Wooden USB-stick
6,746
94
4
This is a really simple but rather nice project, which can be built in a few hours and with stuff laying around. But besides it's simplicity it is a great gift idea and a project you'll be happy about every day! If you want to built one for yourself watch the video first, it will explain everything.
Step 1: Gather Materials and Tools
Materials:
  • scrap wood (you can use pretty much annything - I used an old cutting board for this ;) )
  • a USB-drive
  • some oil for the finish (or anything else)
Tools:
  • a chisel
  • an electrical sander
  • sandpaper (for manual cleanup)
  • a saw (scroll-saw or small handsaw)
  • a drill if you want to make the dowel-version)
  • some wood-glue
Now we can begin the project
Step 2: Cutting the Wood
First you need to pry open the USB-drive enclosure. Mine came apart pretty easily.
Then cut the boards to size. They should overlap the stick gently but not to much. You can use a stack of different boards, or one block. If you decide to make the enclosure from one whole block of wood, you have to cut the block in half now.
You can round of the backside now
Step 3: Fit the USB-drive Inside the Wood-block
You can use the USB-drive as a reference for the slot that has to be cut in the middle piece. If you want to use one block you have to chisel out the cavity, or use a cnc-machine if you are super fancy ;). I recommend to use a soft wood for the middle, because it will be easier to cut a slot in it.
Always check the fit of the USB-stick. It should be a snug fit, but the upper and lower half should touch. If they don't touch make the cavity in the middle a bit bigger.
Step 4: Glue It Together
Before you glue the stick together, you have to sand the front side down, because later the plug will be in the way. Just clamp the pieces together and sand them down. They don't have to be super-smooth, because we will sand the front side manually after the stick is assembled, but big dents or scratches are difficult to remove in that state...
After sanding down the front-side you can assemble the whole stick. I would recommend to use some tape to cover the metal plug of the USB-drive to prevent glue from getting onto it. I used wood-glue for the wood and a bit of general-purpose adhesive to fix the stick to the wood. Clamp it down and let it dry for a few hours.
Step 5: Adding a Dowel (optional)
For one stick we decided to add a dowel in the backside to make it visually more interesting. For this we drilled a hole through the back-side of the wooden case and stuck a wooden dowel through. We cut it flush and sanded it down. This step is optional, so if you don't like it simply skip it..
Step 6: Sanding...
Now there is a lot of sanding, the most favorite part of woodworking...
Start with the roughest sandpaper and the highest power setting to get to the main shape. Then gradually use smoother sandpaper to make it smooth...
If there are any holes in the wood you can use wood-filler to get around it.
Lastly go over it manually with a very high-grit sandpaper to make it really smooth
Step 7: Finish
Lastly you have to add the finish, we used oil, but you can use spray-lacker, or anything...
if you have made your own USB-device, we would be very happy if you like this video and submit your own creation. Also if you have ideas for future projects please leave a comment.
Anyway I hope your USB-stick looks nice and you did enjoy the building process. Bye!
  • Woodworking Contest
    Woodworking Contest
  • Classroom Science Contest
  • Fandom Contest
    Fandom Contest
4 Discussions
mr_eand1der
2 years ago
Nice work! The best impromptu (hard)wood stain I've used to date is Kiwi shoe polish-- dab it on and then buff it to a high shine using a cotton cloth-- it brings out the grain beautifully. You can then coat it with glossy finish sealant to seal in the color (and help make it more watertight). If you do, I'd recommend using painter's tape to protect the metal USB plug. Oh, and be aware that using black shoe polish will actually get you a mostly *purple* stain-- brown tends to work best.
Nice job. I would have used a darker stain with a shiny wax finish, but you stick look also glorious!
Ohh...what did I just say......
Swansong
2 years ago
Neat mod, that looks really nice! :)
