive liquid around a certain area and then putting
something temporary and insulating on the wood in the area that I'd like
to keep clear?
NicholasS138H&JK
Reply 2 years ago
let us know how your expiriment worked...
Murray Elen
2 years ago
Warning: A 32-year old artist's death occurred on 7/2/16 in Cortland, OH burning wood like this! This is not safe. RIP Jarrett R. Hutton.
