Amigurumi Crochet Pattern Two Little Bear Amanda and Annie
About: Hi, I am Jane the girl behind " Jennyandteddy " crochet and crafty blog, is a place where I share my free easy crochet tutorial. Come to said hi.
Finish Size
-Approximately 5.5-6 inch tall
-Size of Amanda and her sister may varies depend on size of yarn and crochet hook
Materials
To make you will need
1. Acrylic yarn in this pattern, I normally used 8 ply
2. Plastic eyes with safety backing 7.5mm (you can find it at any craft shop)
3. Fiber fill for stuffing
4. Sewing pin
5. Ribbon or button
7. Crochet hook size1.25mm or 3mm and craft glue
Pattern is in my blog.
http://www.jennyandteddy.com/2010/09/free-amigurumi-pattern-two-little-teddy-bears-amanda-and-annie/
Skill and abbreviations
You will need to know how to make a magic ring or adjustable ring
-Single crochet (sc)
-Crochet increase (inc) which mean-make 2 single crochet in same stitch
-Crochet decrease (dec) which mean-Crochet 2 stitches together
-Stitch (st)
* = Repeat stitches from * to end of *
-Chain (ch)
-Slip stitch (sl st)
-change colour
Step 1: Head and Ears
Let’s start with head
Brown for teddy
White colour for panda
You will work from top to bottom
Round1. Make magic ring and 6sc in ring (6)
Round2. 2sc in each st around (12)
Round3. *Sc in next st, 2sc in next st* and repeat from * around (18)
Round4. *Sc in next 2 st,2sc in next st* and repeat from * around (24)
Round5. *Sc in next 3 st,2sc in next st* and repeat from * around (30)
Round6. *Sc in next 4 st,2sc in next st* and repeat from * around (36)
Round7-12. Sc in each st around (36)
Round13. *sc in each of next 4 st,dec 1* and repeat from * around (30)
Round14. Sc in each st around (30)
Round15. *sc in each of next 3 st,dec 1* and repeat from * around (24)
Round16. *sc in each of next 2 st,dec 1* and repeat from * around (18)
Round17. *sc in each of next st,dec 1* and repeat from * around (12) then finish of and leave long tail for sewing. And stuffing polyester firmly.
Ears
Brown for teddy
Black colour for panda
For bear make 2 pieces (brown)
Round4-7. sc in each st around (18)
Then finish of leave long tail for sewing and stuffing polyester just a little .
For panda make 2 pieces (black)
Round4-5. sc in each st around (18)
Step 2: Arms, Body and Legs
Arms
Brown for teddy
Make 2 pieces
Round1. Make magic ring and 8sc in ring (8)
Round2-11. sc in each st around (8)
Then finish of leave long tail for sewing and stuffing polyester just a little.
Legs
Brown colour for teddy
Make 2 pieces
Round1. Make magic ring and 10sc in ring (10) (black colour for panda)
Round2. sc in each st around (10) (black colour for panda)
Round3. sc in each st around (10) (black colour for panda)
Round4-10. sc in each st around (10)
Then finish of and stuffing polyester just a little.
Step 3: Dresses
Dress we will work from top to bottom.
Yellow for teddy
Pink for panda
Round1-3. Sc in each st and around. (18)
Round4. *Sc in next 2st,2sc in next st* and repeat from * around (24)
Round5. sc in each st around (24)
Round6. *Sc in next 3 st,2sc in next st* and repeat from * around (30)
Round7-12. sc in each st around (30)
Round13. sc in each st around (30) white and finish off.
Finishing
Sew nose to the face and ears to the head.
Then attach dress to body by sewing, then attach the head and arms.
  • Paper Contest
    Paper Contest
  • Sweet Treats Challenge
  • Warm and Fuzzy Contest
14 Discussions
mandolin.woodstarkec
you can use an I but when you go to stuff the bears you will see the white fiberfill stuffing through your stitches making the bear less cute. I have made quite a few little creatures and recommend an f hook if you crochet loosely or a g hook if you tend to crochet tightly.
Check out my etsy shop to see what i made. The lion, apple and hedgehogs are made with an f hook.
http://www.etsy.com/shop/AgapeLiving
jennyandteddystarkec
any size of crochet hook will work fine,however the finished size of the doll will be slightly different.
Rayney
8 years ago on Step 2
I am lost here. What part is the body? Sorry,I am new to this.
jennyandteddyRayney
Reply 8 years ago on Step 2
crochet the leg first then joining two leg together to make body for the body part is in my blog.
Rayneyacosicris
Hon, if you can chain, you can single. I am just learning myself. It is confusing at first but I went to you tube and looked it up. My mom has been showing me when she comes over on the weekends but you tube really helps a lot too.
