Kermit the Frog Clone
61,567
172
26
About: I am an puppet creator and a sculptor
Some days ago SHIFT! asked me if I can post a Kermit tutorial
Sooooo, here it is
It is not the perfect replica but it resembles in some  manner
So I called this a Kermit clone
Searching online I found out that there is a muppet comics out there
never knew that  :P
Experiment with this instructable and do some tweaks and you will be there
You can also ask some advices from    puppets and stuff.com
 Materials needed for your puppet
Fleece    I recommend you buy a good quality one because if the fabric is to thin the seams will show
Eyes  I was looking for a small plastic bal to cut in two ,you can find them at corners in machines similar to gum drop machines , but of course I did not find this and I made them from polystyrene
Hot glue sticks
Contact cement
Craft rubber
Some aluminium wire
Craft paper
Sponge
Tools :
Scissors
Cutter knife
Needle
Brush for the contact cement or a stick
Pins
Marker pen
Sewing machine
Hot glue gun
Step 1: Cut and Glue
Make your stencils on craft paper(it is cheap and you can afford to do mistakes)
Take the stencil for the head
Mark and cut two pieces from the sponge you have(it is a good idea to use a thinner one than the one I had ,because when the sponge is too thick it is a little difficult to work with the puppet in the end)but you can also use what you find around the house
 Glue the pieces using contact cement
Step 2: Cut Fabric and Stitch
Take a piece of fleece fold it in two,
Mark it using the same stencil as for the head
Stitch first around the head (no 1 in picture)
Then stitch the upper segment (no2)
Cover the sponge with the fleece and then…
Step 3: Make Mouth Board
Trace the mouth board by folding a piece of cardboard and placing it in the puppets mouth,
Trace around the sponge
Cut a little smaller than the tracing because this will give the big dimples in the corner of the mouth
I forgot to do this
 Glue fleece to mouth board using hot glue
Fit board inside puppets mouth and first glue the corners
Then the middle of each side(top and bottom)
Glue the rest
Step 4: Glue Mouth Board
Glue the rest
Step 5: Cut Sponge and Fabric for Body
Take two pieces of fleece and fold in two
Trace the body stencil on them
Stitch
Cut four pieces of sponge using the same stencil
Glue together and fit the segment inside the fleece part
Step 6: Stitch Head to Body
Stitch the head to the body using a ladder stitch
Step 7: Make Neck Piece
make a triangle stencil and cut the neck piece from yellow fleece
Step 8: Make Arms and Fingers
Make arms and fingers
This I made by sewing a thin hose and a wider one
Cut the wide one for arms and the thin for fingers
You can add some aluminium wire to the fingers to make it easier to shape the fingers
Stitch the fingers inside the wide hose
Place wire inside fingers
Close fingers
Stitch fingers to the body
Step 9: Add Eyes and Tongue
Make or buy the eyes and glue them in place(i made them from polystyrene)
Make the tongue from pink craft rubber and glue with hot glue
make the dark part of the mouth also from craft rubber
Step 10: Try Out Your Puppet
Try out your puppet and have fun
:P
I have some puppets on my Etsy shop if you want to check them out
https://www.etsy.com/shop/TheCircusCottage?ref=seller-platform-mcnav
Comic Contest
First Prize in the
Comic Contest
    • Jewelry Challenge
      Jewelry Challenge
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    26 Discussions
    QUEEN19721991
    Question 12 months ago
    So I have a few questions:
    1. What kind of stitches did you use for the fingers?
    2. After stitching the head, do I need to turn the head inside-out?
    3. Can you email me a tutorial video? I was unable to work only with the instructions
    4. What would you recommend me to use as arm-rods?
    1 answer
    todyQUEEN19721991
    Answer 11 months ago
    I made the fingers on the sewing machine
    yes you need to turn the fleece inside out so the stitch gets hidden.
    I do not have a video of this puppet as I built it ages ago :)
    For arm rods I usually use a wood dowel .I buy it in 1 meter long pieces from the home improvement store
    nadernehal
    2 years ago
    I like your tutorial, Tody. It was just that I was thinking if you could post or email me the pattern you used; I am not good at drawing patterns.Thank you!
    NathanSellers
    3 years ago
    Nice work. What a fun puppet project.
    Good job. but a tip for the mouth... you shouldn't put the little grooves at the side of the mouth... that's what I've found out at least. But really good job otherwise! Oh, if you want to see pictures of the Kermit that my sister made last year, check out this blog: http://awesome-kermit.blogspot.com/
    SHIFT!
    7 years ago on Introduction
    Wow great job! Thanks for sharing this step by step, always wanted to build one!
    Kermit The Frog replicas do take a lot of practice to make and tons of trial and error to make. I've been on several Muppet forums and a lot of prop replica builders are very secretive about sharing plans, which is disappointing.
    CaptainTal
    6 years ago on Introduction
    thants really good i made one myself not based of of your tutorial
    h1web
    How did the frog head take on the 3D shape exactly? I'm just not seeing it
    SHIFT!
    Could you please post a video of him being puppeteered? It would truly be Muppetational to see him alive!
    Kiteman
    It would be very cool if you could scan your templates and add them as scaled PDF files...
    kgeffe
    Great job. Ping pong balls cut in half are what Henson originally used for Kermit's eyes.
    jstubbs1
    That looks great! My first thought on how to improve your replica drastically is by using ping pong balls for eyes. That's how Henson did it, and it usually gives a very nice sharp feel.
    smurrell
    7 years ago on Step 9
    He is fantastic im just going to have to give it a go at making this my kids will love it!.....Ok I will love it more. Are there any other muppets to make too pwitty pweeze!
    But well done hes super ;-)
    the_kcar
    The original Kermit was made from a discarded-but-salvaged ladies' coat and the eyes were made from a ping pong ball. Henson surrounded himself in creative people, but refused to take credit - even when and where it was warranted.
    Muppet [mannequin-puppets] makers always preferred to keep most of their design creations close to the chest, but Henson actively tried to create workshops to teach the next generation...to carry the torch, but pass the flame along.
    Another note: the muppets oftentimes required not just one person to operate/animate, but sometimes two or three people to coordinate a single muppet's movements.
    The original Kermit wasn't a frog, but rather it was later upgraded/morphed into being Kermit at a later point in time.
    Sorry for the comment overload. Much Props for the 'ible.
    TheMattMan
    Very cool. You should try fishing bobbers for the eyes. I've seen them used with some success in puppet building.
