Easy Voodoo Doll Costume
60,216
114
13
About: I work at instructables by day, and turn into a stitch witch by night. follow me on instagram @jessyratfink to see what i'm working on! ^_^
This is a super simple and unisex Halloween costume - the voodoo doll! At the bare minimum, all you really need is a heart and some pins to attach to your clothes. Anything you do after that is just a bonus!
I decided to go ahead and do makeup, too.
But regardless of what you do, a voodoo doll costume is a great last minute idea for Halloween. It'll only take a couple hours to throw together - even less if you take some shortcuts. :D
Step 1: What You'll Need:
  • red felt
  • wire
  • foam balls
  • hot glue gun
  • red paint
  • painbrush
  • small safety pins (for attaching the heart)
Depending on how thick your wire is, you may need to use foam craft sheets - I used a really thick wire, so I stuck it into craft foam to anchor it. For wire that's 14 gauge or less, you'll be able to bend it and then wind it inside the two felt pieces and can skip the foam all together. :D
You might also want some face paints. I really recommend Ben Nye brand paints - the black and red are that brand and they were great to work with!
Step 2: Paint the Foam Balls
Should just take a couple coats. If you're in a rush you can use a hairdryer on low to help speed it up. :D
Step 3: Cut Out Some Hearts
Pretend you're in elementary school! Fold a sheet of paper in half and draw the best heart you can. Cut it out of the paper and figure out if the size is right for you. I had to bring it down in size twice.
Once the size is right, cut it out of both pieces of felt.
Step 4: Assemble the Heart
Because I was using thick wire, I glued three sheets of craft foam to the felt base, and then stabbed the wire through the top layer of felt and into the craft foam and applied lots of glue everywhere.
If you're using thinner wire, cut it really long so that you can poke it through the top layer of felt and then spiral it on the backside of the felt and glue it down. That way it's still stable but not as bulky. :)
Step 5: Makeup Clothes
I applied white paint to my face - but not a thorough coat, I wanted it to look a little grey. Then I applied red around my eyes and black on top of that.
Painted in my brows, used some eyeliner and lipstick, and taaa-daa!
As far as the dress, I chose the warmest one I had and pinned the heart onto the front of it.
Step 6: Party!
You'll have more time to eat candy since your costume took so little time. SUCCESS
2013 Autodesk Halloween Contest
Finalist in the
    • Jewelry Challenge
      Jewelry Challenge
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    13 Discussions
    thundrepance
    3 years ago
    i love voodoo dolls!! x^D .... this is GREAT!
    julwhitso.
    4 years ago on Introduction
    So what is being used for these long pins?? I don't see it mentioned anywhere! Help!
    mikolynn
    5 years ago on Introduction
    Woow!
    http://grooveshark.com/s/Voodoo+Child+Slight+Return/3Cyyw5?src=5
    General Zod
    This is pretty good again, but nothing beats the Frida Kahlo costume you did a while ago. Excellent 'ible.
