Glow Tie
29,085
533
24
About: Build.Share.Destroy.Repeat. Follow me and try a few of my projects for yourself!
Light up your next formal event with a glow tie! You're sure to be the most popular person when you draw shapes on your tie with your UV flashlight and then let everyone else have a turn.
The effect fades after a few minutes and you can apply a new design, allowing you to keep your look fresh all night.
The best part is that the tie still looks great even when it's not charged up and glowing. Making your own is easy and can be completed over a weekend.
Ready to get glowing? Let's make!
Supplies:
Step 1: Supplies
The glow powder is added to a liquid medium which is then applied to the tie. The medium is made from silicone caulking which is diluted in mineral spirits.
You'll want to use 100% clear pure silicone caulking. Look for "silicone I" as "silicone II" has mold retarding agents, we want pure silicone. The silicone can be thinned with mineral spirits. You can find both the caulking and the mineral spirits at your local hardware store.
To make the tie glow you'll need some glow in the dark powder, and a UV flashlight (blacklight) to make it react and glow.
You'll also need a woven tie (not silk), I got mine at a thrift store.
Step 2: Tie Selection
I chose a tie that was not silk, since we want a fabric that has some texture for the glow powder to really get into. A silk tie would be too uniform and smooth the the glow powder to really be effective.
I chose a textured synthetic blend tie over an all silk tie as I thought they were more visually interesting, silk ties are typically a flat canvas to display art and woven ties add an element of depth. Though I used a synthetic woven, you could also buy an all cotton tie if you can't find one locally. This tie label says that it's made from 55% polyester, 21% wool, 18% acrylic and 6% other fabrics, which means it has 100% awesome potential for this project.
Step 3: Mix Medium
To make a medium that can be brushed onto the tie we'll need to thin the silicone caulking with plenty of mineral spirits.
I started with a ratio of 5:1, 5 parts mineral spirits to 1 part caulking. Put both into a disposable paper cup and mix thoroughly. At first this is going to look like too much mineral spirits and not enough caulking, but the caulking is incredibly thick and after a few minutes will begin to thin in the mineral spirits. You're looking to achieve a very runny medium with no clumps, lumps, or anything even resembling the caulking.
The GIF below should be the viscosity you are looking for, something like very runny maple syrup. Oh, it's going to smell terrible so make sure to work in a well ventilated area.
Step 4: Add Glow Powder
Once your medium is completely mixed you can add your glow powder. You can add more or less depending on your preference and glow factor, I used about 2 ounces (50 grams) of powder for this tie.
Pour the glow powder into the mixing cup and stir until all the powder has been incorporated and you have a homogeneous mixture.
Step 5: Brush Onto Tie
I used a bristle chip brush to apply the medium onto the tie. Chip brushes are meant for resin, acetone, and epoxy, so are a suitable choice for this application.
The brush was dipped into the mixture and generously applied all over the tie where I wanted a glow effect. The tie was then hung up to dry in a warm area for a day. The smell from the caulking is still pretty terrible even after a day of drying, but goes away after about a week. You can test your glow tie now after charging it up under UV light, apply a second coating of glow medium if your glow isn't bright enough.
Step 6: UV LED Flashlight
To make this tie glow you'll need to first charge it up with UV light. This can happen outside in daylight, then going into a darkened area inside, but more likely you're already at an event and want to reveal your cool tie and won't have time to charge it up with the sun.
I got this powerful UV flashlight "blackight" online that works really well. There's loads of sizes and styles available, so chose one that suits your needs best.
Step 7: Charge Up and Glow!
After a week of degassing your glow tie should be ready to wear. Suit up with your favourite shirt and you'll be the brightest guy at the party!
Have you made your glow tie? I want to see it!
Share a picture of your version of this project in the comments below and get a 3-month Pro Membership on Instructables!
    • Fandom Contest
      Fandom Contest
    • Arduino Contest 2019
    • Gardening Contest
      Gardening Contest
    24 Discussions
    sylviahamilton
    1 year ago
    this would be awesome for the granddtrs' teeshirts! How washable is it? I would imagine it would hold up rather well since it has the silicone base. If i do a design on their shirts is it clear enough to not be visible until under the black lights? Really stoked about this, fun!!
    Ricardo Furioso
    2 years ago
    Thanks so much for sharing this.
    Heck. With this method, you could make a whole glow shirt.
    Brilliant.
    whopoder
    3 years ago
    Cool!!!
    But I don't know what is Mineral Spirits. xD
    GrantC4
    3 years ago
    what glow powder did you use? I cant seem to find where you said that. also the link for it isn't working.
    thanks
    GrantC4mikeasaurus
    Reply 3 years ago
    how well did it glow? brightness and how long did it glow for?
    GYPSYOWL
    3 years ago
    buy powder off eBay way cheaper. you said you used 2oz and your link was $25 for one ounce?
    Ricardo Furioso
    3 years ago
    Most excellent.
    Thanks for sharing.
    jeanniel1
    3 years ago
    So Dilbert of you! LOVE LOVE LOVE this! I think I might make some for presents! Thinking of presents for the ladies, too! Glowing Scarves, gloves, gosh anything is possible.
    studleylee
    3 years ago
    I want one! I didn't know you could thin out silicone this way. I must try it !!!!
    Mrballeng
    3 years ago
    The world would be so dull without mikeasaurus. This is great.
    Burlingamepez
    3 years ago
    The CLEAR TIE can hold a variety of small items including glow-in-the-dark BBs.
    physicsguy137
    3 years ago
    My glow-in-the-dark powder is on the way and I'm buying a tie this weekend. Let's hope everything arrives in time for the company Christmas party.
    Alywolf
    3 years ago
    Totally going to have to make a Glow Tie now, I have made many glow things in the past. I cant wait to try the silicone and mineral spirits idea, I didnt know you could do that. Another route people can take, especially if they do not want the smell, is by using Acrylic Matt or Glossy medium, and a fabric painting medium. I like Golden's because it is the only one I have tried. They are white, but dry completely clear. Just mix them together, I add about 2/3rds Matt Medium and 1/3 fabric medium. When its done, either throw it in the dryer or use an iron moving constantly, and with an ironing cloth (towel) over it. I shared links just to make it easier to find.
    http://www.amazon.com/Golden-Regular-Gel-Matte-8-O...
    and
    http://www.amazon.com/Acrylic-Gac-900-Heat-Set/dp/...
    ghunt4
    3 years ago
    Excellent! Definitely going to try this. Just one point for UK members, Mineral Spirits is White spirit
    jflake
    3 years ago
    Dude! every time I find an amazing instructable I am like... I wonder who this is, almost every time it turns out to be MIKEASAURUS! another quality instructable! Keep up the amazing work. I am going to have to do this with my kid's ties and then frisk then for flashlights when we go to church :)
    Yonatan24
    3 years ago
    Awesome! It would look really nice in other colors too
    snowpunk
    3 years ago
    would a regular light source charge instead of the UV light source?
    Would this process work to paint onto a solid surface as well? I suspect it would.
    (thinking of painting some skis to glow in the dark)
    leon.t.gibson
    3 years ago
    I love the step-by-step illustrations.
    henry98
    3 years ago
    Thanks for the great idea!
