Woodgas Can Stove
326,870
299
53
This is a design for an inexpensive, lightweight wood-burning stove, suitable for backpacking, bike touring, and bush cooking.
It is a two-wall design, which preheats air in between the walls to ignite the smoke. Well-tended, this produces a bright, smokeless flame which produces little soot and leaves little to no scorching on the ground below.
It is built from commonly available (in the United States) parts: a quart paint can, a smaller tin can, and a shorter tin can. The only specialized tools are a safety-style can opener and an Irwin Unibit #1, though similar designs can be made with just a church-key and ordinary can opener and alternate tools are discussed in appropriate steps.
The whole thing can be built in about an hour. This model weighs 6.6 oz (187 grams) after several firings, and nests in, e.g., the Snow Peak 900 Ti or Al pot.
Ready? You'll need:
Supplies:
Step 1: Materials
A 1-quart paint can, with lid. I just bought a new one for a couple bucks at the local hardware store; if you're reusing one with paint in it you need to fire the paint off in an open fire. This is nasty and you're probably better off buying a new can.
A 19 ounce Progresso soup can. Other cans such as 20 ounce cans of fruit will work as well, but the
Progresso cans are a bit shorter, which we want.
A Large, short can. Mine had bamboo shoots in it; many cat foods and canned meats come in this sort of can. The diameter should be a little larger than the inner ring on top of the quart can. Don't get an aluminum one, it'll melt and buckle in the heat.
Step 2: Tools
You'll need:
Drill
Tin Snips
Irwin Unibit #1 Though one can use several bits to make successively larger holes, this tool will make you life easy and your holes better.
Safety Can Opener This is the kind that takes the top entire off the can, rather than cutting a hole in the top. One could use the other kind but this will leave a jagged hole and isn't recommended.
Also useful
Sharpie, Electrical Tape and Scissors for marking where the holes go. The ruler turned out useless, however a:
Fabric Tape Measure proved very useful indeed.
Step 3: Drill the Bottom Sides of the Inner Can
This step I will be doing differently in the next model.
What I did here was drill two rows of 1/4" holes in the bottom side walls of the can. This does not provide enough draft. A design known to work, this stove's closest relative in fact, has holes in the bottom, rather than the bottom sides, so one could drill out a bunch of quarter-inch holes into the bottom.
I intend to drill out another can in the near future, with three rows of 3/8" holes up the inner walls, and perhaps more holes as well. I'll update this instructable accordingly, and welcome comments on people's luck with this step.
Step 4: Measure Top Holes of Inner Can
The circumference of your can is in the area of 10 1/2". What you're going to do is mark 10 spots an inch apart, leaving one area with a slight gap between the holes.
The quarter-inch fabric measure is about a quarter-inch from the top corrugation of the can; this gives a good result.
Step 5: Drill the Top Holes
Drill holes into your dots, all the way down to the bottom of the unibit. Let the rotation, rather than the pressure, do the cutting, or you'll get some buckling.
Step 6: Measure Holes in Outer Wall
The outer can is about 13 1/4" in circumference. We measure 10 holes, an inch apart. leaving a gap between them. I centered this gap on the seam, because it looks nice, but this isn't necessary.
5/8" up from the rim turns out to be the sweet spot for the holes. An eighth inch either way won't kill ya.
Step 7: Drill Holes in Outer Can
Make 1/2" holes in the can on your marks. You have to look at these holes, so take your time and do it right and you'll have a neat-looking stove.
Step 8: Remove Bottom of Outer Can
Take your safety cutter and remove the lid. It can be reserved for extra fire protection or discarded as useless; take your pick.
Step 9: Press Fit Cans Together
Taking your soup can, press the top rim into the inside-top rim of the quart paint can. It'll be a tight fit, push it in there with the heel of your hand until you feel it lock into place. No additional fastening is necessary; to crimp the seal, pound the lid back on as far as it will go with a rubber mallet. Be prepared to spend quite awhile prying the lid off with a flat-head screwdriver after!
Step 10: Drill Out Potstand/windscreen
Make a diamond-pattern of 3/8" holes, as shown.
Leave room to cut a feed slot out.
Step 11: Cut and Crimp Feet Slot
With tin snips, cut out a chunk of the can to make a hole to feed sticks into the fire while a pot is on it. With your multitool or pliers, crimp the edges in to strengthen the cut and reduce the chances of snagging a finger.
Remove the bottom of the can with your safety opener, and discard.
Slice through the top, leaving a ring that can be stored between the walls or nested into the top ring of the can.
Step 12: You're Done!
This one came in at 6.6 oz or 187 grams, but drilling more holes in the inner can should drop a couple points while making it work better. This compares with the BushBuddy, which weights 6.4 oz and costs 90 bucks Canadian, while offering similar functionality.
Step 13: Use It!
To fire up your cooker, you will first need a can full of biomass. Best choice is pencil-sized sticks of completely dry, dead wood, most often found still attached to trees or hanging from branches. Anything which is laying on the ground is likely to be somewhat damp, hindering a clean burn. The stove will also burn charcoal, pine cones, bits of cane etc. to varying degrees of success.
Fill the can with sticks, laid parallel to the ground in alternating rows like a grid. Bring the wood to near the top burner holes, but do not cover them.
Place the cooker on something that won't ignite, and shelter it from the wind. You could carry a windscreen but unless you're traveling in particularly harsh terrain it's worth it just to find a quieter place to cook your meal.
Build and start a small fire on top of this fuel. Fire-lighting is an arcane art with many approaches, all of which call for some practice and skill. A general approach that works well is a tinder ball with a small tipi of sticks around it; the idea is to get the sticks burning and start to char the layer below, as well as to make glowing coals that drop down to ignite the lower wood.
Place the windscreen/potstand in the groove of the can; this can be used to build a lean-to style top fire as well. Experiment before it makes the difference between dinner hot and dinner cold!
If properly built and loaded, the stove will ignite the smoke from the fire readily, within a minute of ignition. When the smoke is burning cleanly and brightly, it's time to put a pot on the stand. I keep steel chopsticks on hand to stir the fire if needed, but a light hand is best here and the fire if well built will burn without interference.
When the existing wood has all become coal, one can keep the fire going by feeding sticks in one at a time. They quickly ignite and the smoke feeds the fire for awhile; the stove in this mode must be frequently but lightly fed, finding a balance between too much smoke to burn it all and not enough to keep the secondary burn going.
I keep the lid around, as a trivet for the pot, and to cover the fire when i'm done with it. This will cause the remaining charcoal to smother out slowly; leaving the lid off will led it burn down into clean ash. The can could be used for charcoal making by firing it until the volatiles are mostly gone, covering the bottom holes with dirt, and putting the lid on.
As I implied earlier, the stove as shown here doesn't work as well as it might. I chalk this up to the small holes at the bottom of the inner can; larger holes, and more of them, will feed the fire properly and keep everything nicely aglow.
Step 14: Credits
The first stove of this nature I'm aware of is the Bushbuddy, http://www.bushbuddy.ca/. By all reports it works well, I've never had a chance to use this or any other woodgas stove but my own. It is expensive, but first in class.
This design closely models http://tjamrog.wordpress.com/2008/12/22/the-evolving-backpacking-wood-stove/, by Tim Jamrog. His design has holes in the bottom of the inner can, rather than the bottom sides, and this is known to work well. I'm working on a design with a solid bottom, for various reasons including catching the ash and embers. As I've indicated, it works, but it could work better, and I think larger holes on the sides of the inner can will help. For just under six bucks in materials, experimentation is easy.
For those wanting the lightest weight and blingiest gear, the Bushcooker LT from http://www.fourdog.com/index_files/bushcooker.htm can't be beat. Titanium won't rust out, ever, and the LT II, which is closest in size to this model, weighs a wispy 3.5 oz.
Making stoves is easy, fun and satisfying. Experiment to your heart's content, and let me know what you come up with.
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    53 Discussions
    der_fisherman
    3 years ago
    Great Instructable, one of the best I have seen recently.
    I would like to point out that 2 or the 3 links posted, do not seem to work anymore.....but that is minor. YouTube has many videos for anyone interested as well.....
    Many, many thanks.
    many, many thanks......
    Skwurlitosarge89or
    Reply 4 years ago
    there's also the mountain ranger design...
    rajmathur
    8 years ago on Step 13
    Please provide pics of where to put the burning material and maybe a video of it in action.
    Skwurlitorajmathur
    Reply 4 years ago
    make your kindling pile on top or wedged inside a bit. light it. let it burn a bit. it should fall in the process as normal.
    dforcucci
    5 years ago
    I made some mods but using the two cans and how they fit together so perfectly was the bomb. Thanks
    gunsmith67
    6 years ago on Step 2
    Those "tin snips" of yours sucked for one simple reason... they are actually pruning shears!
    cant_decide
    6 years ago on Introduction
    Built one today, and did a burn test. It was pretty easy to build, not my cleanest work, but smooth on the outside, and serviceable for backpacking. The test burn was sans water, and I was happy to see no issues, and a burn time of as long as I wanted to keep adding scrap wood, about 45 minutes. After I do a test with water, I'll post a comment as well. I did opt to drill out the bottom of the inner chamber instead of the sides.
    gaziger
    6 years ago on Step 5
    http://www.northerntool.com/shop/tools/product_200307292_200307292
    The largest hole that the Irwin Unibit #1 can make is 7/8"
    pstretz
    9 years ago on Introduction
    This is a great instructable. I will be building one of these to take camping for sure. That being said, I think this may be misnamed. Wood gas is actually a completely different thing altogether. http://en.wikipedia.org/wiki/Woodgas This is more like a really complicated chimney starter. http://en.wikipedia.org/wiki/Chimney_starter I have actually cooked on my chimney starter before when quickly searing tuna and steaks and I can completely appreciate this design as a means to concentrate heat and cook things quickly and efficiently.
    It would be interesting to pit a chimney starter modified with a potstand against this stove to see which would boil water faster.
    atmanpstretz
    To quote the Wiki on the subject of woodgas: "Certain designs of stove, are in effect a gasifier working on the updraft principle - the air passes up through the fuel, which can be a column of rice husks, and is combusted, then reduced to carbon monoxide by the residual char on the surface. The resulting gas is then burnt by heated secondary air coming up a concentric tube. Such a device behaves very much like a gas stove. This arrangement is also known as a Chinese burner." That's the sort of stove this is! I hope that was clear. This stove is also not unlike a chimney starter.
    jcampbellatman
    Reply 6 years ago on Introduction
    Pstretz was right: This is a wood stove, not a wood gasifier. A gasifier creates two products: wood gas and charcoal; it requires heat from another fire to operate. The wood is not actually burned in a gasifier.
    twohawks
    6 years ago on Step 14
    My thoughts exactly. Good write-up, atman, thanks.
    kiwiiano
    9 years ago on Step 5
    May we have actual hole sizes, please. Irwin Unibit #1s aren't universally available outside of the US of A.
    atmankiwiiano
    The actual hole sizes are given, albeit in our funky, fraction based Imperial "inch" system. For those of you where things make more sense, let me interpret the runes:
    1/4" = c. 6 mm NOTE: don't make holes this size, use:
    3/8" = c. 1 cm for the inner bottom holes and the windscreen and:
    1/2" = c. 13 mm for the inner top holes and the outer bottom holes.
    Hope this helps!
    akilbypup
    7 years ago on Introduction
    In making this good stove, I couldn't remove the tab-opening Progresso can lid with any of my can openers, because the rim is too high. Surveying available canned goods, I found another source for 19-ounce cans, measuring the same as the Progresso but with an ordinary top and bottom, in the ethnic section: La Victoria brand enchilada sauces (both red and green types) come in three sizes, including the one we need for this purpose. Just thought folks might like to know.
