Word Art Trivet
3,841
49
12
I realised I was missing a trivet from my life and really needed somewhere to place hot things in the kitchen. I like self-referential objects, and "hot stuff" is a bit of an inside joke between my girlfriend and me, so I set out to make this word art trivet. The actual making process is pretty simple if you have access to the right tools (a CNC router ideally, or a saw capable of detail work) so this is going to be more of a look into how I turned the text into the shape of the object in Inkscape.
Step 1: Write Text
Open up Inkscape, set your document to use the units you want, create a text box and type in the text you want to use. I spent a while playing around with fonts at this point to find one that looked good. Ideally you want a fairly chunky bold font to end up with a solid object that isn't too spindly. Serif fonts tend to be more legible in the finished article because the serifs make the end points of the letters more visible, and fonts with a "natural" curve tend to look better than very geometric ones, but this is largely a matter of personal choice and the limitations of the material you are working with.
If you're using more than a couple of words, you'll want to think about word placement at this stage too. You can always change it later, but it's good to start with the layout you want because it makes the next steps easier.
Step 2: Convert to Path
We're going to be editing the words as a path, so once you are happy with the font and placement of words, select the text and click Path -> Object to Path. Select the new path and press Ctrl-Shift-G to ungroup it into individual letters. Once you've done this you should see each letter surrounded by a dotted outline box.
Step 3: Overlap Letters
The next step is to make the letters in each line overlap slightly so that the result will be a single solid object. Inkscape's Align and Distribute tool makes this easy. Select the endmost letter of a word and move it leftwards slightly (you can use the arrow keys to move objects around, or Alt+Arrow for smaller adjustments). Select the entire word, open the Align and Distribute sidebar, and select Make horizontal gaps between objects equal. This attempts to space out the letters between the first and last so that there is an equal gap between each, but if the end letters are too close together to space all the letters out, this will move them so that there is an equal amount of overlap between each letter.
This is a starting point for your word art, but you will probably need to tweak the layout after distributing the letters to get the amount of overlap you want and to make the final product as legible as possible. This might also be necessary after you move the lines together so that they overlap- serifs might get covered up, letters might meet in inconvenient places etc. This stage of the design is very much an iterative process.
Step 4: Artistic Choices
So now you've got a bunch of letters overlapping that you could turn into an outline, but the layout isn't quite right. In my case, the first word is shorter than the second but I really wanted the letters to fill out a rectangle. My first instinct was to space out the letters of "HOT" to fill the rectangle- they didn't need to overlap because they were connected to the bottom word which had each letter joining together. It filled the rectangle but didn't look right, it was too sparse looking and I wanted something that would feel less lopsided.
Another of Inkscape's useful features is the ability to perform a transformation to each element of a group rather than the entire group. With the letters spaced out, I selected the word "HOT" and did a scale transformation to make the letters wider, but ticked the "Apply to each element separately" box. This meant that Inkscape would make each individual letter wider but keep the spacing I'd established. This resulted in the second layout, with the letters both being wider and having thicker strokes, giving a much more solid-looking layout.
The path should have a fill colour set so when viewed on normal view it will appear as solid text. You may find it useful to set display mode to outline, which shows the outlines of the letters and gives you a better idea of where each letter sits and how much they are overlapping, and then change back to normal view to see how the solid object will look.
Step 5: Path Editing
When you are happy with the layout of your letters, select the path and click Path -> Union. This will combine all of the letters into a single outline path. This will be the outline of your finished object.
Despite choosing a chunky font and making it bold, I wanted the letters of my trivet to be even thicker. To achieve this, click Path -> Dynamic Offset. This will add a node to the path that you can drag. Dragging this outwards replaces your path with a new path drawn a set distance from the outline of the original. You are effectively "inflating" your letters, making the letters chunkier and the spaces smaller. Where parts of the outline collide (for instance the "O" and "U" in my design) the path joins up where they meet. In my case I was glad of this as it meant the O wouldn't only be supported by a single point and the trivet would be sturdier. Again, this process should be driven by the limitations of the material you are working with, how you are going to cut it out and how legible the resulting text outline is.
Step 6: Cut It Out!
The final step in editing the path before turning it into a real life object is to make sure it's the right size. I wanted my trivet to be about 20cm wide, so I set the path size accordingly. It's helpful to set the document size in Inkscape to something familiar (in my case portrait A4, which I know is 21cm across) as a visual reference.
How to cut it out depends on the tools you have to hand. I used Makespace's CNC router by exporting the outline from Inkscape as a DXF, converting that into a toolpath and cut the trivet out of some 12mm plywood. You could use a scrollsaw, a fretsaw or even a drill and a jigsaw. If you are going to use hand tools, you could print the outline at 1:1 scale and use contact cement to stick the paper template to the wood and then cut around the outline.
Step 7: Finish Up
Once your trivet has been cut out, give it a sanding to remove any splintery edges and round the corners slightly, and it's just about done!
If you are going to put cookware on your trivet (and that is rather the point of the exercise) it would be best to apply some kind of finish. I used some boiled linseed oil and a J-cloth to oil the surface of mine, which should provide some protection against spills. I'm no expert in wood finishes but I suspect a lacquer-type finish would be more resilient, providing it's capable of withstanding high temperatures. Whatever it is, if food is going to come into contact with it make sure it's food safe- the only thing I put on mine are hot pans and dishes so I could get away with this linseed oil ("boiled linseed oil" isn't food safe as it contains metallic drying additives).
Once that's finished, you're done- go and admire your new piece of functional word art!
    • Tape Contest
      Tape Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Trash to Treasure
      Trash to Treasure
    12 Discussions
    unkerjay
    3 years ago
    Good news!
    Found a hackerspace in my area.
    "Hacker Space", "Maker Space", "Tech Shop"
    No "Tech Shop"s, but, "Hacker Space"
    Gotta learn what to "Google" for.
    They've got a laser cutter.
    Haven't made it yet.
    Anxious to try.
    Attached is the design I want to go with - the lower one.
    And some examples of the fonts I tried. The Wood Look and
    Carbono are free downloads (try DaFont).
    Also added them as I did, because, leaving it and coming back
    to it, left me forgetting which font I'd actually started with. When
    playing with multiple fonts from a LARGE variety, something like
    that may come in handy when it's time to pick one.
    I'll post an update, when, (IF) I get it done (assuming I don't
    run into any problems along the way).
    I made one (modest) change to the design, as I thought it might
    be just a little more eye catching. Just my tendency to not want to
    leave well enough alone.
    unkerjay
    3 years ago
    Are you saving money with your laser cutter?
    Well, Shapeways will print me an aluminum model
    at your dimensions (20 cm) for as much as $ 1,200
    or down to about $ 800.
    If I print stainless steel, it'll cost about $ 400.
    That's a savings of at most, $ 800 over the cost of
    an aluminum model.
    And I started out with a HOLLOW model to begin
    with to cut costs!
    I'd say you're saving money.
    Considering the cost of the alternative.
    My dimensions? 20 cm x 8.6mm thick
    Even if I reduce the thickness, not sure, I'm going
    to save much.
    unkerjayunkerjay
    Reply 3 years ago
    At 4.3mm, I cut my costs in half as well.
    Anyone interested in a $ 200 trivet?
    PKMunkerjay
    Reply 3 years ago
    Well, considering the idea of a trivet is to insulate the countertop from a hot pan, I'm not sure a metal trivet is what I'm looking for :)
    If you wanted one made of metal, I think you'd be better off using a CNC mill, waterjet or plasma cutter to cut it out of a sheet of metal rather than 3D printing. There are plenty of commercial businesses who could probably cut an outline out of steel from a design file for less then $200.
    unkerjayPKM
    Reply 3 years ago
    Yeah, well, probably not.
    The other alternatives for 3d printing at Shapeways are:
    Porcelain and Plastic.
    If METAL isn't exactly the best, porcelain breaks and Plastic
    melts.
    They're not offering wood yet.
    Just looking at this alternative since I don't own a laser cutter.
    And those who do (when I've asked, on projects) aren't returning
    my calls. Apparently they're not in the hobby markiet.
    At least the ones I've checked.
    There's not a Tech Shop in my area (Seattle). Don't know why.
    There would likely certainly be the demand.
    Not sure if custom wood cutting is something Home Depot or Lowe's
    offers. Unlike "Office" Depot which offers custom printing (but not
    laser cutting either).
    Curious. By comparison, what are your total costs of production?
    Including the cost of a laser cutter?
    Last I looked, I don't think they're cheap. Or am I wrong?
    I'm kind of scared of saws (routers, jigsaws, band saws, table saws.
    Afraid to lose a finger, a hand, an eye, or worse.
    I have so much respect for them that I just avoid them like the plague.
    So far, it seems to be working.
    unkerjayunkerjay
    Reply 3 years ago
    BUT, I could do porcelain for a LOT less: $ 70 by comparison.
    Not nearly as durable.
    $ 70 trivet anyone?
    ANYONE?
    (There's just not much of a market for even $ 70 trivets.
    Sigh)
    PKMjessyratfink
    Reply 4 years ago on Introduction
    Thanks :) I almost couldn't believe no-one had done something like it already. Thought I'd had a great original idea then saw something quite similar in the local chinese takeaway after I'd made it...
    KitemanPKM
    Not yet, I'm just getting the hang of the software, not so flexible as an Epilog.
