Dinosaur Pencil Sharpener
17,809
197
20
About: Build.Share.Destroy.Repeat. Follow me and try a few of my projects for yourself!
Tyrannosaurus Rex might be the king lizard, but this tiny terror desktop dinosaur has been tamed to sharpen my pencils.
It might seem like something like this must already exist, and while there are some dinosaur pencil sharpeners, none can sharpen pencils in the dinosaur mouth - making it look like the dinosaur is chewing the pencil to a fine point.
All you need are a few simple tools and supplies, and take special care on where you place the pencil shavings exit. This is a quick and fun project that looks great, is functional, and super easy.
Ready to get prehistoric? Let's make!
Supplies:
Step 1: Tools + Supplies
You probably have some of these items on hand:
These are inexpensive, and the rotary tool is invaluable in the workshop!
Step 2: Measure, Mark, Then Cut
I measured the length and diameter of the small pencil sharpener and made some small marks inside the dinosaur mouth for reference.
Starting with a small carving bit in the rotary tool I careful carved out small sections at a time from the inside of the mouth. I constantly stopped to clear out the plastic debris and check to make sure I was staying inside the envelope of the dinosaur an not blast out the side of the head.
Step 3: Shaving Exit on Side of Mouth
The shavings will need somewhere to exit the sharpener, so a small opening was cut into one side of the dinosaur mouth. This opening will gather pencil shavings, then spill them out.
Dry fit the pencil sharpener into the mouth opening to ensure a good fit, and that the shaving exit is adequate.
Step 4: Epoxy
Once the mouth opening is finished the pencil sharpener can be glued in place. I like using 2-part epoxy, which uses equal squirts of epoxy and catalyst. I mixed up a small batch and coated the inside of the dinosaur mouth and then pushed the pencil sharpener into the mouth cavity, making sure not the get any epoxy over the pencil shaving exit of the sharpener.
The epoxy was left to cure for a few hours before using.
Step 5: Sharpen!
Your prehistoric pencil sharpener is ready to keep your desk safe from intruders, and sharpen your pencils.
This easy and fun modification can be customized for your favourite dinosaur, or just about any other toy. I wonder why toy companies didn't think of this obvious trick first?
Have you made your own dinosaur pencil sharpener, or other toy mod? I want to see it!
Share a picture of your creation in the comments below and get a free Pro Membership to Instructables!
    • Arduino Contest 2019
    • Party Challenge
      Party Challenge
    • Fandom Contest
      Fandom Contest
    20 Discussions
    BobS79
    3 years ago
    This sounds fun I am blind so therefore need to use the computer with special audible screen reader software, I will need to get someone from our Blind Society to try make me two for the Grandkids, how much would you charge for two mikeasaurus?
    kimberley.mccurdy
    3 years ago
    When my oldest son was small, he had a hollow plastic T-Rex. Couldn't this be used instead? That way the shavings would collect inside the body and a hole cut be cut underneath and then plugged. Open when it's full to empty the shavings.
    Igioteno
    3 years ago
    I love the idea!?
    BrodyE
    3 years ago
    Awesome! But how did you make the shavings come out?
    BeachsideHankmikeasaurus
    Reply 3 years ago
    It would be epic if the shavings were deposited right behind his legs, if you get the picture.☺
    mikeasaurusBeachsideHank
    Reply 3 years ago
    I had considered that, but decided to keep it a little more tasteful. Version 2.0 might incorporate your idea :)
    BrodyEmikeasaurus
    Reply 3 years ago
    Ik but there isn't a picture of the hole
    mikeasaurusBrodyE
    Reply 3 years ago
    It's a cut into the side of the mouth, you can see the difference between the 2 pictures in step 3
    thijsv
    3 years ago
    great excuse to put a dinosaur on your desk, no mather how serious your job is! I love it!
    Jedi_zombie85
    3 years ago
    nice idea, deffo giving this a go
    sabu.dawdy
    3 years ago
    This is innovative. Il try to make one
    Carleyy
    3 years ago
    This is awesome!
    BeachsideHank
    3 years ago
    Very original and appropriate too!
    jessyratfink
    3 years ago
    This is fantastic!! I'm gonna have to do this with one of the action figures I have left over. :D
    p.s. when'd we get fancy pencils? I want!!
    annrrr
    3 years ago
    Sooooo gooooooood
