Bfo Metal Detector
90,316
108
50
Simple BFO metal detector
BFO ( beat frequency oscillator ) metal detectors use two oscillators, each of which produces a radio frequency. One of these oscillators uses a coil of wire that we call the search loop. The second oscillator uses a much smaller coil of wire, and is usually inside the control box and is called the reference oscillator. By adjusting the oscillators so their frequencies are very nearly the same, the difference between them is made audible as a beat note, this beat note changes slightly when the search loop is moved over or near to a piece of metal. It has been found in practice best to make the search oscillator fixed say at 100khz and to arrange for the reference oscillator to be adjustable 100khz plus or minus 250hz. This gives a beat note of 250hz to 0 to 250hz. The beat note disappears or nulls when the two oscillators are about equal. This type of detector is most sensitive when the beat note is close to zero, about 5hz ( motor boating ) any slight change being noticeable.
Supplies:
Step 1: Parts
Parts list
Power source:
Any 9v battery PP3 is ideal.
Capacitors:
2 off 220uF 16v electrolytic.
5 off .01uF polyester.
5 off .1uF polyester.
Resistors:
All resistors 1/4 watt 5%
6 off 10k
1 off 1K
1 off 2.2m
2 off 39k
Transistors:
All BC 183B. Just about any small signal npn with a gain of 250+ will do. There are hundreds to choose from.
Audio output:
A 2.5 inch 8 ohm speaker will work but headphones or earpiece are preferable the higher the impedance the better.
Many of the above parts could be salvaged from a broken transistor radio.
Once the components have been obtained the circuit can be built in a few hours using copper clad stripboard, or if you the facilities make a printed circuit board using the layout below. The original layout as below should print out at about 50mm x 100mm.
Step 2: Coils
Coils
This is the only tricky part. The search loop is best wound on to a plywood former. Method 1: Cut three circles from some 3mm plywood, one 15cm diameter and two 16cm diameter. Using wood glue make a sandwich with the 15cm circle in the center. When the glue has set you can wind 10 turns of . 25 mm swg enameled copper wire around the groove in the edge of the former. Connect this coil when finished to the points marked coil 1 on the schematic. Method 2: Cut a 16mm diameter circle from some 10mm plywood. Then with this circle clamped in a vice run a saw around the edge of the circle so as to make a slot about 5mm deep and 2mm wide around the edge to accommodate the windings. If you have access to an oscilloscope or frequency counter make a note of the frequency. Ideally This coil will be oscillating at about 104khz, with an amplitude of about .5v p to p. The second or reference oscillator needs to be made much smaller and if possible attached to the control box so it can be adjusted as the detector is used. To make a really good adjustable reference oscillator you will have to visit a DIY store, what you need are some plastic water fittings, two examples are shown below. The smaller one is the inlet pipe to a plastic ball valve assembly fitted with a brass nut. The larger one is a plastic tank connector fitted with a brass nut from an old tap. Both of these work well and are glued to the control box in a position where they can be adjusted. The reference coil itself is wound on a piece of wood or plastic about 10/12mm diameter and about 50mm long The actual number of turns of this coil depends on the diameter of the former and can only be found by experiment. Start with about 125 turns . 25 enameled copper wire ( this coil when finished has to fit inside the plastic tube ) and remove turns until the two frequencies are close. This coil is attached to the circuit board at points marked coil 2. If all is well the detector should be howling at this point. When the two oscillators are well matched it should be possible by adjusting the brass nut in or out to bring the beat note to a halt or null.
Note. On the working detector shown in these pictures we wound 10 turns on to the searchcoil which then oscillated at 104 khz Then we wound on to a piece of 12mm dia x 50mm long wooden dowel ( taken from a bird cage ) 120 turns of wire. This was pushed inside a threaded plastic tube from a ball valve assembly. This oscillated at 96 khz without the brass nut and increased gradually as the brass nut was screwed on up to 106 khz. This was perfect for tuning the detector.
Searchcoil made from 10mm thick plywood
The reference coil is wound on to a piece of wooden dowel about 12mm diameter x 50mm long. This has to fit inside the Plastic pipe fitting above, and is tuned by moving the Brass nut. Drill a very small hole 1mm through each end of the wooden dowel so that you can pass the beginning and end of the wire through these holes to keep the windings in place.
Step 3: Coils2
This large coil is 30cm wide by 60cm long ( 12 inches by 24 inches ) and is made from 10mm plywood. It has 5 turns of wire in a 3mm deep groove cut around the edge with a saw. it oscillates at 104 khz . If you want to make different size coils start with the big one, as with only 5 turns you can only alter it in big jumps eg. 4 turns = 115 khz and 6 turns = 85khz . next make the reference coil to match. next make the next smallest coil and so on. The smaller coils are easier to match up as adding or removing a turn at a time only alters the frequency in small amounts
Step 4: Building a Parktical Detector
Building a practical detector.
Building a practical detector for outdoor use will depend on the skills and materials at your disposal. The golden rule is keep it lightweight, avoid using heavy materials such as hardwood or perspex. The round search loop needs to be glued to some sort of handle, with the circuit board inside a small box at the other end for balance. You will need to adjust the reference oscillator from time to time when in use.
Step 5: Instruction
Coil A = Search coil: Coil B = Reference coil: NC = No connection: B+ = Battery + 9V PP3 or similar : B- = battery -
Step 6: Notes
Notes for the electronics beginner.
2 off 220uf / 16v Electrolytic : These are 220 microfarad / 16v working voltage. You can use a higher working voltage but not less. Higher working voltage capacitors work just the same but they get physically bigger. They have a negative lead that must be connected to the battery - track. These components must go in the correct way round.
5 off .1 and .01 polyester : These also have a working voltage. 63 volt in quite common and will be ideal. If you want to use the pcb layout above you will need capacitors with 5mm lead spacing. .1 can be marked as .1 or 100n or sometimes 104 : .01 can be marked as .01 or 10n or sometimes 103. These components can go in any way round.
All resistors 1/4 watt 5%: These are general purpose carbon film resistors with a 5% tolerance and rated at 1/4 watt. You could use resistors of a higher wattage as this does not affect the working they just get bigger. 1 watt or bigger will not fit on the board. These components can go in any way round.
Transistors: The bc 184b transistor is described has Audio, low current, general purpose NPN . These are quite easy to get in the UK but may be difficult to get in other countries. There are hundreds of types of small plastic NPN transistors available around the world and just about all will work in this circuit. You will have to be sure of the pinouts though. You can get the pinouts for most transistors from manufacturers websites. This will be the most likely problem area when building this project. These components must be connected correctly. PNP types won't work.
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    50 Discussions
    DennisD153
    4 months ago
    I've seem this other blogs for many years.I try to simulate in falstad the 2 oscillators really work!
    MohamedS312
    2 years ago
    what is the range of detection for this circuit ? if i need 30 cm range , is it good for that ?
    TheDoubleZ
    2 years ago
    I have trouble reading circuits, so can you please show me how and where to put each part please?
    PeterH324
    2 years ago
    im trying to build this as a design project for my electrical classes. i would like to see a full shot of the metal detector to get a full perspective of what went where and what all was going on.
    guilherme figui
    2 years ago
    when can the zero rate and does not accuse the presence of metals which can be cause?
    I did the site http://detectordemetais.r30.com.br/detector-de-metais/circuito-detector-de-metais-caseiro/
      Only fit as I approach the soldering iron connected to the network 110v .
    daniellong2
    4 years ago on Introduction
    could I use a ferrite instead of a search head for using it as a pin pointer?
    I have applied the circle and managed to run and I knew the secret operation to inquire and communicate call 771597465: 773628926 or
    Aoabr Facebook: Ahmed الصلوي of the Rahal or around the world
    hhmed2020@hotmail.com / / or / / lphwv@hotmail.com
    paulinex127
    7 years ago on Step 5
    hi! i would like to know where the 220 uf electrolictics connect, because the two
    have the B-, and if possible where the two electrolictics are going to connect.
    Best regards,
    Paulino Alves paulino_al@iol.pt
    p.s. i´m trying to build your project, but i don´t understand what i mencioned!
    tesladude123
    7 years ago on Introduction
    I have just bought a GC-1005 metal detector from ebay,
    is this good to get started with?
    please replie
    baker amin
    7 years ago on Step 2
    Hi,
    thanks for this instructable. Can I use this method to make a security system like those we see in airports, those which look like doors that passengers pass to check them.
    jack002
    8 years ago on Step 5
    No connection means the wires at the junction there at the bottom where the one goes up and down and the other goes left and right do not connect. The one passes over the other. The bottom of the 10K resistor will go to the base of Q3 and will NOT connect to B- but pass over it.
    toben222
    hey, sorry, but really: what does NO CONNECTION mean...? where should i connect the 10K ???
    Azaylestoben222
    It means the two wires crossing over each other are two separate wires, and not connected at the node.
    bobberts
    can anyone tell me how to figure s voltage drop across any of the resistors??? cause there's no ground in this circuit :s
    jaschhina
    8 years ago on Step 2
    Hi ,
    I am working on project of metal detector .
    Could we find out that how far it can detect.
    if we want more distance metal to detect what I have to do for it.
    Thanks
    easytreasureanasko
    You can find the original of this project on my site http://www.easytreasure.co.uk
    this is where it was stolen from. There is also a video of it working here
    http://www.youtube.com/watch?v=aSqmFWtoXYw
    If you check it out on my site there is nothing to pay its free.
