Yarn Brain
6,482
86
12
About: I like sewing and crafts,and trying new things. I'm vegetarian and always looking for new recipes. My cat's name is Mirko and likes to be in the centre of things, so you will see him in several of my instr...
I had first planned to make this brain for Halloween, (zombie bait), but the biologist in me wanted to make this anatomically correct so it took me a bit longer to make. I am not a neuroanatomist so I can't guarantee the accuracy of this brain. I made it based on Google image searches which actually proved to be a bit of a challenge since most brain model images are in cross section (sagittal section) so you only see half of it and you need to extrapolate into 3D.
I made my brain all one colour, but if you want to use it as a teaching tool, you can make each of the parts a different colours. Also the midbrain and brain stem is connected to the cortex with a magnet so you can pull it out and see the parts.
Step 1: What Will You Need
Yarn weight 3:
  • Pink
Other:
  • 2.25mm crochet hook
  • Yarn needles
  • Small knitting loom (eg. Knitting Nancy or a spool loom)
  • Polyfil/fibrefil stuffing of some sort
  • Sewing thread and needle
  • 22 gauge wire, pliers and a magnet
  • Elastic thread (white or pink)
Abbreviations:
Rnd round
ch(s) chain stitch(s)
sc single crochet
sl st slip stitch
st(s) stitch(s)
sc2tog decrease by crocheting 2 stitches together
Step 2: Cerebral Cortex: Knitting
I made my own spool loom from a small plastics tube, I cut a hole in the bottom and poked four nails into the rim. Knitting with this loom forms a cord with a diameter of approximately one centimetre. (Here is an Instructable on how to make a small knitting loom). I won't go into how to use a loom there are plenty of great instructions available for that (How to Loom Knit)
So with my homemade loom I knitted two lengths of cord approximately one meter in length.
Step 3: Cerebral Cortex: Making the Folds
I cut two pieces of elastic thread, roughly half the length of the two knitted cords made in the previous step, about 50cm. I tied one end of the elastic to one of the ends of the cord, threaded the other end of the elastic through the centre of the cord using a yarn needle. The elastic is pulled through the entire length of the cord, out the other end and tied to the yarn tail. This should cause the cord to form folds. Repeat with the other cord.
Step 4: Cerebral Cortex: Assembly
To form the cerebral cortex you need over 3 million years of human evolution. Though for a yarn cortex some sewing thread and a needle will do. I folded each cord about four times and sewed each length together forming the general shape of each hemisphere, albeit flat. I then lined up each hemisphere side by side and stitched together to top edge, leaving the bottom open, creating a bowl shape.
Step 5: Cerebellum
Make two:
With the pink yarn
Rnd 1: Magic Circle 6 .
Rnd 2: Work 2 sc in each sc around - 12 sts
Rnd 3: *2 sc in next st, sc in next st, rep from * around - 18 sts
Rnd 4: *2 sc in next st, sc in each of next 2 sts, rep from * around - 24 sts.
Rnds 5 -7: Sc in each sc around - 24 sts
Rnd 8: Sc in each sc around - 24 sts
Rnd 9: *sc2tog, sc, sc, sc, sc repeat - 20sts.
Rnd 10: *sc2tog, sc, sc, sc, repeat - 16sts.
Rnd 11: *sc2togsc, sc, sc, repeat -12sts.
Rnd 12: *sc2togsc, sc, repeat -8sts. Stuff
Rnd 13: *sc2tog in rest. Fasten off. Leave tail.
Step 6: Pons and Brain Stem
Brain Stem
For the brain stem, use the knitting loom to form a cord approximately 10cm long.
Pons
Make one
Rnd1: Magic Circle 6 6sts
Rnd2: 2sc in sc 12sts
Rnd3: sc insc 12sts
Rnd4: 2sc in first and 6th, sc in sc in rest 14sts
Rnd5: sc insc 14sts
Rnd6: sc2togin first and 6th 12sts
Rnd7: sc in sc 12sts
Rnd8: sc2tog in each 6sts
Rnd9: sc2tog in each. Fasten off. Leave tail. Press flat.
Step 7: Thalamus
Thalamus
Make two
Rnd3: 2sc in sc, sc. repeat in rest 18sts
Rnd4: sc in sc 18sts
Rnd5: sc2tog in sc, sc. repeat in rest 12sts
Rnd6: sc2tog in each 6sts. Stuff
Rnd7: sc2tog in rest. Fasten off. Leave tail
Step 8: Pituitary Gland
Pituitary Gland
Make two
Rnd1: ch2, 3sc in second ch from hook
Rnd2: sc in sc for first, sc2tog next 2, ch3.
Step 9: Hippocampus
Cut two pieces of wire 7.5cm (3 inches) in length. Bend each into a nearly closed circle, with the bottom part flatter and the ends folded back (see image 2 above).
Begin by crocheting: ch2, 3sc in second ch from hook.
Step 10: Hippocampus Continued
Hold the piece you started crocheting in the previous step against the end of the wire and chain stitch around the wire starting at the top. (See these instructions for more information). Continue covering the length of the wire, once you reach the end, turn and sc in each chain for the first 7-8chs, sl st into next chain, tie off and weave in ends. You may need a dab of glue on each end to prevent the yarn from slipping. Repeat with the second wire. Stitch the two pieces together at the top like in image 4 above.
Step 11: Corpus Callosum
Corpus Callosum
Make one
Rnd1: Magic Circle10 10st(s)
Rnd2-15: sc in sc 10sts
Rnd16: sc2tog in each. Fasten off. Leave tail
Stitch a rare earth magnet to the centre of the corpus callosum.
Step 12: Assembly
Now that we have all of the parts, lets assemble.
  • First stitch together the two Thalamus (?plural) at an angle, see above.
  • Sew the two Pituitary Glands in between the Thalamus.
  • Then attach the Thalamus to the top of the Brain Stem.
Step 13: Assembly Continued
  • Stitch together the Cerebellums the same way you did the Thalamus.
  • Wrap the Pons around the Brain Stem, front to back and stitch the Cerebellum to the Pons.
  • Place the Hippocampus around the Thalamus and stitch in place.
  • Stitch the Corpus Callosum to the inside of the Cerebral Cortex, between where the two hemispheres come together in the middle (magnet facing out).
  • Place the Hippocampus against the magnet inside the Cortex, with the Cerebellum at the back. The magnets should hold the two parts together, and can be pulled apart as needed.
    • Paper Contest
      Paper Contest
    • Organization Contest
    • Pie Contest
      Pie Contest
    12 Discussions
    shascho
    2 years ago
    Michelangelo would be proud;
    art in the service of science!
    Or is it science in the service of art?
    Either way, this is a brilliant project.
    I've downloaded your instructions
    and expect to make a colour-coded version.
    An ischemic-cum-hemorrhagic stroke
    converted me from an ambulance paramedic
    to a student of crochet;
    I'm thinking this will be a useful teaching tool.
    And besides, it's just cool.
    ChrysNshascho
    Reply 2 years ago
    Thanks, a colour coded version would be really cool as well as educational.
    ediestel
    3 years ago
    This is SO RAD and unique!
    sigifor
    3 years ago
    Very nice, I'm usually not a fan of knitting but this was exeptional! I'll try to make it as a gift.
    starforest
    3 years ago on Introduction
    Very instersting. Never have seen anything like this before.
