How to Capture a Photo of a Lightning (poor Man's Way)
573
10
this is a tutorial on how to capture a still photo from a video with a lightning
Supplies:
Step 1: Capture a Video of a Lightning
1.firstly you should find a place from where you can capture the video ,without your camera becoming wet from the rain (of course if your camera isn't waterproof)
2.you should set your camera on the best quality it can record and at the most frames per second (fps)
3.have a rainy day with many lightnings
4.record the video
Step 2: Download and Install Software( Free Video to JPG Converter )
in order to get the best picture out of your video you should use the proper software to get all the video frames as images i used Free Video to JPG Converter
Step 3: Use the Program
1. add the file(video)
2.select ''Every Frame"
3.convert
Step 4: Find Your Image
once the converting process has finished you should find the best photo
this can be done by the following way
1.first watch the video ,see and note the exact second of the video when the lightning appears
2.then if you know the fps of the video you can calculate the photo's "serial" number as shown bellow
number=seconds*fps
3.search for the photo it should probably not be so difficult to find
Step 5: Finished.....
credits :cover Photo was taken by Mathias Krumbholz. Using a Sony Alpha 700.
    • Gardening Contest
      Gardening Contest
    • Classroom Science Contest
    • Fandom Contest
      Fandom Contest
    3 Discussions
    BengaminJ
    3 years ago
    This is not the best way to capture lightning. Setting a dslr to manual is far Superior.
