Make a Leather Wallet
153,550
1,030
30
About: I work at instructables by day, and turn into a stitch witch by night. follow me on instagram @jessyratfink to see what i'm working on! ^_^
In this instructable I'm going to take you through my whole process of making a leather wallet. This is something I've been working on for a few months now and I'm really pleased with the finished workflow and product. I've been carrying different versions of this wallet for months now now and I love it! It's nice and small (easy to fit in the terrible and nearly nonexistent pockets in lady jeans!) but still fits a decent amount of cards and cash.
I've included three different wallet patterns with this tutorial - one with straight pockets and two with slanted pockets. This wallet is able to hold eight cards a little folded cash - perfect for every day use!
Making this leather wallet will teach you loads about leatherworking, too! It's a great project to get you off and running.
P.S. If any of the links to Tandy aren't working, please use the search on the Tandy Leather website to find what you need.
Check out the rest of my intro to leatherworking projects for more information:
Step 1: Tools + Supplies
Below is a list of the things I used to make this wallet, with links to what I'm using if applicable:
It's also a great idea to have some paper towels and q-tips on hand.
I know this is a huge list, but you'll be able to make so many projects with just this basic set of tools. You can also use that weight of leather for many things, too - bags, straps, jewelry, etc.
Step 2: Choose and Cut Out Your Pattern
I've attached three patterns in PDF format. Choose the style you'd like and cut it out carefully using a ruler and an x-acto knife.
Lightly oil the grain side of the leather once it's been cut.
Click here to read about how to cut leather.
Step 3: Burnish the Short Edges
You'll want to burnish the two short edges because we'll have a hard time getting to them later on once they're glued down and sewn into place.
First, apply a little oil to the edges - if they're too dry it'll be very hard to get a nice burnish. Apply a bit of gum tragacanth to the edge, let it get tacky, and run a slicker over it. Keep repeating the process until the edges have slightly darkened and smoothed out.
For more information on burnishing leather, check out my "how to burnish leather edges" instructable.
Step 4: Make the Side Folds
Mark the side and middle fold lines on the flesh side (the fuzzy side) of the leather - I like to run a bone folder down the line.
Dampen the side folds with a little water and then fold them over and clamp them into place. Be very careful about positioning them in the right place - you really want to get this right the first time!
I like to use leather scraps in my clamps to protect the leather I'm using from getting marks in it.
Clamp until dry and then check out how they're looking. If they're not folded perfectly, moisten the leather again and pound with a mallet. That will help flatten out the fold. :)
For more info on this, check out my "how to make folds in leather" instructable.
Step 5: Make the Middle Fold
Moisten the middle fold line and fold the leather in half carefully - make sure all the edges line up nicely!
I like to put this fold into the stitching pony and clamp the sides, too. :)
Step 6: Groove the Stitching Lines on the Inside Pockets
I've marked the stitching lines on the pattern - use a groover to mark them on the side folds.
Go slow and steady and work with dry leather for best results.
Step 7: Glue Down the Pockets
Use a piece of tape or paper as a guide to apply the glue and keep it away from places it doesn't need to go. (It can make punching holes and sewing harder!)
Apply your glue just along the edge of the inside pockets and clamp or hold until dry.
For more information about glueing leather, check out my "how to glue leather for sewing" instructable.
Step 8: Punch the Sewing Holes on the Inside Pockets
I'm using diamond chisels to do this - they're much more accurate than an awl for me!
Moisten the leather lightly wait until it's almost dry, and then line up the chisels to punch your holes.
Step 9: Use an Awl to Make Holes Through to the Outside of the Wallet
Place your wallet on a piece of cardboard, inside holes up.
Use a nice sharp awl and punch it down through the inside holes. Make sure you're punching straight up and down - no angled punches, or the stitching holes on the back of the wallet can come out crooked.
This will leave you with a line of tiny holes on the outside of the wallet - this is how we'll line up our grooving and stitching holes on the other side.
Step 10: Groove and Punch the Outside of the Wallet
Using the tiny holes from the awl as a guide (they should lay right in the middle of your groove!), groove the outside of the wallet to match the inside.
Wet the leather and let it go nearly dry again, and then line up the chisels with the holes and punch.
At this point, it's a good idea to use the awl to punch through both layers again to make sure the holes are nice and clean. It'll speed up sewing.
Step 11: Oil the Wallet
It's important to oil the leather before sewing because the wax on the thread can cause issues with getting the oil to soak in.
Use an old piece of cloth and give the grain side of the leather a couple coats of oil. Pay special attention the to the stitching grooves - this will be your last chance to oil them properly.
(I'm using jojoba for all my oiling - it's odorless and has a very long shelf life (5 years!) meaning it's not going to go rancid on you.)
Step 12: Stitch the Wallet Pockets Down
For this part, you'll want to thread some leather needles with about 16 inches of thread.
I've got a whole instructable over this process - click here to learn how to saddle stitch.
Step 13: Sand the Long Edges
Use fine grit sandpaper to sand down the long sides of the wallet.
This will help ensure both layers of leather the pockets are made of line up correctly. It'll make burnishing these edges much easier!
Step 14: ​Burnish the Long Edges
Use gum tragacanth to burnish these edges just like the ones before. Remember to add jojoba oil to the edges if they're really dry. :)
Once you're done, your edges (including where the pockets overlap) should be nice and slick.
Step 15: Oil Again and Enjoy!
Once you're done sewing and burnishing, lightly oil the wallet one more time. Now you're good to go. :D
2 People Made This Project!
  • IoT Challenge
    IoT Challenge
  • Classroom Science Contest
  • Gardening Contest
    Gardening Contest
30 Discussions
UmairM24
7 months ago
very easy and useful. slim wallet thats what I was looking for
LightsAction
3 years ago
Nice project!
What is the reason you don't punch all the way through both layers at the same time with the chisels? Just curious about why you do it in two steps/two tools. Thanks!
jessyratfinkLightsAction
Reply 3 years ago
Attempting to punch all the way through at once had three problems - the top layer you're punching on gets indented, and the bottom outside layer (on the opposite side of the wallet) ended up with the flesh pushed up and out and looking a little ragged. Sometimes the amount of pressure needed to punch all the way through meant the holes ended up a little skewed, too.
Doing it on both sides gave me the cleanest and most uniform results. :)
ramk57
3 years ago
it is a very use full item, i like it. and i make two wallet by self.
and i like you.
jafrance
4 years ago on Introduction
I am getting all that I need to get into Leathercraft, and to make this wallet, from my local Tandy. Is there another oil that you can suggest for prepping? Tandy does not sell jojoba oil, and the only "general purpose" type oil I see in their product catalog or online is advertised to "significantly darken most leathers". I am considering using oil dye, but that seem like more of a finisher than a prep.
jessyratfinkjafrance
Reply 4 years ago on Introduction
The two other major oils I've found folks to use are neatsfoot and olive. I did not care for neatsfoot - it darkened the leather a lot and smelled like a rodeo. :P
But olive worked really well! Darkened only a little, but it absorbed pretty slow, so you have to wait a long time between coats to see if you really want to put more on or not! I just didn't use it because I ended up liking the jojoba more.
The Rambler
Awesome project once again. I think I really need to get a stitching pony. Was that a life changer when you got it? Or just mildly helpful?
ALD3The Rambler
Reply 4 years ago
If you do very much stitching or lacing, a stitching pony is really a must. Different between night and day, I been using 1 for 25+ years, its like having a 3 rd set of hands. There are some very good Instructions to make 1 and I'm wanting to make a new 1, mine is still in good shape but would like it a little higher as I'm tall. Hope this helps.
The RamblerALD3
Thanks for the input. I've seen a couple instructions on making one and I think I'm definitely going to have to try it. I'm sure I could make one out of scrap wood for close to free rather than buying one for $30-100.
ALD3
4 years ago
Very good and simple instructions, wish I had these when I started leather years ago. I still read others instructions as I always find a new or easier way to do something. Yours included and will be reading all your Instructables. Thanks
iamunique127
Hi. The finished product looks wonderful and the instructions are nice and clear.
One question: do you oil the inside of the leather (the fuzzy side) too?
Thanks
8HATE8
4 years ago
So sweet and lovely !!!! ( The wallet is too ;) ) no seriously it's as great as it's simple ! Thousand " hearts
handycrowd
Thanks for making the time to do all these!
I just dismantled an old leather briefcase I had made in Uganda many years ago, I couldn't bring my self to throw it away. I have started making a few tool holders etc out of it and now I can really 'up my game' and make something nice.
Superb instructables!
