Laser Cut Bicycle Wallet
11,929
130
7
About: I am a queer, transgender, nonbinary, and mixed-race picture book writer/illustrator. As a young person, I didn’t have the words to explain the big feelings I had about my identity and relationships. It is s...
I've been needing a new wallet for a while, so I decided to laser cut myself one, based on this instructable with a couple updates. Jbagnol's wallet is pretty cool, but they didn't include their work file. I also wanted to give instructions for those without a laser cutter.
I’m lucky enough to have free access to a laser cutter and colleagues who leave large enough scraps in the trash, so I used 1/16th inch plywood. However, if you don’t have access to a laser cutter, you could make a version out of cardboard, card stock, or mat board and an exacto knife. If you’re doing an exacto knife version, be on the lookout for thick card stock, kind of like what a cereal or tissue box is made out of, rather than corrugated shipping cardboard. You could even laminate or cover with clear shipping tape (the poor person’s version of laminating) for additional support.
If you're doing this without a laser cutter:
  • print the attached .png and cut along the dotted lines. This will be your pattern.
  • Use the pattern and trace it onto your heavy cardstock
  • Cut the cardstock with an exacto knife. (You might wish to forego the keychain holder, since it is the most fragile component)
  • place cards between cardstock covers and attach with rubber bands, elastic, or bicycle tubing
  • decorate, if you wish!
Materials:
  • laser cutter or scissors/exacto knife
  • 1/16 in plywood or heavy cardstock
  • small piece of spare bike tube, rubber bands, or other elastic.
Step 1: Designing Wallet in Illustrator
See annotated images!
  1. Begin by measuring your wallet.
  2. Add thumb tabs to facilitate removing cards.
  3. Indent so elastic band won't slip
  4. Optionally, add keychain tab/hole
  5. Add engravable elements
  6. Color code and set appropriate thickness for your laser cutter.
Step 2: Laser Cut It! (or Exacto Knife/scissors)
I used 1/16th inch plywood with vector set at 100% power, 15% speed and raster set at 100% power, 80% speed. Those settings are highly dependent on your laser cutter and material. Illustrator-editable PDF is available in intro for laser cutting, or use the .png and cut on the dotted lines.
Step 3: Put It Together!
I used a piece of an old bike tube to hold my wallet together. The cards are placed between the two plywood sheets. It's pretty sturdy so far! Let me know if you have any questions!
Rubber Bands Challenge
First Prize in the
    • Woodworking Contest
      Woodworking Contest
    • Party Challenge
      Party Challenge
    • Arduino Contest 2019
    7 Discussions
    brcastle
    4 years ago
    You go to UW-Madison, don't you? (Bus pass)
    jayluddenbrcastle
    Reply 4 years ago
    I do! I'm an MFA candidate in the art department. You?
    seamster
    4 years ago on Introduction
    Very cool design! I'm gonna say, I think using a band made from an inner tube has to be a requisite feature on this! ;)
    jayluddenseamster
    Reply 4 years ago
    You might be right for this version. I think it would be cool to make a wallet with vegetables engraved on it and use the super thick blue rubber bands I often see on broccoli at the grocery.
