Compost Tumbler
28,810
62
13
this compost tumbler is portable it is also my first instructable
Step 1: Get a Barrel
find a barrel with a lid you can get one at freecycle.org
Step 2: Get Tools a Materials
Materials
- barrel
- plywood about the size of the barrel
- 3 sets of skateboard wheels
- 2 L brackets
- a handle
- 2 small blocks of wood bigger then the wheels
- peice of wood the weight of the barrel
Tools
- drill (an electric/corded drill works best for this job)
- 3/8" and 1" drill bits
- screws
Step 3: Drill Holes
with you drill make hole thoughout the whole barrel
Step 4: Put Wheels On
drill on set of the wheels on bottom to one end
Step 5: Tumbler Wheels
With the other wheels put them in the middle of the plywood on the other side about a foot and a half apart
Step 6: Handle
put the handle on the same side that has the 2 sets of wheels but the other end of the wheels on bottom
Step 7: Back of Wood
put the wood that is the height of the barrel on the same side as handle but other end
Step 8: Blocks of Wood
put them on same side as the one set of wheels but to the other end and spread them apart
Step 9: Put Barrel On
now put the barrel on the wheels and you are done
    • Tape Contest
      Tape Contest
    • Trash to Treasure
      Trash to Treasure
    • Jewelry Challenge
      Jewelry Challenge
    13 Discussions
    Bubbler
    7 years ago on Introduction
    The one thing of upmost importance that I found missing was the loading door. To take the screw top lid off of the barrel would be way to awkward in muy opinion, and so I think the a carefully planned door by cutting out a section of the side, would be needed. Otherwise, this is a brilliant Instructable. I have kept away from making rolling composters, because of the idea of having an axle through the middle. I would also have a collector tray underneath bacuase the nutrients from that would be good for plants, or simply poured back through the composter. I agree, this is the best idea use of a skateboard yet. LOL
    duhfuss
    9 years ago on Introduction
    I like the thoughts in your design; however, I think it may be difficult to execute when composting.  First, the oddly shaped barrel will most likely not stay balanced on a single pair of wheels as the compost shifts inside the barrel when turning.  A barrel shaped more like a complete column with two sets of wheels has always worked for me.  Second, I really like the idea of moving the compost to where it is needed, but bigger/stronger wheels will be needed  to roll over the lawn or garden paths.  I have made several compost tumblers with the external wheels like your design and I may add the movability design in my next construction.
    pleabargain
    It would probably begin to leak smelly water as well through the air holes. An outside composter IMHO.
    nlevan01
    9 years ago on Step 8
    He meant on the opposite side as the wheels. When it is flipped back over those legs will keep the barrel from moving off the backstop.
    dbinvt
    Great project, nice design. Could use some additional directions on use.
    Z..
    Just to add something positive.. As a first instructable, this is very good! I won't put one up because I'm old, ugly, and could not take being criticized after making such an effort.. Nice first try son.
    MalKnowles
    this type of composter is ok, but you must add water to promote rotting, and plenty of air-holes to allow aerobic decay otherwise you get a wet, soggy mess of stinking stuff. High nitrogen vegetation like lawn mowings will rot better if the pH is raised by adding lime , don't waste money on expensive decay promoters. The plastic barrel should be rotated ccasionally.
    uguy
    Your context is extremely confusing.
    But, the absolutely best use of a skateboard I've ever seen!
    karossii
    punctuation seconded! also, you may wish to add a step or two on how to use this. i can easily see it is manually rotated tumbler, but there are those who don't know what compost is (or how it is made) much less how to use a tumbler. In the least, a link to another source for that information would be useful.
    mrdepo96
    good idea, but revise the punctuation and it would be much better. ;)
