X-Box Controller Modification to Work on PC/Mac
72,433
61
31
Electrical modification to make your Classix X-Box controller work on your PC under Windows XP or on your Mac under OS X.
Step-by-step instructions for rewiring that even a beginner can follow.
SOFTWARE:
On OSX install Xbox HID Driver for Mac OS X from http://xhd.sourceforge.net/
For Windows XP install XBox Controller Driver (XBCD) from http://www.redcl0ud.com/xbcd.html
Step 1: What You'll Need
1. Heatshrink - I used 6mm, but I would recommend something slightly bigger
2. USB Extension cable - I used grey for the purposes of the tutorial, but black obviously looks a lot better
3. X-Box controller - pictures is a Japanese Controller-S
4. USB Extension cable - I used grey for the purposes of the tutorial, but black obviously looks a lot better
5. Cutting tools - something capable of cutting through the cables and something smaller for stripping wires.
6. Electrical tape
Step 2: Cut
Cut both ends of the USB extension cable off about 4" / 10cm from each end.
Step 3: Remove Cable Casing
Remove the outer rubber casing from the cable by cutting it with your smaller blade. Expose approximately 1/2" - 1" (1-2cm approx) from the end.
Step 4: Remove Cable Shielding
Inside the cable will be some highly annoying shielding to protect the cable, some is silver foil and the other is silver wire. Simply discard of all of this.
Step 5: Remove Wire Casing
Now expose a short piece of wire from the end of each of wire. Be careful, some of the wires are quite fine and will break easily.
Step 6: Discard Yellow Wire on X-Box Controller Cable
Discard the yellow wire from the X-Box Controller, it's only necessary for some of the X-Box light guns.
Step 7: Pair Your Cables
Pair your cables up. The FEMALE USB matches up with the X-Box end of the cable and the MALE USB matches up with the controller end.
Step 8: Pair Femable USB to X-Box Adapter End
This is reasonably obvious. The female end of the USB extension cable goes with the X-Box end of the cable. The reason for this is that we want the male end attached to the controller in order to plug it into your PC/Mac.
Step 9: Cut Your Heatshrink to Length
Cut off approximately 3" / 7.5cm of heat shrink, enough to cover all of the exposed wire.
Step 10: Place Your Heatshrink
Put the heat shrink over the cable BEFORE joining the wires or else you won't be able to get it on. I made this mistake once and it was highly annoying.
Step 11: Twist
Twist the wires together at the end. Black to black, red to red, green to green and, amazingly enough, white to white.
Step 12: Cover Twisted Pairs With Tape
Place a tiny amount of tape over each of the twisted pairs to ensure that none of the wires can touch each other.
Step 13: Cover Exposed Parts With Heat Shrink
Push your heatshrink down so that it is covering the exposed wire. DO NOT bond the heatshrink until you've tested the cables are working.
Step 14: Pair Male USB With Controller End and Repeat
Step 15: Step 15 - Almost-final Product for Testing
Test your cables. Use the controller with both your X-Box and your PC/Mac in order to confirm you've done everything right. Even though it's unlikely that you've messed up such an easy mod, it would be annoying to have to strip all that heatshrink.
On OSX install Xbox HID Driver for Mac OS X from xhd.sourceforge.net/
For Windows XP install XBox Controller Driver (XBCD) from www.redcl0ud.com/xbcd.html
Step 16: Final Product
Finally, blast the heatshrink with a hairdryer or use a cigarette lighter to bond the heatshrink with the exposed pieces. Suddenly you have the final product ready to go.
    • Arduino Contest 2019
    • Classroom Science Contest
    • Woodworking Contest
      Woodworking Contest
    31 Discussions
    JuanB149iCotton
    Reply 2 years ago
    I used the driver that you posted from macman860, the one that's named xhd_2_0_0.dmg. I'm running Sierra as well. Maybe you need to reboot.
    HenserT
    2 years ago
    Very Good idea to keep working with xbox and pc not just pc
    GÑpfrsloE
    2 years ago
    So, I went through with this, though, since I already had two spares of the xbox plug part but no controllers for them I simply stripped down one and added the USB like so. However, the controller I'm connecting is an old Acteck joystick, now that I'm done, the acteck software doesn't recognize the controller, but Windows 10 still detects it as an "XBOX gamepad" however, it tells me there was a problem installing the driver. I then go to install the one you provide with the same results.
    The printer and hardware section recognizes it only as a "generic usb hub".
    Did I messed up, or is this a software issue?
    Franciscob60GÑpfrsloE
    Reply 2 years ago
    Well the problem is the driver doesn't install because "Win10 needs to have signed INF files. And because Inf can't be signed directly - it needs to have ".cat" file that contains digital signature."
    So...
    -Press Start
    -Click on Power
    -Hold down Shift and press Restart
    -Navigate to Troubleshoot -> Advanced options -> Startup Settings and press Restart
    -Wait for Windows to restart and when prompted press 7 for Disable driver signature enforcement and wait for Windows to come up
    -Install XBCD and allow it to install the driver
    If it's still not working
    Device Manager-> Unknown device-> update driver-> search my machine -> C:\Program Files (x86)\XBCD\Driver
    lhz_dun04GÑpfrsloE
    Reply 2 years ago
    So yeah at first I wasn't planning to do the 2 part to link back at the Xbox via USB.
    But I had the same problem as you (seemingly not working, generic usb hub) so I was wondering if that was a hardware or software problem, as it's my first time doing this.
    After reading this guide I did the second part (xbox connector to female usb) and tested the modified controller on the xbox: seemed to work well, so I think the link is all ok, so I guess it's a software problem.
    XBCD driver is a bit of a pain it seems.
    pastapal
    3 years ago
    Anyone have any experience with this under Windows 10 before I get to work on this mod?
    JackB36
    3 years ago on Introduction
    I did mine different, I just used the controller port out of an old XBOX an wired the usb cable straight into the wires :)
    cuth_bert
    5 years ago on Step 6
    http://en.wikipedia.org/wiki/Light_gun
    Cameron657xbox650
    A pistol/rifle for shooting games. You point it at the screen and pull the trigger.
    badbradmx
    9 years ago on Introduction
    just wondering, i dont have a need to try this for my PC but on the other hand, could it be used as a wired 360 controller?
    BigEdSCHS
    9 years ago on Step 1
    I got a few questions man.
    first, I want to know if the heat shrink is necessary or can I just wrap e-tape around it?
    second, can i do the same thing your doing to the cord except splice the USB into the dongle?
    bananasontoastBigEdSCHS
    Reply 9 years ago on Step 1
    Heatshrink - no not 100% necessary, but it does help to ensure there are no worries.
    Yes, you can cut it into the existing dongle, but I personally prefer my method as it's less messy.
    jedikalimero
    wouldn't be easier to make a cable with a male USB at one end and the mini-DIN used in the adaptor cable at the other? this way, you can use the controller unmodified in the Xbox and swap the adapter cable when using it in the PC. I don't know if this mini-DIN is standard or MicroSoft propietary, but even so, you could build the cable with a spare one.
    bounty1012
    ok, can you help? I opened up my controllers wiring and it has a blue green red black white and yellow wire and I plug it in with my usb and go to memory but nothing happens what did I do wrong?
    bounty1012bounty1012
    NVM I got it =] I guess my wires were either touching my carpet and not working or touching eachother and not working, Ty for the instructable, I wanted my controller so that I could still play with it after I modded my xbox 5/5.
