Wooden Train Whistle
59,435
495
23
About: I am a high school design and technology teacher and I love making things, especially if it involves using recycled materials. I use instructables all the time and find them inspiring, motivating, useful, an...
This is a small wooden whistle that is quick to make and sounds great.
Material used in this example is 20 mm x 20 mm x 150 mm pine and 9.5 mm dowel
This plan is based on a similar one by dirtbike98
Step 1: Mark the Centre
Mark the centre of one end.
Draw a line from corner to corner.
Step 2: Drill Hole
Clamp your material in the jig under the drill.
Check the drill bit is lined up to drill down the middle.
Drill down as far as you can.
Step 3: Mark Out the Air Hole
Follow the measurements on the plan to mark out the air hole.
Step 4: Cut the Air Hole
First make the straight cut by clamping your work in a vice
Step 5: Angled Air Hole Cut
Take your time to saw the second angled cut
You can hold the base in a vice and hold the saw on an angle to cut.
Or if that's not working for you use a jig to guide the saw.
Sand the air hole edges smooth with sand paper
Step 6: Prepare Dowel
Cut a 20 mm section of dowel, this will be fitted into the end of your whistle.
Sand a flat face onto to dowel.
This flat face will sit up so the air can be blown over it and exit through the air hole.
Step 7: Project Complete
Your whistle may need a bit of fine tuning now.
You can adjust the sound it makes by flattening the dowel some more, smoothing the air hole edges, pushing the dowel in further or removing it a bit and making the hole deeper
Good luck!
3 People Made This Project!
  • Paper Contest
    Paper Contest
  • Trash to Treasure
    Trash to Treasure
  • Organization Contest
23 Discussions
fraser02
2 years ago
Nice project, thanks for sharing!
i might try this out with bamboo...
tsb2225
3 years ago on Introduction
So simple - thank you. If you want different tones then you can change the depth of the drilled hole in step 2: shallower will give a higher note. Alternatively, drill right through and use a longer piece of your dowel, slide it in from the other end to the air hole and adjust the note by changing how far its pushed in.
Ms Wildtsb2225
Reply 3 years ago
Thanks for the comment, I haven't experimented with tones, I will give it a go.
Great suggestion, thanks
MJFoster
3 years ago
I've been looking for a pattern for a train whistle and this is the BEST one. Thanks for sharing.
Ms WildMJFoster
Reply 3 years ago
Terrific! Would love to see any pics of your finished work, all the best
MJFosterMs Wild
Reply 3 years ago
I'll be glad to share Ms Wild. :0)
caperjack
Great job ,nice whistle ,,when I was a kid in the 50's , when hiking or fishing my uncle would break a branch off a tree he new had a hollow center in parts of it ,and cut it like you cut your wood and make us a whistle for us ,we just thought he was the smartest guy ,and he still is at 86
Ms Wildcaperjack
Reply 3 years ago on Introduction
Hi, thanks for sharing the memory, I'm going to look out for small hollow branches!
fran=1Ms Wild
be carefull their is a hollow weed called hogweed that is what looks good but it can cause skin burns and blindness it grows most places it has a big flower like queenann lace but it grows to 8' or taller please look out for this......frank
Ms Wildfran=1
Thanks for the heads up
https://en.wikipedia.org/wiki/Heracleum_mantegazzianum
Truckloadfran=1
Hi Frank, I think bamboo will be a good choice for this type of project. Michaels (or any art supply store) sells bamboo. I have collected a piece from my friend. I am going to try it out. Thanks for the nice post Ms Wild.
BIVS2000
Great idea! Have you ever heard of making a whistle with more than one tone? Maybe 2 or 3 or 4? I read about one a long time ago, but of course, forgot where!
Good job!
Anakin47
Great project to do with grand kids... Thanks for the clear and easy steps to follow.
NathanSellers
3 years ago
This is cool. I like the simplicity of it. Thanks for sharing.
BCDesign
3 years ago on Step 2
Great work,I will make this with my kids!
