Woven Paper Bracelet
775
16
5
About: I will be sharing with you helpful videos about cardmaking, papercrafting, painting, some occasional journaling and more.
This is a super fun project to make and you only need paper, no glue or any other fancy tools or materials.
Step 1: Video
If you wish to see how I made the bracelet, I invite you to watch this video.
Step 2: Cut
Cut strips of paper measuring 4 1/4" x 1"
Step 3: Fold
Fold your strips length-ways. I used around 22 strips (11 of each pattern).
Then fold the strips in half.
Step 4: Start
Start with one strip of each pattern.
Pass a strip over the other to form a T. The left side will be shorter and look like a loop. The loop should be big enough to fit another strip through it.
Step 5: Fold & Secure
Fold the ends of the inner strip outwards and down, then over the outer strip.
Secure the ends with a clothes peg.
Step 6: Fold & Tuck
Take another strip and pass it through the loop you've created.
With the loop on the left-hand side, fold the ends from the right-hand side outwards and down, then over the other strip.
Tuck the ends underneath the previous strip.
Step 7: Tip
After passing the strip through the loop insert the next strip through the last loop you've created. This way you'll always be one step ahead and you'll make sure the loop is wide enough.
Be careful not to make the loop too tight as it will be more difficult to tuck the ends.
Step 8: Repeat
Repeat the process until the bracelet is long enough.
Step 9: Finish
To close the bracelet pass the ends of the first strip through the last loop.
Fold and tuck the ends (the same way you did with the other strips).
Step 10: Wear It
So there you have it, a super fun bracelet.
You can use any paper you want (I would recommend a good quality paper), any patterns you like and you can even add a waterproof film (like Mod Podge or Decopatch glue). Have fun with it!
    • Jewelry Challenge
      Jewelry Challenge
    • Fat Challenge
      Fat Challenge
    • Pie Contest
      Pie Contest
    5 Discussions
    HollyH75
    4 weeks ago
    In the Seventies, we made these with paper chewing gum wrappers, which are the perfect size. Middle school memories!
    Cat00xHollyH75
    Reply 4 weeks ago
    Yes, I remember doing that in the 50s and 60s, too! gum wrappers. We would make long chains of them. Hah! I love that the idea is back.
