Zip Tie Bike Traction Chain
3,646
60
16
Never slip on an icy road again with your bike. Use zip ties to act as chains around the wheel
Step 1: Supplies Needed
12-inch zip ties
Scissors
Step 2: Loop the Zip Tie Around Weel
Wrap the zip tie around the wheel and pull tight the cut excess
Step 3: Placement
Put the zip ties about every 4 inches to keep constant contact with the ground.
Zip Tie Challenge
Runner Up in the
Zip Tie Challenge
    • Gardening Contest
      Gardening Contest
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    16 Discussions
    live4ktm
    3 years ago
    Brilliant ! When ibles has a "zip tie" contest, you have my vote. Note: to make them really tight, simply deflate the tire about 10 lbs. before installation, then reinflate after installation.
    Solamar
    3 years ago
    Nice
    gkeck
    3 years ago
    the best but can u make this
    EkrasCraftAndu
    Reply 3 years ago
    Yes this would be more effective if he used disk or drum breakes instead of the rim breakes.
    Sqidman31
    3 years ago
    Bear in mind, this only applies for bikes with disc brakes or coaster (backpedal) brakes.
    MarkJ92Sqidman31
    Reply 3 years ago
    Agreed. This hack won't work with any rim brakes, e.g. road calipers, cantilever or v-brakes....
    Roentgenium111
    3 years ago
    In the pictures you took, I noticed that the side of the zip tie that is against the rims is the "notched" side. The side of the zip ties that have contact with the ground is the smooth side.
    Bossert4212
    3 years ago
    I have not noticed a difference. I don't understand what notche side you are talking about? The place where it sticks into the other?
    Roentgenium111
    3 years ago
    Have you noticed any significant difference? And also I noticed that the smooth side of the zip tie is what hits the ground. Couldn't it be better if it was the notched side?
    mrgw98
    3 years ago
    Still be careful around turns. Do not go to too fast. Also do not use bikes with too thin of tire tread. I have learned my lesson from these things!
    Bossert4212
    3 years ago
    It is meant for the ice so very good. It lasts for very long time. A zip tie might break every once in a while, but you can just replace it easy
    Just4Fun Media
    3 years ago
    That is a great idea. How does it perform on ice? And how long do the zip ties last?
    Have a great day! :-)
