Worlds Smallest Power Supply !
39,345
597
40
About: Ideas Into Reality !
Have you ever wanted tiny sized power supply that still pack lots of power, here's world's smallest power supply you can make under 6$ !!! Following Features will impress you that's for sure so why not make one ?
# Features
1. 3-25v Adjustable Voltage Output
2. Built in 720mAh Battery Backup
3. 2 Amp Max Current
4. Built in Live LED Voltmeter
5. Built in Voltmeter For Quick Measurement
6. In Built 3.7v Battery Charger
Supplies:
Step 1: Applications
1. Power Supply (OTG) on the go !
2. Measure voltage with it.
3. Do the Job of Many Power supplies 3v, 5v,9v,12v,19v,24v...
4. Charge 3.7v Batteries on the go.
Step 2: You Will Need
★☆★ Buy Parts from your online local store ★☆★
1. 3.7v Li-po Battery http://geni.us/okAOH
2. TP4056 Lithium Battery Charger http://geni.us/f6uQJ
3. Micro Usb 2A 25v Step Up Converter http://geni.us/jbMwyB
4. LED Voltmeter http://geni.us/to6Ap9p
Step 3: Watch Full Tutorial
Watch Full Tutorial Here
https://youtu.be/0I_GVAxdO9M
Step 4: Making PCB's Compact
LED Voltmeter and Dc-Dc Converter has few leads which may puncture the battery and take up lot of extra space, so use dremel tool or sand paper to make these pcb's flat at the bottom so that battery can be effectively installed here
Or Yo can use flathead pcb wire cutter to do this job , just don't apply too much force otherwise pcb tracks will be damaged.
Step 5: Make the Connections
Make The connections As Showed In This Block Diagram.
1. Connect the tp4056 board to the battery
2. Connect the negative terminal of the battery to the dc-dc converter
3. Connect switch between positive terminal of the battery and dc-dc converter
4. Connect LED Voltmeter at the output of dc-dc converter
Step 6: Stick Togather !
Well Done Your Connections are finished !
Now Stick all the parts togather in a compact form factor as i've done in this picture.
If you like this instructibles ,then check out my Youtube Channel .
Step 7: Some Extra Safety Tips
1. As you are dealing with li-po battery's , make sure not to puncture,smash,tear or casue any kind of damage to the battery it may cause fire hazard. Do it at your own risks.
2. Don't try to measure voltage grater than 24v with this power supply's voltmeter It can damage the dc-dc converter.
3. If you connect any inductive load ,there is chance of causing damage to dc-dc converter , so connect diode at the output. diode will drop 0.7v but save your power supply.
  • Classroom Science Contest
  • Party Challenge
    Party Challenge
  • Woodworking Contest
    Woodworking Contest
40 Discussions
drherobrine01234
Tip 5 months ago
when sordering and you get a burn from the sordering iron put it down emititly and wash your hands competly and use dish soap instade of hand soap
chiragjwl
1 year ago
I want to make lipo 11.11/2ah battery backup circuit .so please help me on this circuit.
GauravJ14
2 years ago
Hi. Thanks for a brilliant instructable.. This can be used to charge bose speaker. It's battery needs 20 volt output.
RexTexHM
2 years ago
If you use a 3 wire voltmeter, the output can go below 3V
bptjr
2 years ago
bptjr The tp4056 charge board comes stock to current limit at 1 amp . Is this too high current to charge the battery you describe ? Or did you change the current limit resistor on the board ? Great project I plan to build one Thanks
MirzhaK
2 years ago
can I use this power supply to charge my laptop?
Input : 100-240V ~ 1.8A
Output :19V - 3.42A
ovi20k
3 years ago
are those components available in ebay.in??
tonep
3 years ago
Nicely done! I made almost exactly the same here https://m.instructables.com/id/Portable-Variable-Voltage-Power-Supply/, but it has a few extra features and the lithium cell is much bigger (taken from a defective portable charger) so the size is much bigger, but the main components are the same. For those interested in knowing if a bigger size cell works on the same charger,the answer is "yes". I have been charging and using it for about 4 or 5 months now.
brianfit1
3 years ago
Love it. As an alternative to flat-sanding the board, you could press it into a slab of Sugru, and shape it around the Li-po for a nice finished look.
wstewl
3 years ago
1) does the battery get automatically disconnected from the circuit when the 'high power' USB input is used?
2) using just the battery, what output current is available from the circuit (at 5V, or at 12V)?
Kedar Nimbalkarwstewl
Reply 3 years ago
in high power mode battery is disconnected since we're keeping battery switch off, and @5v 1.2amp @12v 500 ma.
wstewlKedar Nimbalkar
Reply 3 years ago
Thank you for answering my questions. Nice project.
When I build it I'll have to be careful about keeping the switch off when using external power.
jr2233
3 years ago
Is that small battery to be used for the charging circuit or is it for whatever I am turning on? Can I replace that small battery with a large 5,000 mAh battery? Will the 2 amp charger be enough to charge it> Hope someone answers me.JR
Kedar Nimbalkarjr2233
Reply 3 years ago
There's no problem keeping Tp4056 as chaging circuit with bigger battery,but if battery is higher capacity then use high power handling dc converter.
lmcwilljr2233
Reply 3 years ago
No. This will handle single cell lipo batteries. Charging a large lipo (multi-cell) battery requires a balancing charger to keep the charge rate under control.
ac-dclmcwill
Reply 3 years ago
He wrote nothing about using more than one cell, so "no" is premature and incorrect. There are ~ 5000mAh Li-Ion cells and you could use as large a cell as you want providing there is no minimum charge rate specified by the manufacturer.
Yes a 2A charger would, in most cases, be enough to charge a 5Ah battery, but the charger is not 2A, it is 1A max, but the input is USB so your source could be even lower at 500mA.
Even as low as 500mA could work but it would seem undesirable to have to wait that long so I would recommend that you find an alternate power source and charger capable of more than 1A, which will raise the build cost a little but so does the 5Ah battery.
evdj
3 years ago
Is it possible to use this power supply as a battery backup with continue connection to USB power?
Kedar Nimbalkarevdj
Reply 3 years ago
Yes its possible to continue use with usb input.
