Black Pipe Shelf
5,941
108
About: about what?
needed storage so this is what I came up with
Step 1: First Off Acquire Some Black Pipe and Fittings From Your Local Hardware Store
I bought
4.. 10ft lengths of 1/2inch black pipe
3.. 1/2 in 45° fittings
9.. 1/2 in T's
15..1/2in hand rail ends
3.. 3/4inch x 12in x 12ft long pine board.
box of 1'1/2 screws
a pack of #8... 1' ribbed plastic anchors
Step 2: Measure 3 Times Cut Once! Then Weld
I need space in my newly almost completed attic. so I decided on using black pipe to make shelves and instead of buying precut lengths I decided to cut and weld it all together. this idea sucked because getting everything aligned, was a hassle but I figured it out.
basically I spaced the the shelves 16 inches apart and made them 24 inches deep
I left the threaded end at the bottom for minor adjustments when screwing to the wall, ceiling and floor
Step 3: Paint
I used rustolium metallic spray paint
Step 4: Wood
I cut the 12 ft boards in half then drilled pocket holes and glued and screwed them together to make them 24in x 6ft long. after the glue set I burnt the wood to darken it then I stained it with dark stain
Step 5: Installed
Step 6: Storage Compartments
I bought 2 wooden crates from home depot and stained and charred the wood to match then coated them as well as the shelves with some polycrylic... then installed them with drawer slides.
I know they aren't designed to be used this way but it works for now so until it fails I'm keeping it this way.
also i put a substantial amount of weight in the crates to see how the drawer slides would react and they didn't have a problem and still moved freely
    • Build a Tool Contest
    • Tape Contest
      Tape Contest
    • Paper Contest
      Paper Contest
    AdamC20
    3 years ago
    Burn and Stain looks great!
