Word Rings
33,210
445
39
About: Industrial Design student at Eindhoven University of Technology
In this instructable, I will show you how to make word rings. I took the set 'You are cool' for example. I hope you like it!
Step 1: What Do You Need
To make this project, you will need:
- Wire
- Pliers
- Round object matching the size of your finger
- Paper
- Pen/pencil (Something to write with will do)
Step 2: Writing
First, choose your text and write it down. Using short words will keep it simple.
Think about how to write it so you can make it with wire.
Step 3: The Y of You
So, write it down the way you are going to bend it.
Cut a piece of wire.
Start at the point where you also started writing: The left top of the Y.
Then, bend the wire down. Using the flat nose plier, press the wire closer to the U shape you just created.
With the round nose plier, you can shape the bottom of the Y.
Step 4: The O of You
Take your round nose plier to form the O.
After the O, leave the wire pointing upwards.
Step 5: The U of You
Bend the wire down against the O. Use the flat nose plier to press the wire close against the O.
Using the bigger part of the round nose plier, shape the U.
Step 6: The You Ring
Take your round object and press your word against it. Use the wire to make the ring, by wrapping it around the object until you reach the beginning of your word.
The second picture shows where to bend the wire back. When you've bent it back, put it trough the first letter.
Put it back on the round object and shape it, so it becomes round. You can work away the last bit by wrapping it around the ring.
That was the You ring!
Step 7: The a of Are
Write down the word the way you are going to bend it.
Make half a circle. This will be the first part of the A. Then, bend the wire right up to close the A.
Bend the wire down again and press it closer to the A with the flat nose plier.
Step 8: The R of Are
Bend the wire up again. Then make an almost closed circle and finish the R by making a diagonal line down.
Step 9: The E of Are
The E is very simple. You just have to make a imperfect loop and then bend the wire to the side.
Step 10: The Are Ring
The closing of this ring is exactly the same as with the You ring.
Step 11: The Cool Ring
Can you figure this ring out yourself?
Now you have your own set of rings! What can you come up with? Please, show me!
If you have any questions, feel free to ask :)
    • Gardening Contest
      Gardening Contest
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    39 Discussions
    Luv2Draw
    5 years ago
    I know-emilyvanleemput- that ur probaby getting a little tired of replying back to everyone by saying "Thank You, Thank You, Thank You" commenting saying "cool, good idea, etc" but GUESS WHAT?!!! ITS TRUE!!! Dont worry u dont have to say thank u again---- YOUR WELCOME
    Actually, I like thanking people. The fact that they like my instructable AND take the time to post a comment on it, that's a reason to thank them already :)
    I really like jewelry made out of wire, so this will be really fun to make! Thanks for posting this, it's really cool :)
    kenchato
    5 years ago on Introduction
    i would great if you can use some clear epoxy resin, to make the ring, more hard, because if the ring get attached to something, i will stretch and disarm.
    ouchmytoe
    Actually, I believe the ring says, "you are coal". The tail of the 2nd O should not drop to the typeface baseline. And, in case you are wondering, yes---I actually DO have Obsessive Compulsive Disorder.
    dougwillsouchmytoe
    Reply 5 years ago on Introduction
    I believe you mean Compulsive Disorder Obsessive (CDO). Obviously the letters must be in the right order.
    ouchmytoedougwills
    Yeah, I've seen that before. :) I know it is ment to be humorous, but I actually intentionally omitted the initialism to avoid this very comment. It's not a big deal, it just bugs me (as you can imagine). *sigh*
    dougwillsouchmytoe
    You know, you are right and I sincerely apologize. As someone who has a wife with OCD (the phrase I used previously is actually something she says), I completely understand the frustration that comes with OCD. I hope that I did not offend too much, and am sorry for any frustration I might have (probably did) cause. It was not my intent, but it is clearly something that I should have left unsaid.
    daldrich-1
    5 years ago on Step 6
    Rather than using manuscript you could use linked or cursive writing making it a lot easier to form.
