Wooden Radio
46,524
906
73
About: Helena Mueller, Industrial Design student, Darmstadt Germany
A Radio, which can be positioned and used in two ways. On the one side as a sculpture and on the other side
as a radio.
Discovering and understanding are two typical human acts which belong to the development and education in life. Men are curiously striving for knowledge and if they don‘t find any solutions it makes them anxious. Among its function, the radio “bola” is also a sculpture which does not give any hints to reveal its use. First of all, the observer of “bola” does not know anything about the use of it in the first way. He needs to find out by trying. For switching the radio on and off, setting tune, and to change the volume, the radio has two rotatable rings lying upon another. The round base is the speaker and to use the radio it has to be turned around. Then the radio finds a new stable position on its own through inner weight distribution. Except the electronic pieces, the radio “bola” is completely made out of wood. The case consists of many wooden layers, which are different in their thickness and sort of wood (obeche, balsa, linden, mahogany). If “bola” is not in use as a radio, it can be turned around again to stand on its speaker, which integrates itself as a sculptural object into the interior space.
Supplies:
Step 1: The Design
After long time of researches, scetches and brainstorming I finally found my idea of a wooden radio. I found a method how to place the tuners for setting them by rings, not by buttons. In my pre-model you can see the axial position of the pencil, which shows the middle and the idea to place the tuners in one line, up to each other, not next to each other.
Step 2: Choose the Wood
I decided to take different sorts of wood, in my case it got mahogany, obeche, balsa and linden. When I knew what kind and thickness I could buy in the modelling shop, I started to plan the layers, what part I give what wood for. After planning I started sawing and cutting the layers, piece by piece.
Step 3: Build Up the Hollow Part
After cutting it's all about bringing them clean and parallel together.
Step 4: Shapening to Final Form
With a turning lathe I finished the form. In one second I was not concentrated enough, so I broke it. It exploded into more then 20 pieces, but I was lucky and could find every little piece to bring it back together.. so take care, this shocking moment is nothing I can recommend :)
Step 5: Add the Electronics
In the last step comes the meaning of the radio... the radio! I bought a simple buiding set, which includes just two bottons, one for setting the volume and one for the channels. The "start"-botton is included in the volume controller.
For the inside I builded an extra mount for the electronics, which is sticking by clicking in the hollow part. With this mount it's possible to place the controllers stacked. Here the upper one is for the volume, the lower one for the channels. To shape them for more grip to the wooden part I took a metal saw and rasps.
When all pieces are prepared, shaped, sanded and brazed, you finally can bring them together, there's no more glue neccessary, just stick them into each other. The profile on the controllers and in your controlling rings need to fit into each other, that there's just one (or two) possible positions. If everything went fine, your radio is done, ready, willing to be used!
Wish you a lot of fun trying it! You can check my technical drawing, but I'm pretty sure every radio would be unique, depending of the wood, the set and apperance.
Thanks for watching / reading, I'm courious and excited about your comments!
Best,
Helena
Wood Contest
Fourth Prize in the
Wood Contest
    • IoT Challenge
      IoT Challenge
    • Gardening Contest
      Gardening Contest
    73 Discussions
    hummingbird2002
    3 years ago
    Cool project I am doing this in class!!
    Izzypup
    4 years ago
    Hello again! Months ago I commented on your radio and (stupidly) asked how much you'd charge to make one for me. (I've done crafts for years - decades really - and have often explained to those who ask why I don't make a living doing it that there is so much time involved, nobody would pay for the time involved - even at minimum wage!) But now I have another, possibly equally stupid question. Would it be feasible for you to assemble the insides - the radio part - for a price? And, if so, how much would that cost. My reasoning - I am completely, hopelessly ignorant regarding anything electronic but LOVE working with wood and am sure I can accomplish the build if the exterior. I can do the wood build to fit the interior you create.
    I simply LOVE what you've done and an grasping at straws in an attempt to have one if my own! Give my idea some thought and let me know what you think!
    Thanks!
    helmuelIzzypup
    Reply 3 years ago on Introduction
    Sorry for the late answer, I've sent you a message and some pics here, I couldn't add to the message:
    (Some wires already broke, don't open it too often ;P )
    Izzypuphelmuel
    Okay, so I stupidly asked how much you would charge to make one of your rolling radios for me. (I do crafts too and I know how time consuming they can be - hence the "stupidly".) But I still want one! (Feel free to read that in a whiny voice) I'm admittedly grasping at straws here but what is the possibility (and price, if it is possible) of you putting together the electronic bits? As I said before, I'm electronic-stupid and wouldn't have any idea where to start, no matter how good the instructions are. I'm a visual learner. I MIGHT be able to do it if I watched you and mimicked each step.
    The wood is a different matter. I LOVE working with wood and am at least 95% sure I could pull off the housing for the radio.
    As I said, grasping at straws. But I HAD to try!
    owatson
    4 years ago
    this is cool. I want to make a stereo Bluetooth speaker that looks like this
    helmueljjmorrison4
    Reply 4 years ago
    I bougth it in an electronic store.. you also can find it in the internet, check the links in other comments!
    PowellMade
    4 years ago on Introduction
    Nice work fitting that all inside!! Loved it.
    Lathes are sure fun. Do you know what went wrong so others can avoid smashing their jobs? Chisel fell below rest or caught?
    aerohydro_nz
    This is a great Instructable. It's a lovely design, reminds me a bit of a wooden MP3 player that was mentioned on BoingBoing a few years ago. (http://gadgets.boingboing.net/2007/12/10/acornshaped-wooden-m.html)
    hgaikwad
    4 years ago
    Very beautiful
    Do u have any simple design which as beautiful as this
    helmuelhgaikwad
    Reply 4 years ago
    thank you! I have a lot of different designs, but each one is about anything else and not even a real existing product I can share here :p
    Izzypup
    4 years ago
    So beautiful and elegant! I love things made of wood - and making things of wood. Unfortunately, I'm completely ignorant when it comes to the electrical parts. What are the chances (and what would the price be) for you to make one for me?!
    helmuelIzzypup
    Reply 4 years ago
    thanks! guess the price of materials and time would be a way to high ;) if I'd get the chance to produce it another way, you will hear from me!
    jdenslinger
    If I put a blutooth receiver in it, can I call it the e-bola radio? Ok ok... that was lame
    But Really awesome product! I almost wish I could buy one! If you find a manufacturer to (semi-)mass produce these, please share with us!
    helmueljdenslinger
    Reply 4 years ago
    hehe, I guess it's a way too expensive building another single one, but if I'd get the chance to find any other chance to produce it professional I'll let yyou know.. that would be a dream :D
    helmuelhelmuel
    Reply 4 years ago
    oh, about the single one, was ment to another comment xP
