Wood State Maps
7,595
244
11
About: I love playing in the woodshop, I'm a bee keeper.
Step 1: Start With a Real Map
I started with a laminated map. Then cut out state shape.
Step 2: Cutting the Board
First you measure the map at the widest part. You have to pick out the with of board you want. I used 1x6 and 1x10. Then you know on map where to measure.
Step 3: Stencil the Map
Once you lay out the boards in the order you cut them lay your map on them and draw the shape of the map onto your boards.
Step 4: Cutting the Shape
Then you take the jigsaw out and start cutting the shape. I use a 10 teeth per inch reverse cut blade. Here's what I learned after the first one. It's easier to cut the bigger parts off , then cut out to the lines. I then used a random orbit sander to sand it down. I started with a 60 grit on the sides that I cut. Then a120 grit.
Step 5: Stain
You pick out your stain color. I went with a darker one.
Step 6: Hangers
I measured down 1 1/4 inches from top center. Then placed d rings down 3 inches. I split the difference from center to the edge. And used a braided wire from the d rings.
And that's all there is to it. It's simple and easy. Give it a try. You can see other things I make at Todd's S. O. D. Woodworking on Facebook
Thanks
  • Trash to Treasure
    Trash to Treasure
  • Gardening Contest
    Gardening Contest
  • Tape Contest
    Tape Contest
11 Discussions
wpnman99
3 years ago
I wish I could do that but I live in Colorado...
felix_hancockwpnman99
Reply 3 years ago
yeah its not that impressive when a sheet of plywood looks like your state
Thor Hunter
3 years ago
Mn was a fun 1 to make.
rachl009
3 years ago
looks cool! yay minnesota!
ClenseYourPallet
3 years ago
Great project. So simple... Why didn't I think of that. Thanks for sharing
Thor Hunter
3 years ago
Yes. Measure up from the bottom of the board to the top of the cable and add 3/4 inch. And so on. That will give you a 3/4 gap between the pieces
mlawing
3 years ago
Cool project. Are you hanging each of the boards independently?
Thor Hunter
3 years ago
Yes it's simple and easy to do. Great for your friends and family that move out of state.
Kymi 57
3 years ago
I like!
seamster
3 years ago
I like this idea, it's simple but classy. Very nice!
