ZVS Flyback Driver - Video
8,813
6
35
About: ––––––––––––––––––––––– "Energy cannot be created nor destroy...
It has been a long time since I have posted anything, lol.
I have recently got more sealed lead acid batteries so I can now power my ZVS flyback driver up to 36 volts! I will try find some time to make an instructable about making one of those beast, at the moment, I can show the vid of it working. :-)
    • Tape Contest
      Tape Contest
    • Arduino Contest 2019
    • Trash to Treasure
      Trash to Treasure
    35 Discussions
    Hey, could you tell me how to modify the schematic to make an induction furnace?
    jukeesMvtnns
    Reply 6 years ago on Introduction
    yes, it is possible, made it and took 40kV zap from it, wasn't nice. :D
    but the arcs climb nicely.
    JoeBeau
    7 years ago on Introduction
    What is the minimum voltage required to run a ZVS driver? I was planning to run mine at 5 volts (at 22 amps) and use different MOSFETS. Would it be able to run at 5 volts or would I have to make modifications to the circuit?
    Alex1M6
    I have seen this video several times but it is still awesome!
    PlasmanaKaiven
    Awesomesauce... lol thanks!
    I am pretty sure it does, probably in a newer NST, but I never seen the insides of one of those things.
    KaivenPlasmana
     I don't know what a ZVS or NST is... xD
    I guess I wanted to know more of what this is used for.
    PlasmanaKaiven
    Hehe sorry, I get carried away using abbreviation and expect everybody to know it sometimes.. :)
    A ZVS is Zero Voltage Switching (I know, its very technical :P)
    A NST is Neon Sign Transformer
    XellersKaiven
    No, you cannot use pure monatomic halogens because they are not stable elements like the noble gasses are. In fact, fluorine is so unstable that it is almost never found in its pure form; that's why they're called "Oxidation Numbers" and "Reduction-Oxidation Reactions" and not "Fluoridation Numbers" and "Reduction-Fluoridation Reactions." Chemists thought that oxygen was the most reactive element on that side of the table simply because fluorine was never found in its pure form. It's called "oxidation" because oxygen has a tendency to strip atoms of their electrons in order to form its standard state diatomic (remember BrINClHOF?), it would have been called "fluoridation" if fluorine were less reactive.
    You might then ask, "why not use their more stable diatomics or other molecules that are gasses at SATP?" One reason you might want to use noble gasses is that all of their orbitals are completely filled and they are monatomic in their standard states, in other words, they have the lowest excitation energies. If you use diatomic, triatomic, etc. gasses, then you need to break more stable sigma, pi, etc. bonds than you would if you used a monatomic gas. This translates to a lower breakdown voltage for noble gas excitation and this means that you can use simpler equipment. For example, to make a good sized Argon discharge a few feet long tube, you don't even need a vacuum pump with a standard 20kV power supply. To contrast to this, you would only be able to get an inch long discharge in free air (mostly O2 and N2 gas) with the same power supply.
    ubr.bzkrXellers
    Did you really expect him to understand what you just said? I mean you don't even learn about sigma and pi bonds until college chemistry or AP chemistry.
    KaivenXellers
     Umm...I'll come back with a reply after I take chemistry... or science...lol
