Wood Mountain Wall Decor
13,224
172
15
About: I enjoy simple DIY projects and enjoy sharing them with others. I'm 33 and I am a sheet metal worker by trade. I really enjoy remodeling and making things. I'm married and have two wonderful children.
I've seen photos of these wooden mountains here and there floating around Reddit and I always thought they were pretty neat looking so I decided to try this myself. This was my first attempt and I'm pretty happy with the results. When I remodeled my house I was going for that rustic and modern feel and this fits right in. Here's what I used for the build:
TOOLS:
  • HAMMER
  • NAIL SET
  • MITER SAW
  • TABLE SAW
  • ORBITAL SANDER
  • TAPE MEASURE
  • TRI-SQUARE
  • BRAD NAILER
  • CIRCULAR SAW
  • CARPENTER SQUARE OR DRYWALL SQUARE
  • CLAMPS
MATERIALS:
  • WOOD GLUE
  • BRAD NAILS
  • 3/4 ASPEN WOOD
  • 3/4 OAK WOOD
  • 3/4 MAHOGANY WOOD
  • 1/4 OAK PLYWOOD
  • 220 GRIT SANDPAPER
***CHECK OUT THE VIDEO FOR A MORE IN-DEPTH TUTORIAL***
Supplies:
Step 1: STEP 1: Make the Backer
I bought a 4'x4'x1/4" piece of oak plywood for my backer. I measured out 21 inches by 41 inches and marked it with my drywall square. I left it a little long because I'm not too precise with the circular saw and I would use the table saw to rip it down to the correct length and width. It probably would have been easier to set up a fence for my circular saw; that way I wouldn't have had to use the table saw to cut everything down.
Either way, after I rough cut the backer, I brought it over to the table saw and ripped the backer to 20 inches, then it was off to the miter saw to cut the width to 40".
Step 2: STEP 2: Draw Your Design & Make a Boarder
This took me a few different tries but I finally found a design that I liked with the mountains. I simply used my tri-square and laid everything out. Everything was mitered at a 45 degree angle and the tri-square measures one inch wide so I went with that.
Then I proceeded to the table saw where I ripped everything down to 1 inch wide strips.
I cut the border first using aspen. The border would be the same width and height as the backer we previously made. I test fit everything first and then used wood glue and a few brad nails to hold it in place.
The only problem that I had was that my brad nails were a little too long and they stuck out a little ways so I had to grind them off using a flapper wheel on my grinder.
Step 3: STEP 3: Measure / Cut / Glue / Nail
Using my tri-square, I was able to get most of my measurements. I set my miter saw for 45 degrees, and began cutting everything to length. For each mountain base, I would cut all the strips first and then glue and nail after. This way I could be sure that everything was going to line up the way I wanted.
I only used 2 or 3 nails in each strip, depending on how long they were, and for some pieces just one nail was enough.
All the mountain bases were made from oak.
Step 4: STEP 4: SNOW CAPS
I treated the snow caps a little differently. For one, I did not use any nails, these were cut very tightly so that they would be "pressure fit", but I also used glue on them. I did not want the nail holes interfering with the look of the caps since that's mostly what your eye is drawn to.
The caps were made with aspen since that was the whitest colored wood I could find.
For the caps I would cut them a little longer and mark where they should end; because I followed my drawing I made on the backer piece the entire way for the most part. I then would glue each level one at a time instead of cutting them all at once.
Step 5: STEP 5: the Sky
For the sky I ended up alternating oak strips with mahogany strips and I staggered them so the seams would not be next to each other. Cutting around the caps of the mountains was easy also because everything was at a 45 degree angle. For this I would lay the strip on top of the caps and mark where I needed to cut and measure down. I then cut these out with my scroll saw.
Step 6: STEP 6: Add Hangers and Sand
I, sadly, had to grind off all the nails that stuck through the back side. This actually wasn't really that bad to do, but if I were to have had shorter brad nails, I could have skipped this step.
After the grinding was done, I added 2 sawtooth hangers and sanded the picture with 220 grit sandpaper. I didn't need to spend much time sanding because I was still going to that rustic and rougher look when I was all done.
Step 7: STEP 7: Apply Finish
After sanding I dusted everything off and finished the picture off with some butcher block oil. I ended up doing 2 coats and after a week or so I added another coat.
I hope everyone enjoyed this instructable. I would love to hear what you guys think. Let me know in the comments section! Thanks for looking!
***CHECK OUT MY YOUTUBE CHANNEL FOR MORE TUTORIALS LIKE THIS***
www.youtube.com/c/adamfleisch
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    15 Discussions
    Yoruk
    1 year ago
    Whao, beautiful !
    London Warburton
    1 year ago
    Hi, thank you for sharing your wonderful project, I'm looking for the lumber (new to woodworking) and am wondering how the lumber was labeled when you bought the 3/4" pieces (Is it. I was also wondering if replacing the Mahogany with Aromatic Red Cedar if you think it'd make it a more of a sunrise/set effect. Thank you!
    adamf135London Warburton
    Reply 1 year ago
    I purchased all the boards from a big hardware store. Each piece was wrapped in plastic. Cedar would look awesome in my opinion.
    rusty2010
    1 year ago
    Where could I find other designs that would work like this? I love the geometric art images in wood.
    adamf135rusty2010
    Reply 1 year ago
    Not sure about that. I found this one on Reddit.
    seamster
    1 year ago
    This is really cool. I'd hang that proudly on my wall!
    On Ya Bike
    1 year ago
    Great project But PLEASE PLEASE PLEASE use push sticks
    adamf135On Ya Bike
    Reply 1 year ago
    Thanks and you're right, I get a little too overly confident and mistakes happen very sudden
    jpmarth
    1 year ago
    Breat idea! Might try this on my hometown skyline.
    adamf135jpmarth
    Reply 1 year ago
    You Should! It's a fun project!
