Work Table on Wheels
8,161
279
9
My garage is a nightmare. I have projects piling up, and no usable workspace to get anything done. I decided to build a work table that I could roll out of the garage, and do some clean up in the meantime. I needed a table that would have enough surface space, but also some underneath storage for lumber. The deck of the table is 3/4" plywood, and there is a border of red oak that goes around the perimeter. I left a 4" overhang on the table so that it would be easy to clamp things down.
Supplies:
Step 1: Supplies
  • 1 - 4'x8' - 3/4" plywood
  • 7 - 2"x4" x 8' Pine Board
  • 6 - 2"x6" x 8' Pine Board
  • 2 - 1"x2" x 8' Oak Trim
  • 2 - 1"x2" x 6' Oak Trim
  • 4 - 3" Caster Wheels (2 are rotating & locking) plus mounting screws
  • 2" Construction Screws
  • 3" Construction Screws
  • Polyurethane
  • 8 x 5" x 1/2" Carriage Bolts, washers, and nuts
Tools needed:
  • Circular saw
  • Power Drill
  • Belt Sander
  • Palm Sander
  • Paint Brush
Step 2: Build It Upside Down!
I started by building the framework for the table laying on the ground. Since I wanted to have a 4" overhang on each edge, the length of the frame is 88" x 40". I used a combination of pocket holes and driling screws from the outside in to strength. the box. These are the 2"x6" boards that make up the frame.
The legs are 2"x4" boards attached with 1/2" Carriage Bolts to the frame. Like a jig saw, I used shorter board on the inside part of the leg to create a joint for the cross beam, which ties the entire thing together. The goal was to make the table site 35" off the ground. Once the legs were installed and the cross beams mounted, I used a few extra boards to create a shelf that would facilitate lumber storage underneath. Once the casters were installed, I flipped the table over.
Step 3: Add the Table Top and Trim
I centered the plywood on the table, marked 4" from each edge, and used construction screws countersunk to attach the plywood. I then added the red oak trim strips to the outside edge. This hardwood will not only protect the plywood from getting damaged, but the hardwood will be a nice surface to clamp too. I sanded the entire top with a belt, then palm sander. I didn't spend a ton of time making it perfect, as it's a workshop table. I stained the top with Polyurethane and let it dry. I piled some of my scrap lumber on the bottom shelf, and I'm ready for my next project!
    • IoT Challenge
      IoT Challenge
    • Fandom Contest
      Fandom Contest
    9 Discussions
    bbologna
    2 years ago
    Any concerns with doing any serious hammering while on casters? You might get some bounce, or movement.
    MichaelMikkelsonbbologna
    Reply 2 years ago
    Sorry for the late reply, as I didn't see this until now. The casters are pretty beefy, so I doubt I'd have concerns on that. If this becomes a problem, I can always buy bigger casters!
    IzzysDad
    2 years ago
    Great work! Was wondering, though I can probably figure it out myself with some thought, do you have a cut list/dims? Mostly for the legs construction? Thx!
    MichaelMikkelsonIzzysDad
    Reply 2 years ago
    Sorry, no. I had some rough sketches before I started, and built it as I went along. I guess I had the entire thing laid out in my head, and it ended up working out pretty well. Hopefully, you can use the pictures to help figure out what isn't documented. Good luck.
    Oldehawks10
    2 years ago
    I like this idea being on casters. I have limited space and in need of both a lumber cart and a work station.
    MichaelMikkelson
    Reply 3 years ago
    Good idea. I'll have to google that to see if there is an option that isn't too expensive. Also, I built the table to be the same height as my table saw, so modifying the design might change that height. I have that retractable wheels thing on my dewalt planer, so I know exactly what you are talking about.
    MichaelMikkelson
    Reply 3 years ago
    2 of the caster wheels have locking brakes, so the table remains put. I think that there might be some applications where not having it on casters would be better, but with the weight of the table and the locks, the table doesn't move.
    TomW27
    3 years ago
    Did you put any kind of finish on your workbench?
    Thanks
    MichaelMikkelsonTomW27
    Reply 3 years ago
    Yes, I did a coat of Polyurethane and plan to do a few more coats this weekend. I had thought about doing an epoxy resin to make it stronger, but I figured that it is a workbench, and will be dinged up no matter what.
