Wooden Digital Clock
25,006
377
25
Wooden Digital Clock with
- Time, Temperature, Humidity, Alarm
- WiFi controller through web browser
- Advance display config
- Stop alarm by vibration sensor
size : 64 x 64 x 79 mm
i use PLA with wood veneer instead of full wood
my room's too small for put woodworking tools
If want view detail all steps, you can watch video
Step 1: PCB - Display
This step for make PCB (two layer) display module (if cannot do, you can find PCB Manufacturing Service)
I use MAX7219 for led driver and display with Led CEM3491, it have two dots for sec and upper dot for temperature
But CEM3491 is Common Anode, MAX7219 for drive Common Cathode, so must reverse pin Digit and Segment
Material list :
- (x1) CEM3491BY (0.39" Common Anode 4-Digit 7-Segment Display Amber Color)
- (x1) MAX7219 (Led driver display)
- (x1) 10k Resistor
- (x1) 10uF Capacitor
- (x1) XH2.54-5P (5Pin Straight PCB Male Box Header Bar Connector)
Step 2: Program
I have complete program firmware, you just upload it to STM8S005C6T6 by software STVP-STM8 with file controller.s19
STVP-STM8 : http://www.st.com/en/development-tools/stvp-stm8....
hardware for upload : ST-LINK
if see "PROGRAM MEMORY programming completed" it mean done
about upload firmware, view detail in video at 10:35
Step 3: PCB - Controller
Next for solder microcontroller STM8S005C6T6 and other parts for complete PCB controller
button for reset wifi config, just hold down 3s and buzzer will fire beep sound
Material list :
- (x1) STM8S005C6T6 (Microcontroller)
- (x1) ESP8266-12 (WiFi module)
- (x1) ASM1117-5.0 (voltage regulators 5V)
- (x1) ASM1117-3.3 (voltage regulators 3V3)
- (x1) 470uF Capacitor
- (x1) 1uF Capacitor
- (x3) 10uF Capacitor
- (x2) 4.7k Resistor
- (x1) Mini Pushbutton Switch (4Pin)
- (x1) SW-420 (Vibration sensor)
- (x1) DS1307 (Real Time Clock)
- (x1) 32.768 khz crystal
- (x1) CR2032 battery
- (x1) CR2032 battery holder
- (x2) XH2.54-2P (2Pin Straight PCB Male Box Header Bar Connector)
- (x1) XH2.54-4P (4Pin Straight PCB Male Box Header Bar Connector)
- (x2) Cable Double Connector XH2.54-2P
- (x1) Cable Double Connector XH2.54-5P
- (x1) Cable Double Connector XH2.54-4P
Step 4: External Interactive
solder external interactive parts : dc jack power, switch, DHT22, buzzer
don't forget put heat shrink tube before solder
and make sure solder jack dc exactly polarity (+ -) with PCB controller
Material list :
- (x1) PCB prototype double side
- (x1) DHT22 (Temperature, Humidity sensor)
- (x1) C1815 Transistor
- (x1) DC power jack
- (x1) Buzzer 5V
- (x1) Rocker Switch On/Off
Step 5: Box Case
3d print with PLA filament 1.75mm, layer height 0.16mm
complete SLT file in attachfile, or build for yourself with custom size
Step 6: Assembly
link connector cable and arrange internal, external parts for fit with box case
require M2 bolt (x9)
don't forget put CR2032 battery
Step 7: Wood Skin
I use wood veneer sticker for apply skin simple
Step 8: Complete & Test
Input 9v power supply and turn on switch button to on wifi
Default mode is AccessPoint (mean wifi create from wood clock)
mode AccessPoint have default SSID : noname (no password) with ip 192.168.4.1
with mode Station (mean wood clock will join to other wifi) your device and wood clock must in same wifi network
after switch on and wifi ready, Led will show 4 number of ip, ex : 192 (--blink--) .168 (--blink--) .4 (--blink--) .1
then visit ip on browser, you'll see control page with 7 menu
- Home : display curent Time, Temp, Humi, Heat-Index
- Display : change Brightness and Type display time
- Time : config current time and digits
- Temperature : config temprature
- Humidity : config humidity
- Alarm : config alarm and sound
- Wifi : config wifi
Lights Contest 2017
Runner Up in the
Lights Contest 2017
Internet of Things Contest 2017
Runner Up in the
    • Trash to Treasure
      Trash to Treasure
    • Arduino Contest 2019
    • Tape Contest
      Tape Contest
    25 Discussions
    apatrik
    3 months ago
    impressive! expertise in electronics, 3D printer, cad ... all at the highest expression.
    The precision of the joints is exceptional .... many congratulations!
    To be honest as soon as I saw the title and the first images of the video of the project I thought "I do it too", then seeing the complexity I had to take note that it is not a project within my reach.
    good job!
    ansarid2
    1 year ago
    Can I get the coding of this project
    ee_eng
    1 year ago
    Very nice job. Great video overview of what/how you did it. Very well done. You've included a lot of general info on WIFI, Packaging, Display, etc. that can be leveraged for other projects.
    Thanks for your efforts, all the details, and wiliness to share!
    BaptisteL8
    1 year ago
    Love that. Very interesting and a really good job. Thanks for sharing!
    BobGroh
    1 year ago
    Very nice job. For me, most interesting is digit display through the veneer. Exactly what did you use for veneer? Is it wood or plastic? Thickness?
    richb77BobGroh
    Reply 1 year ago
    Its not wood at all. Its textured vinyl. Depending on where you live it will be called different thing. DIY stores in Europe will have it called "Fablon" (a brand). Not sure elsewhere. Just be sure to clean the case with alcohol or dirt/grease remover first to make sure the adhesive lasts.
    androkavoBobGroh
    Reply 1 year ago
    I not expert about wood, so can't confirm wood or plastic
    only thing i can sure it have waterproof and self-adhesive, like sticker, decal
    back side have info manufacturer : "SHIN LUNG - Product of Taiwan"
    i think same as this product : goo.gl/0ccA9y
    that's all info i have, hope useful for you
    BobGrohandrokavo
    Reply 1 year ago
    Thank you. Information is quite complete. It is plastic (PVC) with adhesive on back. How were you able to make display area transparent?
    androkavoBobGroh
    Reply 1 year ago
    just apply on led, light of led can through with good brightness, it made you feel as transparent area
    slice73
    1 year ago
    What was the program that you used to design the PCB?
    chunkysteveo
    1 year ago
    Great video - neat soldering and a quality project at the end! Top stuff!
    androkavochunkysteveo
    Reply 1 year ago
    thanks, with deep focus about soldering
    i think you also expert about electronic
    ken4199
    1 year ago
    Super cool
    Does that mean it's displaying through the sheet
    brmarcum
    1 year ago
    Bro.
    What the...
    I can't...
    How did you...
    Could this be any cooler!?
    androkavobrmarcum
    Reply 1 year ago
    i curious about your word unfilled :)
    focus to main question, because esp8266 consume large power, so when enable wifi, heat will up at 5v & 3.3v regulator ic (not hot, just warm)
    if you use wifi for short time, so don't need cooler
    if worry about result of temperature sensor, you can isolate temp-sensor by aluminum or silver foil, or drill some holes for air flow into box case
    also don't use 12V power supply, heat will up, good power about 7~9V
    michaelmuntz
    1 year ago
    That's my love. unique idea and easy DIY project. Love to ask my kids to make these kind of experiments. thank you
    cagrikanver
    1 year ago
    Wow that's really cool.
