Fabricating PCB
51,253
491
38
About: i m an undergraduate student, trying to share my ideas with everyone possible and eager to learn new tech stuff
Generating a final printed circuit board for anyone's circuit or project is a tedious work, either print it which takes time or order it online which takes much money,
This tutorial is about printing (the already designed circuit in eagle cad or any other alternative )
the circuit onto a single layer copper sheet(known as copper clad).
Step 1: Arrangements
- Copper Clad
- Iron (Press)
- sand paper
- water in bucket
- FeCl3
- dish wash
- scrub
- drilling machine
- acrylic spray(optional)
- solder wick
- solder wire
- solder wax
- solder station
Step 2: Clean Copper Clad
we have to clean the copper clad so as to remove the oxide layer deposited over it over time
To do so take any sand paper and rub it over the copper clad preferably in one direction until the surface looks shiny and bright
Step 3: Print the Layout
Be very careful about printing a layout file
A laser-jet printer and a photography paper should be used to print the circuit.
Photographic paper has a tendency to loose the ink spattered on it by the laser printer.
tips and tricks----
apply thicken or harden option while printing it makes circuit print even more dark and equally proportionate in darkness everywhere.
after we have circuit on paper
hot the iron(press) and put a hard surface on table put the copper clad on it and the printed layout inverted over the copper clad and apply constant heating with press over it applying little force over it exactly for 1 and a half minute to 2 minutes all over.
after pressing put it under some water and gently scrap of the paper over the copper clad and the result should be like shown in photograph
Step 4: Little Tips
the press should be kept at a setting of cotton
because a little high heat can damage the copper clad hence pcb wont work
fecl3 i used was diluted by just approximation
high concentration wont do great harm but can dissolve copper tracks too so fecl3 should be diluted but not too much then it can take a day or two to finish.
make soldering rod pre heated at 180^c
Step 5: Scrap Useless Copper
when you will have the printed board put it in fecl3 diluted acid
and keep agitating the solution having the board for like 15 minutes
(don't forget to put on the rubber gloves)
check if all the copper have left the board's surface.
afterwards clean it with water;
and wash it like any usual dish(utensil) with a scrub but try to wipe only in one direction
and what you will get is the visible golden brownish tracks
and as soon as you wash it dry it with tissue and spray acrylic spray so as to protect copper from reacting from gases in atmosphere
Step 6: Drilling
i did used a dremel drilling machine to drill holes in board
but one can use a hand drill too
Step 7: Soldering
Soldering is a process in which two or more metal items are joined together by melting and flowing a filler metal (solder) into the joint.
soldering is the most important part of any circuit which can make any of it work better, look better and again work for longer time
There are little tips and tricks for that
-Use of proper iron tip
that comes in huge variety like well shaped or conical in various shapes and sizes
so for pcb designing a conical with small aperture would work great
-the solder should be pre heated before actual task(180^c is fine)
-solder wick can be placed over soldered area and heated to suck of that copper
Step 8: Implementing the Soldering
-firstly make your workspace free
-after that put solder rod on your dominating hand side
-component placement
any component have to be put according to its size arrange all components in a tray or plate and put them in an order of increasing sizes
-insert component of smallest height in the holes of board then just tilt the wires from opposite side a little bit so component dont fall and then gently put the hot rod on area and after 2 seconds apply the solder wire over it touching rod and area simultaneously
-slowly remove the wire first and the rod later
-you can inspect that with any magnifying glass
-put all components in accordance to their sizes and there you have your pcb
-finally check with multi-meter the board if it is short at places needed or not
but put multimeter probes at joints only as on tracks the acrylic is still there but due to heat that has been removed from the joints..
Soldering Challenge
Runner Up in the
Soldering Challenge
  • Woodworking Contest
    Woodworking Contest
  • Classroom Science Contest
38 Discussions
Jose FR
Question 8 months ago
Which proportion water/FeCl3 do you recommend?
--scientists--
2 years ago
What is thicken or harder option
Tumbleweed.
3 years ago on Introduction
Nice instructable, I was thinking of making one myself since this is a valuable skill for any electronic application and I feel that too many people depend on pre-made modules.
I use a similar technique but more simple:
1. Print the Schematic on a transparent foil instead of photographic paper
2. Iron it on the board using a piece of cloth between the iron and the foil to avoid melting it
3.Corode it in FeCl3
4.Apply soldering paste on the circuit then add a thing layer of solder all over to protect the copper from corrosion.
The method has its quirks because usually the ink transfer from the foil is not perfect and I have to go over it once again with a permanent marker. That is why I decided to try using photographic paper like you did and after 5 minutes of furious ironing I couldn't get a drop of toner on the damn board :(
parths1Tumbleweed.
Reply 3 years ago on Introduction
apply some pressure while pressing the copper clad and almost instantly scrub it under water and apply pressure while pressing but only for maximum 2 minutes but if its not happening that means you didn't use laser jet printer
or photographic paper is old
Tumbleweed.parths1
You might be right, I didn't print them myself, probably they didn't use a laser jet printer, I'll investigate and give it another go.
smandal13
Very good and well explained instructable. I have seen there is an insulating coat on the PCB we usually find in electronic devices. I suppose these are to protect from accidental short circuit. What is actually this material? And how to apply that on the PCB?
GrinninSamsmandal13
It's just a clear acrylic spray like you'd find in the hardware store. I think the purpose is to keep the copper from oxidizing, but unless you are putting the board in a really hash environment, I think I'd be inclined to skip that step. Also, it might make it a little harder to solder with an acrylic coating, as the heat and flux has to somehow get through it, unless you scrape it clean where you want to solder.
mcross3GrinninSam
The spray is usually applied *after* the soldering process to seal everything against moisture and oxidation. It's a true pain in the ass if you have to do any repairs, but not too hard to work with as a finish to a build.
ziggybass
3 years ago on Step 3
Is that etching fluid you are using? If yes couild you give me an email addresss or web site as I am finding it so hard to find here in Spain :-)
ziggybasssenoleker
Reply 3 years ago on Step 3
I am sorry but I do not understand your reply. What is HCL/H202 and where can I get it. I need to know a supplier. An email or web site? Thank you!
killboxziggybass
Ferric Chloride (FeCl3), is a common echant, in jewelry and electronics. if you look on here there are several instructables on how to Copper Chloride HCL, etching solution, make https://www.instructables.com/id/Stop-using-Ferric-...
or even better, salt, vinigar and hydrogen peroxide, makes for a pretty good albe it a little slower copper etching solution, https://www.instructables.com/id/Is-the-best-PCB-etchant-in-every-kitchen-/
parths1ziggybass
thats simple fecl3 in photo its too diluted and used for long time
you can get fecl3 as powder anywhere
manicmonday
In the printing phase you use standard ink? I have a HP Officejet 4500 printer. The normal ink it uses will work? Thanks
