Worlds Cheapest Organizer
It is cheaper than the stores
Step 1: FInd Box and Cut It Up
Find a box that is suitable for this build (about 2 foot long and 1 foot high)
Cut of the top flaps and glue/tape the bottom flags together.
Step 2: Drawer Slots
Use the cut out flaps and create a cross shape. You can stick this inside the middle and glue the edges.
Step 3: Boxes
Cut out pieces which you need to glue together to form boxes (leave one side open) (must be able to fit inside the cross) then do this 3 more times
Then add handle
Step 4: Finishing
Place the boxes into the slots. Then you are pretty much done.
(you can use 3 boxes and leave one slot open for shelf space if you want)
    • Weaving Challenge
      Weaving Challenge
    • Pie Contest
      Pie Contest
    • Organization Contest
    2 Discussions
    Swansong
    1 year ago
    Old cardboard is really useful :) I used some to make a tea caddy last week.
    pfred2Swansong
    Reply 1 year ago
    Yeah cardboard is good stuff. A lot can be done with it. Gluing cloth material on cardboard can make it a lot stronger too. It also looks nice then. But it is a bit tricky to get cloth on cardboard flat. I've used spray glue with zero open time. Maybe with PVA wood or white glue it would be better? I'll have to try it some time. PVA glue can even be thinned with water to apply it thinner and stretch it out.
