Zipper Sweater Transformation
2,142
55
4
I found this great old zipper at my local Scrap. Here's a list of creative use centers around the US. It's awesome and fun to dig around random abandoned stuff looking for materials just waiting to be turned into something.
I decided to add the zipper to this comfy sweater that was in need of a little extra something.
Supplies:
Step 1: Materials
sweater - pick one you like but is a bit boring
zipper - mine was about 16in and I trimmed it down. The size is up to you and how you want to style it.
straight pins
sewing scissors
thread
needle
fabric glue
ribbon (1/2")
double fusible web/interfacing (strip/ribbon type is most convenient)
towel
clothes iron
Step 2: Positioning
Pin your zipper where you want it.
Step 3: First Stitch
Stitch the outside edges of the zipper to the sweater with your needle and thread.
Step 4: Trimming the Zipper
There are lots of ways to shorten a zipper, but since mine was plastic, I decided to melt the end with a lighter to create a new stopping point.
Step 5: Zipper Bottom Finishing
Cut the zipper out of the fabric edging below the melted section.
Cut off all but about a 1/4" on one side and fold under. Stitch it in place.
Fold over the other side and trim off about a 1/4" past the edge of the opposite side. (see image) Tuck under the last 1/4" and stitch in place.
Step 6: Fusing
Lay a strip of double fusible web inside the length of the zipper.
Zip it closed.
Turn the iron inside out and place a rolled up towel inside. The towel allows you to iron as little of the sweater as possible (mine was partially synthetic) while fusing the zipper to the sweater inside the zipper. Use the point of the iron along the edge of the zipper. Don't run the iron along the plastic of the zipper. You wouldn't want to fuse the zipper to itself or the webbing.
Step 7: Cut the Sweater
Cut the sweater down the center of the zipper. The fusible webbing should keep the sweater from unraveling.
Step 8: Finishing
When you unzip the zipper, one side is visible as it flops down. Stitch the ribbon to the visible size.
The side that is not visible is up to you. I didn't feel like adding ribbon where it wouldn't be seen, so I added fabric glue to ensure the sweater wouldn't unravel later. The fusible web is good for a temporary hold while you're working or on a more tightly woven material, but this sweater had a very loose knit in sections and needed a bit more security.
Step 9: Enjoy!
Zipped or unzipped, this sweater is fun and comfy.
Wear It! Contest
Second Prize in the
Wear It! Contest
    • Arduino Contest 2019
    • Woodworking Contest
      Woodworking Contest
    • IoT Challenge
      IoT Challenge
    4 Discussions
    eeVee
    4 years ago
    i always look for the off-side zipps. Pretty hard to find and usually crazy expensive. well done!!
