Cookie Monster Rug
150,860
689
60
About: Build.Share.Destroy.Repeat. Follow me and try a few of my projects for yourself!
Om nom nom!
Bring everyone's favourite cookie eating monster home with your own cookie monster rug. This iconic blue abomination was just begging to be remade into a bear skin rug. Using blue faux-fur fabric and some other textile supplies, I was able to make this rug in under an hour. This soft rug is great for kids, and the cookie pillows really make it complete.
Better hide your cookies, as this furry blue monster is ready to steal all your goodies (and then your heart)
Ready? Let's make!
Step 1: Supplies
To make your own monster rug you're going to need blue monster fur. You can usually find this at your local fabric shop, but you may need to hunt around a little. It's not that special, but smaller stores might not carry it. For this project I only needed one yard of blue fur (sold in a 6' width).
You're also going to need one package of white yarn and two black buttons for the eyes. An optional step would be to cover the underside with faux leather, which adds stability to the piece.
Step 2: Trace Hand
I started by tracing my hand on a piece of blank paper. I then sketched around the trace until I had a hand shape that had shorter and wider fingers. Then, I cut out the hand shape with scissors.
Step 3: Trace Outline Onto Fur
Start by folding the fur in half with the fur on the inside of the fold.
Using the paper hand cutout as a template I sketched an outline of the hand and the rest of the monster body. Since the fabric was folded in half I only needed to sketch out half the design. I went for a wider design, giving me lots of fun fur in my rug.
Step 4: Cut Outline
When I was happy with an outline shape I used a sharp hobby knife to carefully cut through the top layer of fabric. Take time cutting around detailed areas like the fingers, this detail will show up on the rug.
Step 5: Flip That Fur
After cutting out one side of the design flip the fur over and fold in half, this time the fur will be on the outside of the fold. Now you can cut the other side of the monster rug out using the previously cut side as a guide.
Step 6: Unfold
With both sides of the rug cut out you can unfold the fur and check out your shape. Now is the time to make corrections to any cuts made previously, or clean up any loose fabric bits.
Now we can move onto the eyes.
Step 7: Eyeballs
Part of this monster's charm is his goofy eyes. I wanted this rug to be as soft as possible for children, so I made these eyes from regular white yarn.
Start by bunching up one end of the yarn, then wrapping the bunched yarn with tight winds, then start working the windings into a more spherical shape. After one eye was a little larger than a golf ball I stopped winding and started the other eyeball.
To prevent the yarn from unraveling after winding I tucked the end loosely under the previous winding and pulled tight. We'll stitch the yarn eyeballs next to secure the yarn and prevent any unraveling.
Step 8: Stitch Eyes
A needle and white thread was used to sew a few stitches through the yarn eyes around the tucked end of the yarn, and around the entire eye to ensure the yarn windings stayed securely wound.
Step 9: Add Button Pupils
I used black plastic glossy buttons for the pupils on the eyes. Using more white threat and a needle the buttons were sewn onto each yarn eyeball.
Step 10: Attach Eyes to Head
The eyes are held in place with thick white embroidery thread. After each eye was attached to the head of the fur rug the eyes were stitched together to provide stability. This monster has crazy eyes, so remember to place the eyes a little crossed.
Step 11: Head Structure
Taking a page from real animal fur rugs, I decided to add some structure to my monster fur rug to enhance the look. Using dense flexible foam to make a head, I started by making a disc shaped cut out and beveling the edges. I then cut a smaller disc shape and used spray adhesive to stick them together. This squashed dome shape would be the soft head structure for my monster rug.
The foam discs were then glued to the underside of the head using more spray adhesive.
Step 12: Rug Underside (optional)
Your monster rug is almost done. If you want a more finished look you can line the underside with faux leather.
Lay your monster rug on top of the faux leather and cut along the outline using a sharp hobby knife. I used more spray adhesive to connect the faux leather to the underside of the fur.
Step 13: Fluff Out Fur
Fluff out the fur around the edges, trim the fur with scissors if needed and cut back any excess leather.
Step 14: Cookie Pillows - Outline
What would this furry friend be without some large plush cookies to go along? I made large chocolate chip cookies from some soft beige fabric. I used a large dinner plate to trace the outline on the underside of the fabric, then cut out two identical circles from the trace.
Step 15: Sew Together
With the underside facing out, the fabric circles were placed on top of each other and sewn together along the edge. Make sure to stop sewing when you're almost all the way around, but don't sew the cookie entirely closed yet, you'll need to have some room to turn it right side out.
Step 16: Add Chocolate Chips
Using a darker plush fabric I cut irregular squarish shapes, and cut enough to speckle over the top of the cookie.
Step 17: Glue Chips
To hold the chips in place I used fabric glue. I put a small dab on each chip and pressed it in place.
Step 18: Sew Chips
Once the glue had dried I hand sewed each chip onto the cookie surface to ensure a secure connection.
Step 19: Stuff Cookie
I used pillow batting to stuff the cookies through the opening I left when I was sewing the two halves together.
Step 20: Sew Cookies Closed
Once stuffed, the cookies were sewn closed with beige thread.
Your fur rug and cookie pillows are now done! Time to place that rug and enjoy.
Step 21: Get Ready for Baby Overload!
This rug is sure to be a hit with all the kids. Grab some milk and cookies and relax on your own monster fur rug!
Have you made your own cookie monster rug? I want to see it!
Share a picture of your version of this project in the comments below and be awarded a 3-month Pro Membership on Instructables.com.
8 People Made This Project!
  • Fat Challenge
    Fat Challenge
  • Pie Contest
    Pie Contest
  • Jewelry Challenge
    Jewelry Challenge
60 Discussions
winneremerald12
6 months ago
This is like, the greatest idea ever. I read every single step, and might just make one for my baby sister.
ohoilett
2 years ago
The cookies are my favorite part. Lol.
ohoilett
2 years ago
This is great. Nice work.
Nancy Kossina
2 years ago
When purchasing vinyl for underside be careful the widths are different than fur. Vinyl was only 54 inches wide instead of 60".
One80Bits
3 years ago
I'm so grateful for your tutorial, I love this lil rug now and want an adult size one as it's so comfy! I added some blockout curtain material as a base and filed it with a layer of wadding. I also made the eyeballs black felt as I wanted it completely baby proof. thanks again!
mikeasaurusOne80Bits
Reply 3 years ago
That's adorable, and great call with the soft eyeballs!
Thanks for sharing a picture, enjoy the Pro Membership!
3118130
3 years ago
I love it so much
You sir are brilliant. I actually found this because I was googling "Cookie monster side view". I love it when random googles lead me back to instructables! This is the exact rug my husband asked me to make once he saw the two yards of blue fur that I had distressed for a cookie monster puppet. I'm now wondering if I should use the scraps to make this awesome rug (was thinking of making a grover puppet). Thanks for saving me the time of coming up with an adorable pattern idea. I especially love the cookie pillows!
I also love being led back here after searching the Internet for something; it's always nice to come 'home' :)
Glad you like this, I have my Cookie Monster rug over my couch and adore it. I'd love to see your creation when you're done!
Sorry it took me 3 whole months to take a photo of my cookie monster but better late than never!
https://flic.kr/p/wvdkG7
Your Cookie Monster looks perfect! He eats cookies, too?!
You're awesome!
Thanks for sharing a picture of your Cookie Monster, enjoy the Pro Membership!
RollerScrappermikeasaurus
Reply 3 years ago
Thank you! One day i hope to be able to do an instructable, i took photos, but just need the time to do a write up! He can eat cookies and even a telephone receiver, just like the real deal, i saw a photo of the real cookie monster and he had a hole in his mouth so I had to add one!
krystaljazmin
3 years ago
Do you have extra to sell? I suck at DIY ?
elliotnash
3 years ago on Introduction
Wow, you killed the Cookie Monster? :D Anyway really cool tutorial. I guess I'll try and make a similar rug for my daughter.
