How to Build a Simple But Powerful Flyback Driver
351,702
387
383
About: ––––––––––––––––––––––– "Energy cannot be created nor destroy...
Tired of little purple sparks? Want bigger hotter sparks? Then try:
The ZVS Flyback Driver
It is probably the most powerful and efficient flyback transformer driver that was fairly recently invented by Vladmiro Mazilli. It uses resonant zero voltage switching (also know as ZVS) to drive the flyback transformer. This means the MOSFET's are designed to switch (on or off) when the voltage across them becomes zero.
Because the MOSFET's switches when there is no voltage across them, it will generate very little heat, the only source of heat is caused by the MOSFET's internal resistance. Unlike the simple 555 timer flyback drivers, The ZVS flyback drivers will allow you to run your flyback transformers for much longer periods of time before the MOSFET's overheat. If you get really good MOSFET's, it might be even possible to run your ZVS flyback driver infinitely! (Or until the circuit is interrupted)
Video of it working!
Step 1: The Dangers of the ZVS Flyback Drivers
Not only the ZVS flyback driver is powerful, but it is very dangerous. You can easily pump several hundreds of watts into the flyback transformer and the output current would be around 50mA to 200mA (or even more), which is way above the lethal rate which is 10mA.
Do NOT attempt to do this as your first flyback transformer driver project, I recommend you to start with using simple 555 timer flyback drivers before thinking about building an ZVS driver.
And finally, you are solely responsible for any harm to others or damage or any other problems that a ZVS driver may cause. The ZVS driver should be used for educational and research purpose only.
That is the end of my health and safety rant. :-)
Step 2: Parts
ZVS drivers are fairly cheap to build, the only pricey part may be the MOSFET's. I got most of my parts from Farnell and some of it I had lying around.
• Flyback transformer
Newer flybacks are recommended as they are very robust. You can use an older flyback for higher current output, however, they are more likely to burn out due to excessive voltage.
• 2x 470Ω 2W resistors
The color code is yellow/purple/brown
• 2x 10KΩ 1/4W resistors
The color code is orange/brown/black
• 2x 12v 1/4W zener diodes
• 2x 400+ volts fast diodes
I used UF4007 diodes.
1x  inductor
The value is not critical but it should be 47uH to 200uH rated at 10A or more. You can find an inductor from a computer PSU or you can simply make your own, just wrap 20 turns of 16 gauge of enameled wire around a ferrite toroid.
• 1x 0.68uF 250v (or higher) capacitor
This capacitor must be bipolar and must be good quality, such as MKP ot MMC types. NEVER use an electrolytic capacitor, they will blow up. You can test various types of capacitors to see which one suits your ZVS driver well.
• 2x IRFP250 MOSFET's
They are a bit pricey, however, you can use other MOSFET's that has Vds 4x more than the power supply and has the Rds(on) lower than 150mΩ. Unfortunately those MOSFET's are a bit over my budget so I used the IRFP254 MOSFET's instead, not the best, but it is cheaper and it and it should give me good arc results. I also tried using the popular IRF540 MOSFET, however, it gave me very poor results.
• 2x small heatsink
They won't be necessary if you are going to run your ZVS driver lower than 12v.
• Large variable voltage power supply
Now this can cost quite a big chunk of change, you can a computer power supply unit for 12v power source. If you want a higher voltage power supply, then you might want to consider modifying a microwave oven transformer, but this is another project. As I don't have a large power supply so I used six  6v sealed lead acid batteries all in series to gain 36v to power my ZVS driver.
Then finaly the other bits and pieces you may need such as solder, thick wires, etc.
Step 3: Schematics
The 5 turns of wire as the primary is not critical, you can add or remove windings for different performance.The voltage input to the driver may affect the number of turns required as well.
The "47-200 µH" inductor can be customized to the desired output of the flyback transformer. In general, if you want a higher voltage, the inductor should have an higher value, if you want more current, the inductor should have an lower value. Also, an inductor is a 'must' for the ZVS driver, without it, your ZVS driver may work poorly or not work at all.
Changing the value of the capacitor can also affect the performance depending on the flyback transformer, again, make sure you use good quality capacitor.
Step 4: Construction
Not much to say here, just get your toolbox, read the schematics and build it! :-)
Make sure you use thick wire as it will be handling currents up to 10 amps.
When winding the flyback transformer, make sure both wire go the same way.
If you are going to attach both of your MOSFET's on one heatsink, Use mica insulators! Or other types of insulators to isolate the MOSFET's tabs from each other, otherwise your ZVS driver won't work.
Step 5: Power Her Up and Set Wires on Fire!
When you first power on your ZVS driver, start with 12v input to make sure everything thing is working. Then you can increase the input voltage up to 36v. You can power the ZVS driver above 36v, but then you risk blowing up your driver, check step 7 for instructions for modifying your ZVS driver to handle higher input voltages.
You may hear an very high pitched squeal from your ZVS driver, don't worry, that is normal.
What ever you use as your negative terminal, it will get hot, very hot! The arc will melt any thin wire you use into little metal balls and steal will just fly everywhere, which is cool (and dangerous)! If anyone has a good explnation why the negative terminal get so hot and the positive terminal remains fairly cool, I'd like to know.. :-)
Also, in the video, just after the arc burnt a hole into a lightbulb, they was a stream of plasma 'shooting' out of the bulb, like a flame thrower. This is because when the arc got inside the bulb, the gas inside heats up, causing it to expand and escaping through the hole thus creating a "plasma thrower".
Step 6: Modify Your ZVS Driver for Higher Performance!
I have not tried this yet, but there is a revision of the ZVS driver by Andrinerii. He added two separate 3 turns of wire on top of the existing primary, each with a series 100Ω 10W resistor. This circuit supposedly add an 35% increase in performance.
Also, make sure your 3 turn windings are the same direction as the primary, otherwise you will blow the MOSFET's!
Step 7: Going Further
The fun does not stop there, if you are hungry for more bigger, hotter, and beastly arcs, a few changes to your ZVS driver should be made to handle higher input voltages.
For input voltages over 36v:
Change the 470Ω resistor to 1kΩ resistor.
Change the 12v zenner diode to 15v zenner diode.
Increase the number of windings on your flyback transformer.
Increase the value of the inductor.
This should work well for voltages up to 60v before the MOSFET's should be changed as well...
I heard that some people had operated their ZVS driver at voltages over 100, just imagine how massive their arcs must be!
Also, this ZVS driver circuit does not have be used just for the flyback transformer, you can replace it for use a different transformer to charge up your large capacitor banks for coilguns, railguns, etc. It might be even possible to do induction heating with this ZVS driver circuit...
11 People Made This Project!
  • Arduino Contest 2019
  • Tape Contest
    Tape Contest
  • Trash to Treasure
    Trash to Treasure
383 Discussions
niksa21485
Question 4 weeks ago
I want to drive an electromagnet with it but as i understand, more turns, bigger/better core etc all increase inductance and thus lower the resonant frequency. Is it possible to make ZVS drive a powerful electromagnet at considerably high frequency, say 200KHz?
NajminN
7 weeks ago
How to drive a flyback with 320 vdc input?
GamblerJ
1 year ago
Will the output be same if I use a 0.33uf mkp.. capacitor.
Juan262GamblerJ
Reply 3 months ago
About the same(maybe more,maybe less),but mine heats up quickly idk(for 0.33uf)
prasu999Juan262
Reply 3 months ago
Have you tried changing the value of capacitor ? Or have you found out any solution ?
My one also heatsup quickly.
Juan262Kaiju.
Reply 3 months ago
I wouldnt suggest it,i prefer 250/n or 260/n
Those can take even 60v from my transformer
JoshuaG160
Question 8 months ago
Greetings,
Could this driver circuit provide up to 600 watts for a flyback transformer made to put out 20-40 kVDC and 10-20 mA? Thank you.
Josh
Juan262JoshuaG160
Answer 3 months ago
If you meant the input power up to 600w (36v+)then yes but make sure you follow step 7 and probably use the more efficient circuit design at step 6
Juan262Juan262
Reply 3 months ago
Also the flyback should be the bigger ones for 25+inch tv's unless you want magic smoke's
tkalfaoglu
2 years ago
The flyback transformer part is not well explained: What do we do with it?
I am assuming that we buy/find a TV transformer, and wrap 5x2 coils onto it, and use its output as our high voltage lead?
SnipeX_Š
1 year ago
Do i need to use zeners when mosfets like irfz44n have them build in?
Juan262SnipeX_Š
Reply 3 months ago
If they have built in protection, maybe not, but still a good precaution to put zener diodes(for me personally)
jayantc5
Question 1 year ago on Step 1
hi,
I have following questions:
1. How to choose flyback transformer .What should be its specs like number of turns in secondary, turn ratio, power capacity etc.
2. What is typical input source requirements in terms of current and voltage.
thank you.
jayant
1 answer
Juan262jayantc5
Answer 3 months ago
Sorry for answering so late(8 months)
1.it doesnt really matter,most flybacks can be used(just buy any flyback used for tv's(tube tv's), a better type of flybacks are ac flybacks but those are harder to find)you can also find them in old tv's
2.about 8v minimum(normal use 12-24v) at about 5a (but for 24+v i suggest a 10a transformer/powersupply) make sure you have a high amperage inductor tho(mine blew up)
Safe_Volts
1 year ago
I had built my ZVS driver. My only problem is with the 2 inductors. They get hot when I draw 6 amps at 24 volts from power supply. My ZVS driver deisgn is the one with no center-tap required. what could be the problem? Inductor core is 22mm X 14mm X 8mm, yellow-white colour
ArjitS1
1 year ago
Ohh my phone keypad is now crazy making mistyping
ArjitS1
1 year ago
So ....... After the thinking deep now my explanation is for why negative terminal of flyback transformer heat more then positive one , this is because when high voltage breakdown the air between it , by hight voltage potential and plasma then the air should breakdown in two parts one elecerons and other air's positively charged ions that moves opposite from electron direction , so because positive ions are massive then electron it carry heat of that plasma from the air towerds negativity charges electrode . That's it . !!!!
