Wood Plant Stand
7,706
158
5
About: DIY Montreal is all about woodworking & DIY projects. I post how-to videos on my YouTube channel, as well as step-by-step tutorials on my website www.diymontreal.com. Builds include mainly woodshop proje...
I went into West Elm the other day and saw this super cute mid-century plant stand, and immediately thought to myself – I can make that! I was even more convinced of myself after I took a peek at the price tag.
Watch the step-by-step video, or read on!
If you like the video please subscribe to my YouTube channel!
Supplies:
Step 1: Materials
Step 2: Measure and Mark Your Cuts
I started by measuring the size of my concrete planter (check out the Instructable) in order to figure out the size of the plant stand. I then cut my poplar board into 2 equal lengths, which I laid side by side and clamped together.
I roughly found the center point and marked across both pieces using a combination square. I then measured 3/8” on each side and marked again with my combination square. Finally I marked 3/4 inch deep. When I was done, each piece was marked with a 3/4 by 3/4 notch (this is equal to the thickness of the poplar board I used).
Don’t unclamp just yet! The last measurements you need to make are for the overall length of the support beams. Mine needed to measure 10-3/4 so I measured and marked 5-3/8 from center on each end. I then transferred this mark onto the 3/4" edge. Ok, now you can remove the clamps!
Step 3: Cut the Support Beams
I started by cutting out the notch using my band saw, but you can use a small hand saw just as well.
I wanted to make this stand as professional looking as the one at West Elm, so I thought it was important to cut the support beams so that they hugged the rounded shape of the dowels where they connected. I used my drill press with a 7/8” Forstner bit that matched the size of my dowels. I lined up the outer edge of the bit with the line I had marked and plunged it all the way through.
Step 4: Cut the Dowels
For the legs, I decided they should go half way up the sides of my planter (5 inches) and I wanted equal length below the planter (5 inches). I added the width of the cross beams (1.5 inches) for a total dowel length of 11.5 inches. I used my miter saw with a stop block to cut the 4 dowels.
I then sanded the edges to round them over a bit.
Step 5: Assemble With Dowel Pins
In order to accurately place my dowel pins, I cut a small piece of cardboard and made to pin holes. I used this as a template to mark all the holes I needed to make. I then used a 1/4" Forstner bit to make the holes.
I started by dry-fitting and although the alignment was not perfect, I was confident that I could get it to fit snugly with the help of some clamps. I added some glue and lucky for me, I was right.
Step 6: Finally Reveal
Once the glue had dried I connected the cross beams. They needed a little encouragement, so I tapped them gently together with a hammer (a soft mallet would have been better).
All that was left was to apply my favorite wood stain, Early American. The final result looks great with my new DIY Concrete Planter (check out the Instructable), and is sturdy enough to withstand the weight!
If you haven't already done so, you can watch the step-by-step video
_________________________________________________________
For more fun DIY projects, visit my blog at diymontreal.com!
You can also follow me on Instagram and YouTube.
2 People Made This Project!
  • Gardening Contest
    Gardening Contest
  • Classroom Science Contest
  • Party Challenge
    Party Challenge
5 Discussions
MarcioWilges
1 year ago
It looks really simple but the concrete planter is the one that needs precise measurements. If they do not tally with the wooden plant holder, then all of your efforts would then go to waste.
abunda
1 year ago
oh qué belleza!!
nex_otaku
1 year ago
Nice design! So cozy )
cbsri
1 year ago
Great idea! Cutting the crosspieces to hug the legs is a very nice touch...looks at least as nice as the one at West Elm, and is probably better.
jessyratfink
1 year ago
Love both the planter and the stand! Might need to make some mini versions of those to go near my windows :)
